cbr046 Posted June 29, 2021 Share Posted June 29, 2021 (edited) Sliding mirrored wardrobe doors. When we bought the coach the seller said we would break these. Yup, after 4 1/2 months the first one snapped, and I had been ever so careful, too. http://www.rvdesigner.com/images/products/imageView.asp?id=205&t=items IMO it's a BAD DESIGN to begin with, and it peels the faux brass off where it rubs the door's plastic frame. I found replacements . . . . but why if it's just going to break again? Has anyone replaced with these? Amazon, $5.76 and 15 lbs of pulling force. Seems like the perfect replacement. https://www.amazon.com/WOOCH-Magnetic-Stainless-Hardware-Closer-Sliver/dp/B07N2NQ992/ Thoughts? - bob Edited June 29, 2021 by cbr046 Link to comment Share on other sites More sharing options...
Dale n Deb Posted June 29, 2021 Share Posted June 29, 2021 N is that's an interesting idea. I'd like to hear how it works for you. Link to comment Share on other sites More sharing options...
tmw188 Posted June 29, 2021 Share Posted June 29, 2021 (edited) I was just online last night looking for one! I might go ahead and try them, they are less expensive and they won’t break on you. Edited June 29, 2021 by tmw188 Link to comment Share on other sites More sharing options...
Dr4Film Posted June 29, 2021 Share Posted June 29, 2021 I purchased a number of those plastic latches over a number of years but finally decided not to spend anymore of my hard earned money on a worthless POS. I then purchased two spring loaded shower rods in brass color to match the closest frame so once we have the closet packed and ready to travel I simply adjust the length of each rod to fit snugly into each bottom rail. Those doors have never moved a mm and no more broken latches to replace. 1 Link to comment Share on other sites More sharing options...
Gary M Posted June 29, 2021 Share Posted June 29, 2021 These are the three parts to my closet doors. Available at https://shop.findmyrvparts.com/ Link to comment Share on other sites More sharing options...
96 EVO Posted June 30, 2021 Share Posted June 30, 2021 Gary, that part you show in your first pic is prone to breaking as well. Even installed one that only lasted one closing. I replaced them with small blocks of hardwood with grouves cut in them. These are holding up well after several years. Link to comment Share on other sites More sharing options...
Gary M Posted June 30, 2021 Share Posted June 30, 2021 37 minutes ago, 96 EVO said: Gary, that part you show in your first pic is prone to breaking as well. Even installed one that only lasted one closing. I replaced them with small blocks of hardwood with grouves cut in them. These are holding up well after several years. Can u post a picture? Link to comment Share on other sites More sharing options...
96 EVO Posted June 30, 2021 Share Posted June 30, 2021 I'll try. Link to comment Share on other sites More sharing options...
96 EVO Posted July 1, 2021 Share Posted July 1, 2021 Lets try this. The blocks are made from leftover 3/4" oak tongue & groove flooring. The groove is the perfect size, and place for the latch to hold the door nice and tight. I sanded off the gunstock stain and made my own cherrywood. Could have been a little darker, but, I'm not a perfectionist. 1 1 Link to comment Share on other sites More sharing options...
Dr4Film Posted July 1, 2021 Share Posted July 1, 2021 (edited) Ben, it appears that your latching mechanism is not the same as some of us that have older coaches. Edited July 1, 2021 by Dr4Film Link to comment Share on other sites More sharing options...
96 EVO Posted July 1, 2021 Share Posted July 1, 2021 2 minutes ago, Dr4Film said: Ben, it appears that your latching mechanism is not the same as what people are discussing on this thread that had a plastic latch as seen in the very first post. Yeah, that post was for Gary, who appears to have the same latches as myself. Link to comment Share on other sites More sharing options...
Dr4Film Posted July 1, 2021 Share Posted July 1, 2021 Got it. Thanks. Link to comment Share on other sites More sharing options...
Gary M Posted July 1, 2021 Share Posted July 1, 2021 48 minutes ago, 96 EVO said: Lets try this. The blocks are made from leftover 3/4" oak tongue & groove flooring. The groove is the perfect size, and place for the latch to hold the door nice and tight. I sanded off the gunstock stain and made my own cherrywood. Could have been a little darker, but, I'm not a perfectionist. Nice job 👍. Link to comment Share on other sites More sharing options...
cbr046 Posted August 1, 2021 Author Share Posted August 1, 2021 On 6/29/2021 at 11:34 AM, cbr046 said: Has anyone replaced with these? Amazon, $5.76 and 15 lbs of pulling force. Seems like the perfect replacement. https://www.amazon.com/WOOCH-Magnetic-Stainless-Hardware-Closer-Sliver/dp/B07N2NQ992/ - bob There's significant force required to open the doors, and without a pulling handle you have to kinda dig your fingers in the crack. It's not hard, but a handle would be convenient. Now for some post-trip feedback . . . . If the coach rocks enough (and mine rocks a LOT due to some of the places I pull into) the doors will unlatch. One sliding door unlatched twice and the other once during my 1,600 mile trip. I'll install a second set of magnetic latches and maybe a pull handle of sorts to make opening easier. I forgot to latch the shower door during the trip. Never thought it would be necessary, but at some point it swung open with enough force to bend the hinge and prevent closing of the door. Ahhh, another thing to fix! - bob Link to comment Share on other sites More sharing options...
