tmw188 Posted September 9, 2021 Share Posted September 9, 2021 Under the coach today putting the collection bottle on my CVT crankcase ventilation tube and was taking pictures and recording images. What is this? Almost looks like a AC Drier? Located way in the back up high near the electric fuel pump. Link to comment Share on other sites More sharing options...
vito.a Posted September 9, 2021 Share Posted September 9, 2021 (edited) You're right. It's the A/C drier for the dash A/C. Ours is up front next to the generator. Edited September 9, 2021 by vito.a Link to comment Share on other sites More sharing options...
Nevada Rob Posted September 9, 2021 Share Posted September 9, 2021 I thought that was the blinker fluid container for the rear turn signals. I guess I was wrong. 2 Link to comment Share on other sites More sharing options...
Just Jim Posted September 9, 2021 Share Posted September 9, 2021 Nope, that powers the wobblin shaft for the smoke grinder. 1 Link to comment Share on other sites More sharing options...
tmw188 Posted September 9, 2021 Author Share Posted September 9, 2021 1 hour ago, vito.a said: You're right. It's the A/C drier for the dash A/C. Ours is up front next to the generator. Figured it was but seemed to be in a odd location. Maybe closer to the condenser is better? Link to comment Share on other sites More sharing options...
Dr4Film Posted September 9, 2021 Share Posted September 9, 2021 12 hours ago, tmw188 said: Figured it was but seemed to be in a odd location. Maybe closer to the condenser is better? Or maybe closer to the compressor is better? Link to comment Share on other sites More sharing options...
tmw188 Posted September 9, 2021 Author Share Posted September 9, 2021 2 hours ago, Dr4Film said: Or maybe closer to the compressor is better? Yep maybe, although in residential applications they like it closer to the evaporator. You often see them outside near the unit only because of the convenience of not needing to go inside someone’s basement or home is what I’ve been told. In either case it’s a tough spot to get to. Link to comment Share on other sites More sharing options...
Dr4Film Posted September 9, 2021 Share Posted September 9, 2021 2 minutes ago, tmw188 said: In either case it’s a tough spot to get to. I would agree. When I had a new compressor installed back in 2012 they installed a new dryer. It took two of us, the shop owner and myself. I held up the cover plate that is located over the dryer while the old dryer was removed and the new one installed. You get to it by removing the small narrow engine cover that is located in front of the closet. You will then see a long plate which holds some relays, etc. You remove the screws holding the plate and then one person can lift the plate up at an angle which exposes the AC drier. Look at the photo below in the lower right corner where it describes the relay's etc. that are located under that cover. I also installed a switch onto that cover which will activate the PRXB PackBrake which I use when lubing the exhaust brake. Link to comment Share on other sites More sharing options...
tmw188 Posted September 9, 2021 Author Share Posted September 9, 2021 NICE! Link to comment Share on other sites More sharing options...
tmw188 Posted September 10, 2021 Author Share Posted September 10, 2021 That’s good to know Richard, hopefully I won’t need to replace that because if I do I was needing more than just that. Link to comment Share on other sites More sharing options...
Dr4Film Posted September 10, 2021 Share Posted September 10, 2021 Correct! Seldom does the drier need to be replaced unless the system has been opened up for a repair or replacement of failed parts. It SHOULD be replaced each and every time anything has been done to the system other than adding new coolant. Link to comment Share on other sites More sharing options...
