Rivrman2 Posted September 19, 2021 Posted September 19, 2021 This system seems to be the system of choice but their kits only include up to eight sensors. Including my toad I need 10 sensors. Thoughts?
Dr4Film Posted September 19, 2021 Posted September 19, 2021 You are not looking in the right places. https://tinyurl.com/48w5xrtk
Mark B Posted September 19, 2021 Posted September 19, 2021 Try Technorv https://www.technorv.com/tst-tire-pressure-monitoring-systems/
Paul Busch Posted September 19, 2021 Posted September 19, 2021 I put 12 Bellacorp on 3 years ago and love them. Easy to program, change batteries, and move around. Also with my 45’ I have no trouble receiving signal from toad tires. paulb
Guest Ron Jones Posted September 19, 2021 Posted September 19, 2021 I have 8 working Flo-Thru sensors and new batteries for sale. See them here... https://tinyurl.com/shne7uz6 Contact me direct at [email protected]
Jim McGarvie Posted September 19, 2021 Posted September 19, 2021 I have the EEZ TPMS and like it just fine. My only disappointment is because they are external, they essentially report outside air temperature, not tire temperature. I thought tire temperature would be a useful early warning sign, but.... Just mention it since the OP is considering external sensors.
Steven P Posted September 23, 2021 Posted September 23, 2021 Maybe the kit you see is for 8? You can add bunches of them. Website says up to 110 sensors for multiple trailers.
ready2retire59 Posted September 23, 2021 Posted September 23, 2021 We have used the TST system since we bought our motorhome in 2005. We are on our 3rd generation system and are very happy with its performance. You can buy as many sensors as you need as Steven P says. They are easy to program and they do monitor the tire temperature and pressure as they rise going down the road. Be sure to buy the latest version since the monitors are not upward/downward compatible. The sensors will work with either monitor, but if you have an older monitor, it will display errors when a new version monitor comes in range. This happened to me several times with the older monitor when I was parked and when going down the road. The company explained that the newer monitor would cause this problem and their only solution was for me to buy a newer monitor. After much complaining about how can you design a new monitor that is not downward compatible with your previous model, I broke down and spent the less than $100 for a new monitor. I'm glad I did and everything is working fine now. Tony & Doreen Chiulli '03 Windsor, '05 Ram Toad
Oregon04Windsor Posted September 24, 2021 Posted September 24, 2021 I ordered the TST system with the flow through caps. For those of you with those caps, are they fine to just attach to the inner dual with a metal valve stem or are you using a rigid extender and rubber grommet?
ready2retire59 Posted September 24, 2021 Posted September 24, 2021 I would recommend getting the braided flexible extensions that mount onto the center hub of the rear wheels and putting the sensors there. On the front, you can mount them right on the valve stem. On the toad, you can mount them on the rubber valve stems. The new ones are light enough. The old ones needed a solid valve stem to mount to. Tony C.
