rpasetto Posted October 3, 2021 Share Posted October 3, 2021 What have you all done with the empty space between the genset and the genset bay door. It seems like good potential for storage, light stuff of course since the capacity of the gen-slide mechanism is unknown and it's way forward of the axle. Link to comment Share on other sites More sharing options...
jacwjames Posted October 3, 2021 Share Posted October 3, 2021 Vanwill just had a post where he installed a motorized cord real to hold his 50 amp cord. I looked at the space the other day, lots of space and seems like plenty of structure. Link to comment Share on other sites More sharing options...
georgeandlouise1 Posted October 3, 2021 Share Posted October 3, 2021 We built a shelf out of aluminum and used non skid tape on the shelf and use a plastic container with top and store our rv wax and gallon of soap and other cleaning items. george 2007 Dynasty countess 3 Link to comment Share on other sites More sharing options...
Dr4Film Posted October 3, 2021 Share Posted October 3, 2021 The original owner had built up that area into a deep rectangle storage box. I use it for storing hoses and cables etc. I also built a platform on top which is on hinges to hold an auxiliary 12 VDC Compressor which supplies air to the Step Cover when we are parked for extended periods of time. Link to comment Share on other sites More sharing options...
Land Lubber Posted October 3, 2021 Share Posted October 3, 2021 My '09 Camelot has limited space in front of the genset so I used the space on top of it. Built a 16" x 20", 5" deep wooden box that I anchored to the generator cabinet using heavy duty zip ties where I store my 50 amp extension cord & air compressor hose. I still have a bit more room but I haven't filled it up as yet. Link to comment Share on other sites More sharing options...
waterskier_1 Posted October 3, 2021 Share Posted October 3, 2021 I made a wire cage or box that I us for extra water hose, jumper cables, rags, floor mats, and other bulky but light stuff. I just got a small 150 PSI compressor and I'm going to see if I can fashion something like Richard has. Link to comment Share on other sites More sharing options...
Rikadoo Posted October 4, 2021 Share Posted October 4, 2021 Some pics gentelmen😎 Link to comment Share on other sites More sharing options...
woodylmiller Posted October 5, 2021 Share Posted October 5, 2021 To the gentleman using zip ties, I suggest using the black ones and good quality if you haven't. Cheap ties will not last long, even the black ones. UV will eat the cheap ones in a couple of years. A shop used some cheap crap to hold a small box on our toad and they broke and the box dropped. They were 3 years old and the thick ones, 1/4", but cheap. I replaced for the time being with Thomas/Betts black ties, which are high industry standard zip ties. I have thought the same thing about all that wasted space in front of the gen. Great place to store something for sure. Woody Miller Link to comment Share on other sites More sharing options...
Land Lubber Posted October 5, 2021 Share Posted October 5, 2021 1 hour ago, woodylmiller said: To the gentleman using zip ties, I suggest using the black ones and good quality if you haven't. Cheap ties will not last long, even the black ones. UV will eat the cheap ones in a couple of years. A shop used some cheap crap to hold a small box on our toad and they broke and the box dropped. They were 3 years old and the thick ones, 1/4", but cheap. I replaced for the time being with Thomas/Betts black ties, which are high industry standard zip ties. I have thought the same thing about all that wasted space in front of the gen. Great place to store something for sure. Woody Miller I used heavy duty black zip ties as you suggested. Being that they are not exposed to sunlight I'm not sure that UV light will be an issue. I'll keep an eye on them though. Thanks for the tip. On my Camelot, there wasn't much usable space in front of the genset plus the windshield washer tank is mounted there so I decided to avoid damaging the hose leading to the wipers by not attempting to build a box around them. I have more usable space on top of the genset. Link to comment Share on other sites More sharing options...
