rambler07 Posted April 11, 2020 Share Posted April 11, 2020 (edited) Looking for the ride height for a 1996 HR Endeavor with a Cat engine, looked at all the charts on the net but no info for a 1996 Endeavor . The coach Is on a Freightliner chassis. Edited April 11, 2020 by rambler07 more info Link to comment Share on other sites More sharing options...
Highwayman Posted April 11, 2020 Share Posted April 11, 2020 Find a similar vehicle with the same chassis and length. The ride height will not vary by engine. Link to comment Share on other sites More sharing options...
Dennis H Posted April 12, 2020 Share Posted April 12, 2020 This is from a 96 Dynasty and most likely the same as yours....Dennis Ride Height Instructions.pdf Link to comment Share on other sites More sharing options...
Bob Nodine Posted April 12, 2020 Share Posted April 12, 2020 12 hours ago, rambler07 said: Looking for the ride height for a 1996 HR Endeavor with a Cat engine, looked at all the charts on the net but no info for a 1996 Endeavor . The coach Is on a Freightliner chassis. 1991 - 2008 Ride Height Chart.pdf Link to comment Share on other sites More sharing options...
96 EVO Posted April 12, 2020 Share Posted April 12, 2020 Bob, looking at the chart you posted, the '08 and '09 models (mine isn't in either for some reason) it shows 'Bag height', and 'ride height'. Any idea what the difference is? Link to comment Share on other sites More sharing options...
Bob Nodine Posted April 13, 2020 Share Posted April 13, 2020 13 hours ago, 96 EVO said: Bob, looking at the chart you posted, the '08 and '09 models (mine isn't in either for some reason) it shows 'Bag height', and 'ride height'. Any idea what the difference is? I would guess the Bag Height is the actual height of the air bag and the Ride Height is the measurement between the top and bottom plates of the mounting for the air bag. See the attachment. RH_Adj.pdf Link to comment Share on other sites More sharing options...
duncan8846@att.net Posted April 13, 2020 Share Posted April 13, 2020 Bob and Dennis, I believe the OP said his coach is on a Freightliner chassis not a Roadmaster duncan, 14 Entegra Anthem 15 Windsor sold hunkered down in N Calif Link to comment Share on other sites More sharing options...
Bob Nodine Posted April 14, 2020 Share Posted April 14, 2020 18 hours ago, duncan8846@att.net said: Bob and Dennis, I believe the OP said his coach is on a Freightliner chassis not a Roadmaster duncan, 14 Entegra Anthem 15 Windsor sold hunkered down in N Calif Missed that. Guess his best bet would be to check with the Ramblin Pushers since they most likely have info on Holiday Rambler coaches before Monaco purchased the brand. Link to comment Share on other sites More sharing options...
walt2137 Posted April 14, 2020 Share Posted April 14, 2020 (edited) The HR Endeavor coaches were on Freightliner chassis until 2000 when they changed over to a Monaco chassis some time in 2000. The procedure for setting the ride heigh was changed in the early 2000 from the H frame to the air bag , its not clear the date of the change but i think between 03 and 04 ? I know for sure the 1999 Dip and 2000 Dyn use the H frame to main frame figures for adjustment. Edited April 14, 2020 by walt2137 Link to comment Share on other sites More sharing options...
Tom Cherry Posted April 14, 2020 Share Posted April 14, 2020 You best source.... Call Josams in Orlando. Ask for Barry. He is the service manager. he has the most complete set of files on the Monaco. He will help you. I THINK that Henderson's in Grant's Pass is also the other "go to" chassis specialist in Oregon. They are also experts. They should be able to look at their files or their charts and give you the info. Others in the NW will have to correct or chime in... Good Luck... Link to comment Share on other sites More sharing options...
