1nolaguy Posted March 28 Share Posted March 28 The red light next to the electric on-off switch at the LP tank (found in the LP tank bay) is burned out. While I can rotate the switch clock wise for on and counter clock wise for off it would be nice to have the light work correctly. This light appears sealed as in there is no bulb to be replaced. Has anyone had to replace this and if so where did you get a replacement? Link to comment Share on other sites More sharing options...
Rikadoo Posted March 28 Share Posted March 28 Try Amazon Link to comment Share on other sites More sharing options...
gdroberson Posted March 28 Share Posted March 28 I replaced mine it has power but still does not work have to check out ground side have not done that yet Link to comment Share on other sites More sharing options...
cbr046 Posted March 28 Share Posted March 28 2 hours ago, gdroberson said: I replaced mine it has power but still does not work have to check out ground side have not done that yet If it's an LED light (most are now) try connecting it backwards. - bob Link to comment Share on other sites More sharing options...
1nolaguy Posted March 28 Author Share Posted March 28 Where did you order the replacement from? Ricadoo, please post the Amazon URL. I have tried several searches but am apparently searching by the wrong subject. Link to comment Share on other sites More sharing options...
gdroberson Posted March 28 Share Posted March 28 amazon NS1-79750LW round indicator light Link to comment Share on other sites More sharing options...
1nolaguy Posted March 28 Author Share Posted March 28 Found them. Thanks. Link to comment Share on other sites More sharing options...
