CLIFF918 Posted April 15, 2022 Share Posted April 15, 2022 In getting ready for our trip I found a connector that looks like it should be connected. anyone know what this is and should it be connected together? Is this some kind of test connector? both connectors have 1 white wire only 2002 Monaco Diplomat Thanks in advance Cliff Link to comment Share on other sites More sharing options...
Dr4Film Posted April 15, 2022 Share Posted April 15, 2022 Is there any black writing on the white wires at all? I have a connector in my front electrical bay that has no matching mate. Haven't had time to track it down but assuming that it was not intended to be used on this coach. Link to comment Share on other sites More sharing options...
DavidL Posted April 15, 2022 Share Posted April 15, 2022 On my Newmar, most of the wires are printed / labeled. You might pull the wire out of the harness to see if your Monaco does similar. Then find a wiring schematic as close to yours as you can find and see if you can locate what the wire is on it. Final food for thought: If it Ain't Broken, don't try to Fix it. ie: don't plug things together that you don't know the function. 1 Link to comment Share on other sites More sharing options...
CLIFF918 Posted April 15, 2022 Author Share Posted April 15, 2022 1 minute ago, DavidL said: On my Newmar, most of the wires are printed / labeled. You might pull the wire out of the harness to see if your Monaco does similar. Then find a wiring schematic as close to yours as you can find and see if you can locate what the wire is on it. Final food for thought: If it Ain't Broken, don't try to Fix it. ie: don't plug things together that you don't know the function. That's why I ask first I'm sure someone has found this in the past. Both connectors are mates and the wire is in the same pin on both halves. I will go have a closer look at the wires. Thanks Link to comment Share on other sites More sharing options...
JDCrow Posted April 15, 2022 Share Posted April 15, 2022 (edited) I’ll go out on a limb Being so close to your Transmission brain, (to me it looks like it runs right to it, and maybe trace what is the sequence for the trans brain) is there any gauges not working? You can read up on how the gear selector inside can give you various info/trouble code. For instance, when changing fluid it will tell you when the transmission has enough fluid or is low and needs more. You have to get the fluid warm as well, it will tell you to of you need to run the engine more to get the temp up so it can read the amount needed read correctly. Just a stab in the dark. Sorry I’m not up on the various wiring for your coach. Edited April 15, 2022 by JDCrow Link to comment Share on other sites More sharing options...
CLIFF918 Posted April 15, 2022 Author Share Posted April 15, 2022 OK I looked further at the wiring and you are right the wires are all marked just like an aircraft wiring harness. The two wires are marked CRUISE on/off on one and CRUSE on, on the mating connector. I am wondering now if this is the cause of my cruse not canceling when I use the brake. I have not used the cruse because of this. Cliff 1 Link to comment Share on other sites More sharing options...
OhReally Posted April 15, 2022 Share Posted April 15, 2022 Cliff, if you look around you will probably find several dozen of these unused connectors. They are there primarily for options. Don't let them worry you. 2 Link to comment Share on other sites More sharing options...
JDCrow Posted April 15, 2022 Share Posted April 15, 2022 Sweet! Link to comment Share on other sites More sharing options...
Gary 05 AMB DST Posted April 15, 2022 Share Posted April 15, 2022 Cliff, looking at the upper left corner on the second photo, that multi wire white connector, it looks like water has gotten into it and is causing corrosion? Gary 05 AMB DST Link to comment Share on other sites More sharing options...
CLIFF918 Posted April 15, 2022 Author Share Posted April 15, 2022 4 minutes ago, Gary 05 AMB DST said: Cliff, looking at the upper left corner on the second photo, that multi wire white connector, it looks like water has gotten into it and is causing corrosion? Gary 05 AMB DST No it seems that someone used some dielectric grease on it some time ago I un plugged and re set it looks ok though. Thanks Gary for noticing it 1 Link to comment Share on other sites More sharing options...
Xracer Posted April 17, 2022 Share Posted April 17, 2022 Most coaches such as Monaco will use the same wiring harness on all coaches of a particular model. As OhReally said you will find many connectors unused as they are for options that your coach doesn’t have. Link to comment Share on other sites More sharing options...
