TommyL Posted April 24, 2022 Share Posted April 24, 2022 Front AC doesn’t always drain through tubing. Sucked a string through tube, tied rag on ,pulled through all clean and clear. PS lm talking about roof AC. While outside scratching my head had wife turn AC off, water poured out of tubing like its supposed to.Sounds like unit is pulling a vacuum on condensate . Middle and rear AC drain fine out rear.Front drains out front. Any ideas thanks TommyL Sorry ,08 Camelot tag ,Dometic Douo therm heat pump units . Link to comment Share on other sites More sharing options...
cbr046 Posted April 24, 2022 Share Posted April 24, 2022 Maybe the "collector tray", connector to the hose or the hose itself is cracked? - bob Link to comment Share on other sites More sharing options...
TommyL Posted April 24, 2022 Author Share Posted April 24, 2022 Bob , the condensate fills the little plastic tray up then runs over on the roof then down the side. Turn AC off and all water runs down the tube like it should! Just doesn’t seem to drain when AC is running. Been doing this since I owned it,10 years.Thought someone may have seen the same problem before. Thanks TommyL Link to comment Share on other sites More sharing options...
hex_nut Posted April 24, 2022 Share Posted April 24, 2022 Tommy I have exactly the same problem, and I have done the same things you have to no avail. I will be monitoring this thread to see if anyone has a knowledgeable solution. It is very frustrating since the drip comes down at the front door when I am parked and level. Richard Link to comment Share on other sites More sharing options...
TommyL Posted April 25, 2022 Author Share Posted April 25, 2022 Guess I’m lucky Richard mine drips down the drivers window,ha Tommy Link to comment Share on other sites More sharing options...
trailmug Posted April 25, 2022 Share Posted April 25, 2022 (edited) I think it's a common issue.. maybe restrictive return creating a vaccum on the evap drain. Ours has done it for years, don't pull out of the driveway with the driver window down! 😂 I wonder if they (should) include a trap like you need on a downflow residential unit. Edited April 25, 2022 by trailmug Link to comment Share on other sites More sharing options...
jacwjames Posted April 25, 2022 Share Posted April 25, 2022 The drain pans are not that big and there are fairly small holes that the tubes connect to, it does not take much to plug the hole and there is no good way to clean the drip pans. Also, the condensation also collects under the evaporator and drains through holes to the drip pans. When I changed my drip pans in 2020 there was ~18 year accumulation of dirt and dead insects that seem to migrate to the drain holes. Link to comment Share on other sites More sharing options...
Happycarz Posted April 25, 2022 Share Posted April 25, 2022 The two A/C’s on my 08 Camelot have been working as designed for the last 15 years. One drains out the front tube underneath by the generator exhaust and rear drains by rear “bumper.” Link to comment Share on other sites More sharing options...
David White Posted April 25, 2022 Share Posted April 25, 2022 (edited) I’m sure you’re probably aware that even the slightest sag in a drain line will cause water buildup and overflow. I’ve opened my ceiling vent access, and secured the line to have at least a level flow. It worked for me. Good luck. Edited April 25, 2022 by David White Link to comment Share on other sites More sharing options...
Chuck B 2004 Windsor Posted April 25, 2022 Share Posted April 25, 2022 David has the correct fix. Try to work the drain line in a slight downward position. Years of road bumps and vibrations will cause the drain line to move. Link to comment Share on other sites More sharing options...
