StephenW Posted May 8, 2022 Posted May 8, 2022 (edited) While getting things ready for summer travel I checked the tires on the coach and found cracked side walls on the two Michelin tires on the tag axle. The other six tires are Toyo M 154 dated early 2018 so I went to the nearby Les Schwab to get a quote and was told it would be 2 weeks to 2 months on backorder. Luckily the tires arrived in about 3 weeks so I went this morning to get the new tires mounted and was able to get the steer tires rotated to the tag axle and the new M 144 tires on the front. Total price was $1,227 including mounting and new stems. The tech asked if the coach was air ride suspension because two fellow employees at another location were crushed while working on a bus with air suspension, unfortunately only one survived. I guess they are not used to working on these coaches, most of their work is on log trucks or semi's. I asked them to please block up the coach after lifting it, which they did. Also I found these behind the wheels Would these be Centramatics? Also found similar on drive axle. Thank you all for the information I have gotten on this forum, I would be totally lost without the guidance and sharing from others. Thank you all! BTW the fluid on the ground is rain water. Edited May 8, 2022 by StephenW spelling
Ivan K Posted May 8, 2022 Posted May 8, 2022 It looks like balance masters if they are black behind the dirt. They are also side specific to provide some airflow.
StephenW Posted May 8, 2022 Author Posted May 8, 2022 Thanks for the info, and they are black behind the dirt.
Chargerman Posted May 8, 2022 Posted May 8, 2022 I think those are just isolators to keep the aluminum wheels from contacting the steel drum
Paul J A Posted May 8, 2022 Posted May 8, 2022 I think Chargerman is correct. Had those on our 07 Executive. Looked up balance Masters; Balance Masters® Continuous Active Balancing System works by centrifugal force which precisely positions the liquid Mercury in counter-weight positions. This technology eliminates the lumping effects caused by shot filled hub mounted and tire fluid products.
Dr4Film Posted May 8, 2022 Posted May 8, 2022 (edited) Those are Balance Masters. Below is a link to a photo of various Balance Masters and yours look exactly like the one labeled MHS105 in the lower left of the photo. balancemasters_10126364.webp Edited May 8, 2022 by Dr4Film
Chargerman Posted May 8, 2022 Posted May 8, 2022 Yup. I didn’t see them at first. I was focused on the black isolator
Dr4Film Posted May 8, 2022 Posted May 8, 2022 So where is this black isolater located in the photo? I am having difficulty identifying it.
Simplysmn Posted May 9, 2022 Posted May 9, 2022 When we did tires a yr ago we used BBWHEELS.COM 1700 for 6 but I have a good friend who mounted them in the front yard.
Dr4Film Posted May 9, 2022 Posted May 9, 2022 (edited) 17 hours ago, Simplysmn said: When we did tires a yr ago we used BBWHEELS.COM 1700 for 6 but I have a good friend who mounted them in the front yard. Those same tires from BBWHEELS.com today would cost you $3,354 for 6. So much for inflation! I just paid $510 each for the M-144 tires from Josam's in Orlando. Barry has always been the least expensive, so I no longer shop around. I go straight to him. Edited May 10, 2022 by Dr4Film
