MHRookie Posted May 23, 2022 Share Posted May 23, 2022 All, I have a 2003 Monaco Dynasty 42. axle is a spicer E1460-W. can anyone help ID part info? brake pads - brake rotors - brake calipers - I’ve searched the net for 4 hours and not coming up with any info. thanks everyone, Kurt Link to comment Share on other sites More sharing options...
TW Racing Posted May 23, 2022 Share Posted May 23, 2022 Go to revrvparts.com they should have the part numbers, you can also reach them via phone. They were very helpful. Link to comment Share on other sites More sharing options...
donbouv22 Posted May 24, 2022 Share Posted May 24, 2022 I need the same thing for my ‘05 Navigator. I’ll check with out REV, too, thanks! Link to comment Share on other sites More sharing options...
MHRookie Posted May 24, 2022 Author Share Posted May 24, 2022 REV was only able to give me my axle part info.. nothing about brakes. 2003 may be too long ago.. Link to comment Share on other sites More sharing options...
Jdw12345 Posted May 24, 2022 Share Posted May 24, 2022 I’d call a heavy duty truck dealer, Peterbilt, Kenworth, ect, you have the axle number, that’s all you should need. Or just google that axle number….. jmo Link to comment Share on other sites More sharing options...
Marine Boy Posted May 24, 2022 Share Posted May 24, 2022 I just did my front brakes on my 2006 Dynasty at a professional shop. There are a possibility of 3 different rotors. The shop couldn't order them until they took it a part. When they did, the rotors had to come from CA to FL. I would not recommend to start the job until you can be without use of your bus for a few weeks, just incase you can't find parts. Link to comment Share on other sites More sharing options...
Hockeydiesel Posted May 25, 2022 Share Posted May 25, 2022 The following PN's fit an 05 Signature. Bendix ESD 225 brake system. Caliper - Haldex 790 - 94049 ( Same caliper all four positions.) Find it Parts , $1,192 plus shipping. Pads - Haldex 790 - 22012 , Jit truck parts , $175 free shipping. Front Rotor - Centric 120.86007 , Find it Parts , $276 free shipping. Rear Rotor - Webb 26741XM7T ( Monaco PN 976045 ) Iron Wing Sales , $349 free shipping. I hope this helps, Mike. Link to comment Share on other sites More sharing options...
MHRookie Posted May 25, 2022 Author Share Posted May 25, 2022 4 hours ago, Hockeydiesel said: The following PN's fit an 05 Signature. Bendix ESD 225 brake system. Caliper - Haldex 790 - 94049 ( Same caliper all four positions.) Find it Parts , $1,192 plus shipping. Pads - Haldex 790 - 22012 , Jit truck parts , $175 free shipping. Front Rotor - Centric 120.86007 , Find it Parts , $276 free shipping. Rear Rotor - Webb 26741XM7T ( Monaco PN 976045 ) Iron Wing Sales , $349 free shipping. I hope this helps, Mike. Thanks… unfortunately none of those parts cross to anything I have yet. REV/Monaco parts could only provide me the axle info.. Spicer E1460-W.. then I was able to find the numbers cast on the calipers… obsolete Meritor but have narrowed it down to: A1 or A2 - 3263M1157’s - it depends on the number stamped on the end of the shaft in the slack adjuster can…. To note (it could be L or R BUT one can be used for both. I doubt I’ll need calipers and since pads are common I’ve stopped looking). brake pads are: KIT15616/15626PM The rotor #’s are the dark horse for now. There are 3 possibilities so far. The other common theme. Things are related to ADB1560 systems, it’s just that there are some variables. Link to comment Share on other sites More sharing options...
Ivan K Posted May 25, 2022 Share Posted May 25, 2022 If you are lucky, you might still find the rotor numbers on their perimeter. Link to comment Share on other sites More sharing options...
MHRookie Posted May 25, 2022 Author Share Posted May 25, 2022 1 hour ago, Ivan K said: If you are lucky, you might still find the rotor numbers on their perimeter. That is one of the 3 potential numbers. Hopefully the shop can find them and readily get one. It is still possible to turn it but we’ll have to see Link to comment Share on other sites More sharing options...
lotosrggp1 Posted May 26, 2022 Share Posted May 26, 2022 I've heard of others finding their parts at NAPA if you bring the parts in. The problem is not all counter sales people are created equal, some know how to lookup odd part numbers and some cannot be bothered. 1 Link to comment Share on other sites More sharing options...
TXcamping Posted June 7, 2022 Share Posted June 7, 2022 (edited) All, I just replaced the front calipers and pads on my '05 Navigator. Symptom was that the coach would really jerk the wheel left on a panic stop. When I removed the calipers it was absolutely clear that the RH caliper piston was not functioning at all and the LH caliper wasn't squeezing equally. Not a hard job and I was able to complete in just about 3-4 hours taking my time. Here are the parts I used: Pads: Kit PN: HX MPD1441CV (includes pads for both sides) Vendor: Vander Haag's Calipers: Kit PN: 99B96100 (one caliper only) Vendor: BBB Industries Let me know if you have any questions! Some pics of the bad caliper, new caliper installed with pads, and pad wear side by side. I would highly recommend the BBB calipers - rebuilt but high quality kit - just like new. Stops like a Porsche now 🙂 -Mike Edited June 7, 2022 by TXcamping Link to comment Share on other sites More sharing options...
donbouv22 Posted June 7, 2022 Share Posted June 7, 2022 Mike, Thanks for the info. This is a job that needs to be performed on my ‘05 Navigator as well, but I need rotors. Do you know where I can find them & a p/n perhaps? Are all Navigators that year the same? I’ve got a 500 ISM 43PBQ. Thank you! Don Link to comment Share on other sites More sharing options...
TXcamping Posted June 7, 2022 Share Posted June 7, 2022 Don - it would be a complete assumption, but highly likely they would be the same. The rotors on mine were just fine, but the part number for the rotors is: https://www.finditparts.com/products/2537732/centric-120-dot-86007 Link to comment Share on other sites More sharing options...
Busnut Posted June 7, 2022 Share Posted June 7, 2022 MHRookie when you do find out let us know. I have the same front axle. Link to comment Share on other sites More sharing options...
Hockeydiesel Posted July 13, 2022 Share Posted July 13, 2022 Caliper part numbers 99B96100 and K022919 cross reference to Haldex 790 94049. I am pretty sure that a 05 Navigator has the same brake setup as a 05 Signature. See my post in this thread for other part numbers. Go to Find it Parts for cross reference. I hope this helps. Mike Link to comment Share on other sites More sharing options...
MHRookie Posted July 13, 2022 Author Share Posted July 13, 2022 (edited) Txcamping & Hockeydiesel, the 03’ Dynasty parts are NOT the same as what you show in pictures above. I will get the final list together for reference. What I am NOT comfortable with is that all 03’s use the same parts. It’s all going to be for reference only. If people look at ADB1560 parts this will give an idea of a starting point. Edited September 10, 2022 by MHRookie Link to comment Share on other sites More sharing options...
Brad Kruchten Posted October 17, 2022 Share Posted October 17, 2022 Where did you get the BBB Calipers? Link to comment Share on other sites More sharing options...
