Mike T Phillips Posted June 3, 2022 Share Posted June 3, 2022 I have a 2008 holiday rambler imperial with a 425 isl My hydraulic fan cooler was covered with a red fluid I assume was hydronic fluid. The Reservoir was low and fluid was coming out of the side radiator and getting all over my tow vehicle we pull the Hydraulic fan cooler off and took it to a radiator shop and he could not find any leaks does anybody have any ideas where the fluid might be coming from are going Link to comment Share on other sites More sharing options...
flyinghi Posted June 3, 2022 Share Posted June 3, 2022 Have checked the hoses ? Link to comment Share on other sites More sharing options...
Dr4Film Posted June 3, 2022 Share Posted June 3, 2022 It's best to start up the engine and crawl underneath to put some eyes on exactly where the fluid is coming from. Then you can formulate what needs to be done to fix the problem. Link to comment Share on other sites More sharing options...
KevinH Posted June 3, 2022 Share Posted June 3, 2022 Not sure if your coach is set up like ours but we have a side radiator with a side hydraulic cooler. Two separate components. I’ve had a leak in both of them. First time it was the hydraulic cooler like you had checked. The second time it was the radiator leaking transmission fluid. Link to comment Share on other sites More sharing options...
jacwjames Posted June 3, 2022 Share Posted June 3, 2022 If your hydraulic reservoir was low that isolates it to the cooling fan and steering circuit. The leak could be coming from a hose and/or the hydraulic fan motor. There have been reports of the fan motor shaft seal failing. Suggest filing the reservoir and starting the engine and crawling underneath to see where the leak is. Link to comment Share on other sites More sharing options...
Ivan K Posted June 3, 2022 Share Posted June 3, 2022 Is your hydraulic pump possibly run by a PTO off the transmission? If so, since you appear to run the same fluid in both, how's the tranny fluid level? Link to comment Share on other sites More sharing options...
Dr4Film Posted June 3, 2022 Share Posted June 3, 2022 Ivan, I would hope that his Allison is using TranSynd Transmission Fluid versus the typical red ATF fluid that is in his hydraulic system. Well, unless his hydraulic system is using yellowish hydraulic fluid. Hard to tell or even guess until he puts eyes on the problem. Link to comment Share on other sites More sharing options...
Ivan K Posted June 3, 2022 Share Posted June 3, 2022 3 minutes ago, Dr4Film said: Ivan, I would hope that his Allison is using TranSynd Transmission Fluid versus the typical red ATF fluid that is in his hydraulic system. Well, unless his hydraulic system is using yellowish hydraulic fluid. Hard to tell or even guess until he puts eyes on the problem. Yes, agree and he mention red fluid. IF the PTO pump pushed its ATF fluid into that transmission, it would be hard to distinguish between the two. Link to comment Share on other sites More sharing options...
Mike T Phillips Posted June 3, 2022 Author Share Posted June 3, 2022 At this point only the hydraulic fluid is low. The transmission fluid is checked by the panel and does not appear to be low mike Link to comment Share on other sites More sharing options...
