Wrayj1 Posted June 15, 2022 Share Posted June 15, 2022 I want to remove the 4 house batteries and 2 coach batteries to clean them as well as clean, lubricate and paint the battery tray. Is there a procedure/and or suggestions of the steps to take? Link to comment Share on other sites More sharing options...
klcdenver Posted June 15, 2022 Share Posted June 15, 2022 You should clean it with water then sand the corroded places. Then take baking soda and water to neutralize any acid. Rinse good and paint. I used flex seal paint on my battery tray and very happy with it. 1 Link to comment Share on other sites More sharing options...
pennzo Posted June 15, 2022 Share Posted June 15, 2022 I did this when we first purchased our 2000 Windsor. I made sure to take pictures of the orientation and connections. Then I took a wire brush to the tray as there some significant corrosion. I then used a black Rustoleum paint and painted the frame. Then finally I lubed the tray slide, reinstalled the batteries lubricated the terminals and 'Voila!'. Link to comment Share on other sites More sharing options...
Cubflyer Posted June 15, 2022 Share Posted June 15, 2022 I just changed out my house batteries (4ea- 6vdc batteries).... when I got them out I found that all the batteries... house and chassis were sitting on one big plastic tray. Since I was not really on a mission to rebuild the battery compartment and hold downs (maybe next winter) I just washed out the plastic tray, cleaned the walls as best I could and shot the walls with black spray paint. My point is, that to clean and paint the metal floor, all batteries, battery hold downs and the plastic tray must be removed (at least on my '03 HR Endeavor). I wish I had batteries mounted on a sliding tray.... 68lbs each lifted into an opening was not fun! Link to comment Share on other sites More sharing options...
Wrayj1 Posted June 15, 2022 Author Share Posted June 15, 2022 Mine is a sliding tray. Are special precautions before removing the batteries? Link to comment Share on other sites More sharing options...
Tom Wallis Posted June 15, 2022 Share Posted June 15, 2022 Turn of both chassis and coach shut off switches. Unplug your shore power. Disconnect the ground cable at each battery first and then the positive cables. Then remove the batteries. Reverse the order to install them. Link to comment Share on other sites More sharing options...
Jim McFarland Posted June 15, 2022 Share Posted June 15, 2022 It was mentioned before, but be sure you take pictures of the batteries and most especially the battery cables. You must re-cable them as they currently are. Good luck and wear protective gear around the acid. Be safe Jim 09 Monaco Knight Link to comment Share on other sites More sharing options...
Wrayj1 Posted June 15, 2022 Author Share Posted June 15, 2022 Thanks,I think I'm ready to do it. Link to comment Share on other sites More sharing options...
bklaes Posted June 15, 2022 Share Posted June 15, 2022 I followed all the good advice above. Plus I used POR (Paint Over Rust) paint and still very pleased 5 years later.. Link to comment Share on other sites More sharing options...
Notn2bars Posted June 15, 2022 Share Posted June 15, 2022 Ditto on the great advice above. Unfortunately one of the battery trays in our Dynasty was beyond repair, so we rebuilt it. When finished coated both trays with Eternakote. As stated, make certain you take pics of all the wiring before you start. Boiling water does a great job of cleaninig any corrosion. Found it works better thank coke or baking soda. The hotter the water the better. God bless, Ed & Sylvia Link to comment Share on other sites More sharing options...
det944 Posted June 16, 2022 Share Posted June 16, 2022 I labeled all wires an connection points, removed, cleaned batteries, unbolted the 3 trays, scraped off all loose paint, treated bare metal with por 15 metal prep and painted with por 15 black gloss black rust treatment paint. All of the above electrical precautions and Also covered solar panel to prevent stray charging voltages. Good project! Link to comment Share on other sites More sharing options...
Wrayj1 Posted June 16, 2022 Author Share Posted June 16, 2022 Thanks to all who provided info, all is appreciated. Link to comment Share on other sites More sharing options...
Steven P Posted June 19, 2022 Share Posted June 19, 2022 I did mine. Was changing from 2 12V house batteries to 4 6V batts. I took pics, but didn't really matter for the house batteries since I was changing them anyway. Took out the tray, cleaned it well. I used a rust remover called Ospho. Then repainted w spray truck bedliner from Ace. Put it back in when dry and have been happy since. Link to comment Share on other sites More sharing options...
