jgraves912 Posted September 7, 2022 Share Posted September 7, 2022 I have 2001 Monaco Signature trying to locate the dash expansion valve. I know where it’s supposed to be looked all around where the lines go back into the coach. I am wondering if it’s behind the panel on the inside by steps if so how do you remove panel Link to comment Share on other sites More sharing options...
vito.a Posted September 7, 2022 Share Posted September 7, 2022 (edited) Mine is accessed from inside the generator compartment. It has a lot of the black putty covering it. Edited September 7, 2022 by vito.a Link to comment Share on other sites More sharing options...
jgraves912 Posted May 15, 2023 Author Share Posted May 15, 2023 Okay I can’t believe no one has had to change expansion valve in 2001 Monaco Signature. I went up where generator is followed the lines the go inside can’t get to them from generator compartment. I need to take the cover off inside above stairs but can’t figure out how to get it off without tearing it up. Anyone please Link to comment Share on other sites More sharing options...
Ivan K Posted May 16, 2023 Share Posted May 16, 2023 Quite painful in our 2000, behind the one piece dash. Link to comment Share on other sites More sharing options...
jgraves912 Posted May 16, 2023 Author Share Posted May 16, 2023 How did you get to it with out tearing your dash up Link to comment Share on other sites More sharing options...
Ivan K Posted May 16, 2023 Share Posted May 16, 2023 4 hours ago, jgraves912 said: How did you get to it with out tearing your dash up Very carefully 🙂 If yours is the same, remove the front door trim, the step handle, screws holding the dash to the floor inside center floor vent and passenger side to firewall. Some more screws by the windshield and defrost vents and maybe some more that I don't remember. Then lift the passenger corner as pictured. Good luck! Link to comment Share on other sites More sharing options...
jgraves912 Posted May 17, 2023 Author Share Posted May 17, 2023 Do you happen to know part number of the expansion valve finally got to it but know one can tell me the part number at O Riely auto parts Link to comment Share on other sites More sharing options...
Ivan K Posted May 17, 2023 Share Posted May 17, 2023 I cross-referenced it to the last part number in Eaton lineup, 12-2012a. Google got hits for it. it. Link to comment Share on other sites More sharing options...
Gweedo Posted May 17, 2023 Share Posted May 17, 2023 What are the signs that it is bad? Link to comment Share on other sites More sharing options...
Gary Cole Posted May 17, 2023 Share Posted May 17, 2023 4 hours ago, Gweedo said: What are the signs that it is bad? I was wondering the same. If it failed at the extreme of open or closed then it would be detectable because you would have to much or no differential pressure. I never have however there is a bench method of testing to verify that the valve is moving. A valve which worked sometimes or out of range would be another matter. You aren't going to know until you have gone thru the entire process of charging the system and then discover there is a problem. I'm thinking now that it might be good practice to just replace the valve on older systems. Maybe Ivan will tell us why he replaced his. Link to comment Share on other sites More sharing options...
jgraves912 Posted May 17, 2023 Author Share Posted May 17, 2023 There is no pressure differential cannot get the Freon to go in Link to comment Share on other sites More sharing options...
Ivan K Posted May 17, 2023 Share Posted May 17, 2023 I replaced mine because it was leaking at one of the ports and I saw the oil seeping through the carpet. It held pressure and worked for couple of days before I found it. The system wasn't operational when we bought it. Link to comment Share on other sites More sharing options...
Gweedo Posted May 18, 2023 Share Posted May 18, 2023 Okay gotcha, I had my chassis AC unit replaced 5-years ago, last year I had to add freon, took a little while but it got cold. I'll see how it is next month. They didn't want to replace the long AC lines, but everything else was. Probably have a slight leak somewhere. So is it safe to assume if the above mentioned valve is replaced, the system needs to be evacuated and recharged? Thanks for the info. Link to comment Share on other sites More sharing options...
Ivan K Posted May 18, 2023 Share Posted May 18, 2023 Yes. Evacuated, vacuumed and recharged. Link to comment Share on other sites More sharing options...
