Stephen Walsh Posted March 12, 2023 Share Posted March 12, 2023 We are deciding on how to go about hooking up a toad and also our electric bikes(2) considering having our mechanic/welder/fabricator build a receiver on the front to carry them since I couldn’t find one specifically for this model Link to comment Share on other sites More sharing options...
cbr046 Posted March 12, 2023 Share Posted March 12, 2023 Can you put a bike rack on the toad? - bob Link to comment Share on other sites More sharing options...
Stephen Walsh Posted March 12, 2023 Author Share Posted March 12, 2023 23 minutes ago, cbr046 said: Can you put a bike rack on the toad? - bob 24 minutes ago, cbr046 said: Can you put a bike rack on the toad? - bob Thinking of a car dolly maybe a double receiver hitch? Link to comment Share on other sites More sharing options...
Rick A Posted March 12, 2023 Share Posted March 12, 2023 I have a bike rack on my toad and it’s great because when you want to visit places, the bikes are right there if you need them. Link to comment Share on other sites More sharing options...
Dr4Film Posted March 12, 2023 Share Posted March 12, 2023 My bike rack goes on the back of our car when needed. No need to mess with any bike rack located between the two vehicles plus with a generator slide on the front of the coach eliminates having anything on the front of our Dynasty. Link to comment Share on other sites More sharing options...
jacwjames Posted March 12, 2023 Share Posted March 12, 2023 I had a Class C that I had a receiver hitch mounted on the front. Made of out of 4X6 heavy wall tubing. This was welded between the two chassis rails. The carryier we used in it was mostly to carry heavy XPens my wife had for the dogs. The carrier was made of 2" tubing with an angled brace to help carry the weight. I worked good but quite a bit of weight with and without the Xpens. So I found a video of a 2008 Caymen and it did show the generator in the front and this was mounted between the two main rails of the chassis. So you do have enough structure but whatever you do must not interfere with the support of the generator AND allow for the generator be removed for service. Not sure what Ebikes weight but just have to make it heavy enough to carry and recognize the dynamics of the weight as you are bouncing down the road. Link to comment Share on other sites More sharing options...
Stephen Walsh Posted March 13, 2023 Author Share Posted March 13, 2023 That’s a great point i will not mess with the generator area thank you Link to comment Share on other sites More sharing options...
cbr046 Posted March 13, 2023 Share Posted March 13, 2023 Most hub drive ebikes are in the 70 lb range, without the battery - bob Link to comment Share on other sites More sharing options...
Chuck B 2004 Windsor Posted March 13, 2023 Share Posted March 13, 2023 I would NOT mount anything on the front of my coach. If you hit anything, you would be sorry you did. Chuck B 2004 Windsor 1 Link to comment Share on other sites More sharing options...
96 EVO Posted March 14, 2023 Share Posted March 14, 2023 1 hour ago, Chuck B 2004 Windsor said: I would NOT mount anything on the front of my coach. If you hit anything, you would be sorry you did. Chuck B 2004 Windsor Chuck, I think you'll be sorry if you hit something in front of you whether you have something mounted there or not 😁! Link to comment Share on other sites More sharing options...
Stephen Walsh Posted March 14, 2023 Author Share Posted March 14, 2023 You are correct thank you Link to comment Share on other sites More sharing options...
Chuck B 2004 Windsor Posted March 14, 2023 Share Posted March 14, 2023 The less you have mounted on the front of your coach, the less damage you have if you hit something. Chuck B 2004 Windsor Link to comment Share on other sites More sharing options...
Stephen Walsh Posted March 14, 2023 Author Share Posted March 14, 2023 True thank you Link to comment Share on other sites More sharing options...
daveyjo Posted March 15, 2023 Share Posted March 15, 2023 I put a 1" or so pressure treated wood spacer on top of my coach's 2 inch hitch and then put a 1-1/8" bike rack hitch on top of that, and secured it with 2 big U-bolts. That gave me enough room to comfortably hook up my tow dolly underneath the bike rack. Been doing it that way for two coaches and 20 years with no problems. 2 bikes and car on tow dolly. My bikes are not e-bikes, but I think I want to get two e-bikes which makes me wonder if my current rig would be adequate for the heavier load. I think my current bikes each weigh about 40 lbs. Any feedback? Link to comment Share on other sites More sharing options...
Stephen Walsh Posted March 15, 2023 Author Share Posted March 15, 2023 Our bikes are 75lbs each Link to comment Share on other sites More sharing options...
Stephen Walsh Posted March 20, 2023 Author Share Posted March 20, 2023 Can you send a photo? Link to comment Share on other sites More sharing options...
