RoadTripper2084 Posted April 23, 2023 Share Posted April 23, 2023 On my '97 Dynasty I am looking for a couple of replacement parts, hoping someone here will know where to look. My right-side ladder bracket is a rusted mess, any idea where I might find ones like it to replace? Barring that, are their similar brackets I could substitute, maybe ones that are easier to unhook to lift the ladder out of the way? Also, one of the tail light bulb holders is corroded up, can these be sourced separately from the entire assembly? NAPA? Link to comment Share on other sites More sharing options...
DavidL Posted April 23, 2023 Share Posted April 23, 2023 Ladder bracket: Take it off, wire wheel it clean, paint it black and put it back on. Light bulb: Any auto parts store. Standard stuff. 1 Link to comment Share on other sites More sharing options...
Tom Cherry Posted April 23, 2023 Share Posted April 23, 2023 15 minutes ago, DavidL said: Ladder bracket: Take it off, wire wheel it clean, paint it black and put it back on. Light bulb: Any auto parts store. Standard stuff. My advice also. I’ll go a step further.. clean the brackets. Maybe a little Naval Jelly or a cleaner that leaves a phosphate coating. Rustoleum Flat black “primer & paint” spray. I’d crawl under and if the screws are tapping or drill points, I’d switch to a SS bolt and nut and some SS washers on the back side or a SS plate or such for added strength. Go one size larger. Drill out the 2 holes in the brackets first and then paint. The pins are standard hitch pins. Amazon or a TractorSupply has them. I have a metallurgist buddy that would get some SS Flat sheet, and use a Manila file folder and make a template, then use a side grinder with a cutoff wheel and make the straight cuts and then a grinder for the curved tips and a square tubing mandrel and 2 pound sledge and bend and form them for an exact match. He like to do such….so that is an option….but cleaning and painting and spend the time saved and working on the rear side for a more robust attachment would be my choice… 1 1 Link to comment Share on other sites More sharing options...
waterskier_1 Posted April 23, 2023 Share Posted April 23, 2023 I had a 97 Dynasty. Those light sockets are all going to be problematic after 25+ years. I got a bunch (I think packs of 5) off Amazon. The ladder bracket looked just like mine as far as rust goes. I believe it's cosmetic. But, that is a simply bracket any fab shop could make. I doubt you'll find a source for new brackets, and any bracket off a wrecked coach would likely be in the same condition. -Rick N. Currently in Deming, NM 1 Link to comment Share on other sites More sharing options...
StephenW Posted April 23, 2023 Share Posted April 23, 2023 I have the same issue on the ladder brackets on my '01 Dynasty. I have wondered where to look for new brackets, now I will try to refurbish the existing ones. Thank you DavidL and Tom Cherry! Link to comment Share on other sites More sharing options...
DavidL Posted April 23, 2023 Share Posted April 23, 2023 Quick google search https://www.amazon.com/Stromberg-Carlson-Universal-Exterior-Mounting/dp/B072N8WLQM/ref=sr_1_53?crid=19TZ3N1R0NRWJ&keywords=rv+ladder+parts+bracket&qid=1682262893&sprefix=rv+ladder+parts+bracke%2Caps%2C110&sr=8-53 But the original brackets reuse the old holes. Not necessarily true for any new bracket that isn't exact. 1 Link to comment Share on other sites More sharing options...
Ivan K Posted April 23, 2023 Share Posted April 23, 2023 I simply sandblasted and powder coated the brackets years ago. But I think it would also be common for the holes in ladder tubes to get elongated with vibrations and I did not like the flimsiness. A piece of correctly sized tube epoxied through the holes fixed that permanently. 1 Link to comment Share on other sites More sharing options...
DavidL Posted April 23, 2023 Share Posted April 23, 2023 2 minutes ago, Ivan K said: I simply sandblasted and powder coated the brackets years ago. But I think it would also be common for the holes in ladder tubes to get elongated with vibrations and I did not like the flimsiness. A piece of correctly sized tube epoxied through the holes fixed that permanently. Nice Mod. Link to comment Share on other sites More sharing options...
StephenW Posted April 23, 2023 Share Posted April 23, 2023 I like the idea of refurbishing the existing brackets as the holes in the coach will line up. Ivan K, nicely done! Thanks for the ideas. Link to comment Share on other sites More sharing options...
RoadTripper2084 Posted April 24, 2023 Author Share Posted April 24, 2023 8 hours ago, Ivan K said: I simply sandblasted and powder coated the brackets years ago. But I think it would also be common for the holes in ladder tubes to get elongated with vibrations and I did not like the flimsiness. A piece of correctly sized tube epoxied through the holes fixed that permanently. Nicely done. Link to comment Share on other sites More sharing options...
Bruce S Posted April 24, 2023 Share Posted April 24, 2023 I found a bit of stainless that I shaped into the correct size, drilled the proper holes and have used these for many years. No more rust or need to paint and looks OEM. 2 Link to comment Share on other sites More sharing options...
RoadTripper2084 Posted April 24, 2023 Author Share Posted April 24, 2023 1 hour ago, Bruce S said: I found a bit of stainless that I shaped into the correct size, drilled the proper holes and have used these for many years. No more rust or need to paint and looks OEM. I was thinking the same thing, it's a pretty basic shape and can be easily bent once cut. What did you use to cut the stainless? Link to comment Share on other sites More sharing options...
Bruce S Posted April 24, 2023 Share Posted April 24, 2023 To be honest I don't quite remember what I used but I believe it was a pair of snips... The material is probably about 10 gauge thick... Link to comment Share on other sites More sharing options...
Paul J A Posted April 24, 2023 Share Posted April 24, 2023 On 4/23/2023 at 10:15 AM, DavidL said: Quick google search https://www.amazon.com/Stromberg-Carlson-Universal-Exterior-Mounting/dp/B072N8WLQM/ref=sr_1_53?crid=19TZ3N1R0NRWJ&keywords=rv+ladder+parts+bracket&qid=1682262893&sprefix=rv+ladder+parts+bracke%2Caps%2C110&sr=8-53 But the original brackets reuse the old holes. Not necessarily true for any new bracket that isn't exact. YEP! https://www.rv.net/obsolete/index.cfm?action=group&groupid=1 findmyrvparts.com rvparts.visonerv.com anyrvparts.com finditparts.com https://www.nwrvsupply.com/ Link to comment Share on other sites More sharing options...
