hex_nut Posted April 26, 2023 Share Posted April 26, 2023 Help! A few days ago someone posted a recommendation to use a small FM transmitter plugged into the TV headphone port to get access to the amp and use the on board speakers for the TV. I made a mental note of the brand of the transmitter and then had a senior moment and lost the note. I have searched for the original post and have not been able to find it. Can someone point me in the right direction. Thanks. Richard Link to comment Share on other sites More sharing options...
Solution Guest Ray Davis Posted April 26, 2023 Solution Share Posted April 26, 2023 This is not the thread you want, but quite a few are on Amazon. Here is a link to one that might work. https://www.amazon.com/Scosche-FMT4R-Transmitter-Frequency-Selections/dp/B004NEUK86/ref=sr_1_6?crid=IJR28RPT8HNV&keywords=fm%2Btransmitter&qid=1682549617&sprefix=fm%2B%2Caps%2C1007&sr=8-6&th=1 Link to comment Share on other sites More sharing options...
hex_nut Posted April 26, 2023 Author Share Posted April 26, 2023 Thanks Ray! That is the one that was recommended. Link to comment Share on other sites More sharing options...
Donflem Posted April 27, 2023 Share Posted April 27, 2023 Wait what? There’s a way to listen to my tv through my radio speakers? Would someone please tell me how to do this that’s a great idea? Don Link to comment Share on other sites More sharing options...
Guest Ray Davis Posted April 27, 2023 Share Posted April 27, 2023 8 hours ago, Donflem said: Wait what? There’s a way to listen to my tv through my radio speakers? Would someone please tell me how to do this that’s a great idea? Don Yep, the little device above should do it. Many TVs have a place to plug in headphones, the transmitter plugs into the headphone receptacle and you set the FM radio and the transmitter to a blank spot on the dial. Volume can probably be controlled by the TV or radio. The transmitter above is a cheap one but should work fine, however, there may be others on Amazon or eBay better suited for a more permanent installation. Link to comment Share on other sites More sharing options...
96 EVO Posted April 27, 2023 Share Posted April 27, 2023 (edited) 1 hour ago, Ray Davis said: Many TVs have a place to plug in headphones, No kidding 🤔. Can't say I recall every seeing one. {edit} Well, after looking, at least two of my house TV's, do indeed have headphone ports on the side! Edited April 27, 2023 by 96 EVO Link to comment Share on other sites More sharing options...
Ivan K Posted April 27, 2023 Share Posted April 27, 2023 I use that output to connect to surround sound on the inside and for a Bluetooth transmitter on the outside. Not all TVs have that anymore. Link to comment Share on other sites More sharing options...
hex_nut Posted April 27, 2023 Author Share Posted April 27, 2023 I ordered that battery powered FM transmitter. It is cheap and I want to see how it works. I searched to see if I could find one that is 110 volt AC powered so I could plug it in with the TV and not have to deal with replacing batteries. Alas, I was not able to locate one. If anyone knows of one that is permanently powered, please share with the rest of us. Thanks. Richard Link to comment Share on other sites More sharing options...
dandick66 Posted April 29, 2023 Share Posted April 29, 2023 On 4/27/2023 at 1:17 PM, hex_nut said: I ordered that battery powered FM transmitter. It is cheap and I want to see how it works. I searched to see if I could find one that is 110 volt AC powered so I could plug it in with the TV and not have to deal with replacing batteries. Alas, I was not able to locate one. If anyone knows of one that is permanently powered, please share with the rest of us. Thanks. Richard Here’s a AAA battery eliminator on Amazon. https://www.amazon.com/Lenink-Battery-Supply-Adapter-Replace/dp/B0873Y5MQ5/ref=sr_1_2_sspa?hvadid=616990830620&hvdev=c&hvlocphy=1027026&hvnetw=g&hvqmt=e&hvrand=11514644225939710045&hvtargid=kwd-306177200139&hydadcr=24632_13611814&keywords=aaa%2Bbattery%2Beliminator&qid=1682728601&sr=8-2-spons&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUFIQ1oyWVU3VEFHU0QmZW5jcnlwdGVkSWQ9QTAxMjkzMjhIMEo0SExXUEZJODQmZW5jcnlwdGVkQWRJZD1BMDQ5OTMzNTFZNkJWTU9QQ0NONFYmd2lkZ2V0TmFtZT1zcF9hdGYmYWN0aW9uPWNsaWNrUmVkaXJlY3QmZG9Ob3RMb2dDbGljaz10cnVl&th=1 You could probably pick up a 3 volt DC transformer and make one yourself a lot cheaper, but this is clean and easy. You might want to check eBay, too. Link to comment Share on other sites More sharing options...
Agpopp Posted April 29, 2023 Share Posted April 29, 2023 I'd like to add I did this on my Neptune right away when I got a few months back by running a 3.5mm aux cord from the TV, down the back of the A pillar trim, under the dash and to the radio. Works great. While I was at it I also removed the TV kill switch wire so my passengers can watch some tube or movies while we drive. 1 Link to comment Share on other sites More sharing options...
