colorodan Posted May 29, 2023 Share Posted May 29, 2023 My right Velvac rear view, P/S mirror arm. is loose and excess to the tightening screws or nut is not excessible. Wondering if any Monaco owners have had this problem with their mirrors? If so, how were you able to tighten the arm? Link to comment Share on other sites More sharing options...
Dr4Film Posted May 29, 2023 Share Posted May 29, 2023 The Velvac mirrors on my Windsor were attached using LAG screws. I filed the holes with LOTS of toothpicks then used YELLOW gas Teflon tape to wrap around the lag screw before reattaching them. They tighten right up tight but don't OVER-tighten them otherwise you may have to fill in the holes with epoxy and start from scratch. Link to comment Share on other sites More sharing options...
cbr046 Posted May 29, 2023 Share Posted May 29, 2023 My mirrors are tight but the glass will bounce around a bit on choppy surfaces. Is there an easy fix for that? - bob Link to comment Share on other sites More sharing options...
Gary 05 AMB DST Posted May 29, 2023 Share Posted May 29, 2023 Bob, the adhesive for the mirror mounting plate may be coming apart. My convex mirror fell off. Fortunately I had stopped to check why it was moving and when I touched it, it came off. Gary 05 AMB DST Link to comment Share on other sites More sharing options...
Martinvz Posted May 29, 2023 Share Posted May 29, 2023 William, no offense to you or the others that had responded but the issue is not clear. Could you provide additional details to explain which part is loose? A photo will also be very useful. Link to comment Share on other sites More sharing options...
Ivylog Posted May 29, 2023 Share Posted May 29, 2023 Arm is loose is clear to me. On the bottom of the mount there’s a removable plug for the bolt that holds the arm on. Put a longer bolt in and hit with a hammer to loosen the arm. Once the arm is removed the plastic cover will come off exposing the 4 lag screws. Good luck just tighten them…rarely lasts. Link to comment Share on other sites More sharing options...
Dr4Film Posted May 29, 2023 Share Posted May 29, 2023 4 minutes ago, Ivylog said: Arm is loose is clear to me. On the bottom of the mount there’s a removable plug for the bolt that holds the arm on. Put a longer bolt in and hit with a hammer to loosen the arm. Once the arm is removed the plastic cover will come off exposing the 4 lag screws. Good luck just tighten them…rarely lasts. Velvac Mirrors do NOT have plastic base covers. Only mirrors from Ramco have the plastic covers.Velvac Mirrors have lag screw covers which have to be removed to expose the head of the lag screw. The method you described above works only for Ramco Mirrors. Link to comment Share on other sites More sharing options...
Ivylog Posted May 29, 2023 Share Posted May 29, 2023 3 hours ago, Dr4Film said: Velvac Mirrors do NOT have plastic base covers. Only mirrors from Ramco have the plastic covers.Velvac Mirrors have lag screw covers which have to be removed to expose the head of the lag screw. The method you described above works only for Ramco Mirrors. If you say so? Link to comment Share on other sites More sharing options...
Dr4Film Posted May 29, 2023 Share Posted May 29, 2023 I stand corrected! I haven't seen a Monaco with that type of Velvac base but there is always a first time. Maybe only found on the lower end models. Link to comment Share on other sites More sharing options...
1nolaguy Posted May 30, 2023 Share Posted May 30, 2023 Our 2005 Safari Cheetah has that type of mirror arm. Bolt through the bottom holds arm on. Removing will allow the chrome cap on base to be removed gaining access to lag screws. When I discovered a problem the lag screws had already wallowed out the screw holes (mirror fell off while driving). Chose to drill out holes and replace lags with screws, nuts and fender washer (required pulling the dash out to access the inside. Note: The other mirror also needs to be done as it is starting to show movement. Unfortunately the mirror arm has developed corrosion in the socket of the base. Any suggestions on how to separate would be appreciated. Link to comment Share on other sites More sharing options...
