ktloah Posted June 17, 2023 Share Posted June 17, 2023 Good evening, my 04 dynasty with the ISL 400 has the " warning" light displayed on the dash. I checked all fluid levels except transmission and all is good. Transmission will be checked when I get home. Anyone have this happen? Thanks Link to comment Share on other sites More sharing options...
BradHend Posted June 17, 2023 Share Posted June 17, 2023 I’ve had that light come on for various issues. Coolant temp was one, other was an exhaust manifold leak causing the turbo to perform out of spec. Is the engine going into reduced power when this happens? Id be checking for codes. Link to comment Share on other sites More sharing options...
Hancoman Posted June 18, 2023 Share Posted June 18, 2023 Mine has been on for 2 years 2 Link to comment Share on other sites More sharing options...
ktloah Posted June 18, 2023 Author Share Posted June 18, 2023 No, coach runs awesome...wondering if it's a bad sensor Link to comment Share on other sites More sharing options...
96 EVO Posted June 18, 2023 Share Posted June 18, 2023 2 hours ago, ktloah said: Good evening, my 04 dynasty with the ISL 400 has the " warning" light displayed on the dash. I checked all fluid levels except transmission and all is good. Transmission will be checked when I get home. Anyone have this happen? Thanks Did you check for water in your water separating fuel filter? 1 Link to comment Share on other sites More sharing options...
Guest Ray Davis Posted June 18, 2023 Share Posted June 18, 2023 Interesting because mine came on yesterday. I was rolling along at 65 mph when the engine died, every red light came, then just as quickly the engine picked back up but the warning light stayed on. When I found a place to stop I kill the engine & restarted, but the warning light did not come back on. Relief doesn't describe what I felt. I believe I've had this happen 3 times over 12 yrs of owning. Believe me, it will give you a heart attack especially since I was on a 2 lane in Arkansas with no shoulder & it was raining. Link to comment Share on other sites More sharing options...
Keamyinc Posted June 18, 2023 Share Posted June 18, 2023 I had my come on too with no fluid level issues but seemed to come on more when the weather was hotter and the engine was working harder climbing hills. Much less frequent it just would come. My service manager said it my just be the sensor. Link to comment Share on other sites More sharing options...
Gary 05 AMB DST Posted June 18, 2023 Share Posted June 18, 2023 4 hours ago, ktloah said: Good evening, my 04 dynasty with the ISL 400 has the " warning" light displayed on the dash. I checked all fluid levels except transmission and all is good. Transmission will be checked when I get home. Anyone have this happen? Thanks Ron, I think that the transmission has an electronic way to check the fluid level using the push buttons. Check your owner's manual. Gary 05 AMB DST 1 Link to comment Share on other sites More sharing options...
ktloah Posted June 18, 2023 Author Share Posted June 18, 2023 Ok, I will check that as soon as I return home next week...thank you! Link to comment Share on other sites More sharing options...
Tom Cherry Posted June 18, 2023 Share Posted June 18, 2023 8 hours ago, Gary 05 AMB DST said: Ron, I think that the transmission has an electronic way to check the fluid level using the push buttons. Check your owner's manual. Gary 05 AMB DST Gary is probably correct. You should have a separate Allison transmission manual. I don’t know the year that they went electronic. If you don’t have the original one that was supplied with the MH, Google it. The 2004 sales brochure is not online and the 2003 did not call out the model number. In 2005, it was the MH3000 which many of us have. The pictures in the Allison are easy to follow. Make sure you have driven at least an hour and the tranny is warm to hot. You also must park and level the MH to get an accurate reading. It is simple….just a few steps. It would be good, as a confirmation, to drive another 10 or more miles and repeat. Link to comment Share on other sites More sharing options...
Gary 05 AMB DST Posted June 18, 2023 Share Posted June 18, 2023 Tom, my 05 Ambassador was the first year that used the 8 air bag platform. It was carried over from the 04 Endeavor, My chassis is the same as an Endeavor but with the 333hp ISC. I was told this by the manager of the Roadmaster frame assembly plant in Elkhart. Gary 05 AMB DST Link to comment Share on other sites More sharing options...
Tom Cherry Posted June 18, 2023 Share Posted June 18, 2023 9 minutes ago, Gary 05 AMB DST said: Tom, my 05 Ambassador was the first year that used the 8 air bag platform. It was carried over from the 04 Endeavor, My chassis is the same as an Endeavor but with the 333hp ISC. I was told this by the manager of the Roadmaster frame assembly plant in Elkhart. Gary 05 AMB DST I pulled the 04 Endeavor brochure. We basically have the same chassis. It is the MH3000. The OP has the Dynasty which is basically an Imperial. For whatever reason, there is NOT a 2004 Imperial brochure. But, odds are…really high that the Dynasty the OP has is also the MH3000 and I would be surprised if it wasn’t the “electronic” level check, Hope he follows through and tries the procedure and lets us know….. Link to comment Share on other sites More sharing options...
96 EVO Posted June 18, 2023 Share Posted June 18, 2023 Your Dynasty likely has a separate warning lamp on the dash for transmission problems. 1 Link to comment Share on other sites More sharing options...
ktloah Posted June 18, 2023 Author Share Posted June 18, 2023 Ok, so I have determined the oil in transmission is A-ok. All fluid levels are A-ok. 1 Link to comment Share on other sites More sharing options...
96 EVO Posted June 18, 2023 Share Posted June 18, 2023 You will likely need a code reader. 1 Link to comment Share on other sites More sharing options...
ktloah Posted June 18, 2023 Author Share Posted June 18, 2023 Scan tool.is ordered, thanks, I'll let you all know when I find out! 2 Link to comment Share on other sites More sharing options...
dl_racing427 Posted June 19, 2023 Share Posted June 19, 2023 On 6/17/2023 at 11:21 PM, Gary 05 AMB DST said: Ron, I think that the transmission has an electronic way to check the fluid level using the push buttons. Check your owner's manual. Gary 05 AMB DST For reference, my 1993 Dynasty has the MD3060 tranny. It does not have the electronic fluid level sensor, but with the tilt-up bed it's easy to access the dipstick. Link to comment Share on other sites More sharing options...
Jeff sams Posted June 19, 2023 Share Posted June 19, 2023 had the same issue was brake pressure switch Link to comment Share on other sites More sharing options...
MHRookie Posted June 19, 2023 Share Posted June 19, 2023 Here is the Allison in vehicle check process. Hope you find the answer. Link to comment Share on other sites More sharing options...
ktloah Posted July 1, 2023 Author Share Posted July 1, 2023 So I got the scan tool, and popped a code for #11 knock sensor...so it's got an appointment at a certified cummins shop....I'll let u know when I do....thanks again everyone... Link to comment Share on other sites More sharing options...
