gjh2916 Posted June 22, 2023 Share Posted June 22, 2023 Pulled motorhome out of garage after setting for a month. Everything was okay last time I used it. My problem now is when the HWH panel is in the travel mode the front of the coach drops and rides like a lumber wagon. I can stop put in neutral, apply parking brake, and turn on leveling button raise front of coach back up. As long as it is in leveling mode the front says up. When I release parking brake and put into gear it goes into travel mode and with in 4-5 minutes front of coach goes all the way down. My air pressure gage is still reading 125 lbs all the time. Does anyone know where I should start looking for the problem? Link to comment Share on other sites More sharing options...
Solution Doug and Nicki Posted June 22, 2023 Solution Share Posted June 22, 2023 There is a single ride height valve that handles the front end and two on the rear. I ran into this on the rear of my dynasty. The ride height valve is either defective or the rod has come out of the holder. 3 1 Link to comment Share on other sites More sharing options...
Ivan K Posted June 22, 2023 Share Posted June 22, 2023 (edited) Look at about center of the axle for a vertical ride hight rod between axle and ride high valve. Could be broken or slipped off on either of its side. That would be the first thing for me. I see Dough already said that... Edited June 22, 2023 by Ivan K 3 1 Link to comment Share on other sites More sharing options...
gjh2916 Posted June 22, 2023 Author Share Posted June 22, 2023 Thanks guys it's going to be a simple fix if I can get a new rubber gromet that the rod goes into at a truck parts store. One broke and the other one is almost broke. Think I going to replace the ones on the rear also why am at it 2 Link to comment Share on other sites More sharing options...
Ivan K Posted June 23, 2023 Share Posted June 23, 2023 I got my spare at napa. Had to buy a complete rod since they don't/did not sell the ends separately, about $20, cut to length when needed. 1 Link to comment Share on other sites More sharing options...
timaz996 Posted June 23, 2023 Share Posted June 23, 2023 3 hours ago, gjh2916 said: Thanks guys it's going to be a simple fix if I can get a new rubber gromet that the rod goes into at a truck parts store. One broke and the other one is almost broke. Think I going to replace the ones on the rear also why am at it Yay, another easy fix from the forum. 1 Link to comment Share on other sites More sharing options...
veraken Posted June 23, 2023 Share Posted June 23, 2023 Had the same problem. Replaced mine with this. Less of a chance of the rubber grommet failing https://www.napaonline.com/en/p/TWDAC103?impressionRank=1 2 Link to comment Share on other sites More sharing options...
