Owen Poole Posted August 14, 2023 Share Posted August 14, 2023 tips on removing indoor paneling in 2008 Monaco Diplomat SKQ Link to comment Share on other sites More sharing options...
vito.a Posted August 14, 2023 Share Posted August 14, 2023 The interior woodwork is held together with square drive screws. You'll need both a short and a long square drive bit and lots of patience. Some of the screws are well hidden. Good luck! Link to comment Share on other sites More sharing options...
Owen Poole Posted August 14, 2023 Author Share Posted August 14, 2023 It looks like where the two pieces meet they stick in a plastic molding, is this connected to steel studs and the paneling slides out. Haven’t pulled crown molding down yet, possibly screws behind it, found none at bottom, thanks for all the help Link to comment Share on other sites More sharing options...
MyronTruex Posted August 15, 2023 Share Posted August 15, 2023 (edited) Post a picture of what you are trying to dissasemble. I have an Endeavor skq 2008. Sister ships. There is not a lot that I have not taken apart. What is the nature of the problem? There are hidden nails in places. Covered in putty and color matched. Edited August 15, 2023 by myrontruex Link to comment Share on other sites More sharing options...
Owen Poole Posted August 15, 2023 Author Share Posted August 15, 2023 Had a leak at beltline and window, bottom part bad Link to comment Share on other sites More sharing options...
LakeBob Posted August 16, 2023 Share Posted August 16, 2023 I've had to do some water damage repair to the 1/2 bath in my 09. Prior beltline and/or vent leak. The wall construction on my rig consisted of vinyl wallpaper glued to 3/16" fiberboard (the stuff that disintegrates when wet). Behind that I had Styrofoam and steel beams. I did not have an upper trim piece (crown molding) to contend with, the vanity cabinet went to the ceiling. As stated, look hard for the screws or nails holding on the cabinets and trim. Be prepared to replace the wall panels. I used 1/4" birch plywood, which is actually very close to 3/16" . I then install a new textured wall paper and painted. I was lucky to be working in a small space and didnt have to match existing non-damaged walls. This is what I started with, hard to see, but the wall paper is loose, the back splash is loose as well. The floor was damaged as well. I had to cut out and replace most of the floor as well. This is what I found behind the wall paper, the vinyl wall paper is an excellent moisture trap. After Clean up: 1st piece of plywood installed: 2 Link to comment Share on other sites More sharing options...
DBRV.0 Posted December 8, 2023 Share Posted December 8, 2023 (edited) On 8/16/2023 at 5:10 PM, LakeBob said: I've had to do some water damage repair to the 1/2 bath in my 09. Just curious - I cannot tell from the pictures, but in the "after" state, it looks like the wall has all voids filled with Styrofoam. Correct? Was Styrofoam present in the "before" state, or was there something else? I'm trying to develop an understand of all aspects of the OEM construction. Boy, you sure do like to tackle big jobs! Edited December 8, 2023 by DBRV.0 Link to comment Share on other sites More sharing options...
LakeBob Posted December 8, 2023 Share Posted December 8, 2023 The styrofoam was underneath the rotted wall board. It’s standard Monaco construction. If you look in the lower right in the picture where I havre painted everything with mold inhibiting primer, you can see where the factory left a piece out. I glued a new piece in place, directly to the interior of the fiberglass body. This was the finished product: 4 Link to comment Share on other sites More sharing options...
jacwjames Posted December 8, 2023 Share Posted December 8, 2023 Great repair Bob. I think jumping into a project like this and fixing it right is the way to go. A post like this gives others the info of what might be involved and hopefully the confidence to fix similar issues. 1 Link to comment Share on other sites More sharing options...
DBRV.0 Posted December 8, 2023 Share Posted December 8, 2023 8 hours ago, LakeBob said: The styrofoam was underneath the rotted wall board. It’s standard Monaco construction. You did a super job! I felt compelled to ask about insulation. We changed out our bed, which necessitated changing the plywood foundation size. During that process, I wanted to document some of the wiring. I was shocked to find that the slide-out wall had zero insulation. That is the wall with the most electrical switches - the forward wall. Made me start to wonder if there was any insulation anywhere except the ceiling. Getting into the front cap, I found insulation stopped 4 inches above the windshield - leaving fiberglass exposed. So when the 'OVHD Fan' switch to the left of the driver is activated, that unconditioned air is circulated. Link to comment Share on other sites More sharing options...
