Kevin Clark Posted August 26, 2023 Share Posted August 26, 2023 I have a 12v electrical connector in my bathroom that I have no idea what it goes to. Can someone help me figure it out? About a month ago we a 2002 Monaco Windsor. It has water damage which we're repairing (from a frozen burst pipe). The previous owner had already demo'd much of the damaged wood. In the bathroom, near the elevated toilet, there is a 12v connection coming out of the floor. The connector is still attached but I cannot find the corresponding plug it goes to. Was there a removed appliance of some sort? Mood lighting? Hoping another Monaco owner can help me figure out what it's for? Thanks!! Link to comment Share on other sites More sharing options...
DavidL Posted August 26, 2023 Share Posted August 26, 2023 Could it be for the toilet itself? 1 Link to comment Share on other sites More sharing options...
Kevin Clark Posted August 26, 2023 Author Share Posted August 26, 2023 I suppose it could be, but why would a toilet need a 12v connection? LOL The toilet that was uninstalled does not have a connection on it. Link to comment Share on other sites More sharing options...
jacwjames Posted August 26, 2023 Share Posted August 26, 2023 I have the Aria Thetford toilet installed which has an electric flush feature, just press a button and woosh all done. You have a fuse in the 12 volt fuse distribution box in the bedroom, F16 is the fuse for the toilet and awning. 1 Link to comment Share on other sites More sharing options...
Solution JDCrow Posted August 26, 2023 Solution Share Posted August 26, 2023 18 minutes ago, Kevin Clark said: I suppose it could be, but why would a toilet need a 12v connection? LOL The toilet that was uninstalled does not have a connection on it. Yep electric flush. Took mine out when I redid the floor and put a gravity flush. Link to comment Share on other sites More sharing options...
Kevin Clark Posted August 26, 2023 Author Share Posted August 26, 2023 Thanks everyone for your quick help! Link to comment Share on other sites More sharing options...
brokenarrow1244 Posted August 31, 2023 Share Posted August 31, 2023 My coach has a courtesy rope light that is on a 12v circuit. also have a connection to turn on the pump. If that is of any help for you...great. Link to comment Share on other sites More sharing options...
Tom Cherry Posted August 31, 2023 Share Posted August 31, 2023 Don’t abandon the 12 VDC. Many of the TPMS need a repeater relay or signal amplifier so the rear TPMS on the rear tires of the TOAD will have sufficient strength to be received by the up front monitor. Just terminate properly. I had to add a 12VDC power plug in my bathroom to power the repeater.. Remember Yoda’s advice to Luke. “Use the FORCE, Luke…Gravity is the force that is always with you”…..🤓 Link to comment Share on other sites More sharing options...
Kevin Clark Posted August 31, 2023 Author Share Posted August 31, 2023 Good to know! I was planning to add a small down light near the toilet to help with those middle if the night bathroom visits! Link to comment Share on other sites More sharing options...
