Solution cbr046 Posted September 22, 2023 Author Solution Share Posted September 22, 2023 BINGO!!! The IGNITION RELAY in FRB Monaco 2 was the culprit. Being intermittent made the job that much more difficult. 😬 I swapped it to the Park Bell 1 relay. Now when I put the coach in gear (or neutral) the beeping never stops. So I swapped it with the Horn Relay from Monaco box 1, which are all different (or are they?). The beeping goes away while in gear but now I don't have a horn. Those relays are Omron (brand) 7866. 1 minute ago, myrontruex said: To find out what the relay controls, just pull it out. And while it is out, take some pictures of it. Might be able to come up with a simple replacement. Agreed, but I'm going to post separately on relays vs relays . . . The Park Bell 1 relay has signals like N SENSE NO and N SENSE NC, which could be signals to the ECM or TCM whether the coach is in neutral. @jacwjames Coach-Net is now $249 for a motorhome, $179 for a trailer. - bob Link to comment Share on other sites More sharing options...
jacwjames Posted September 22, 2023 Share Posted September 22, 2023 Glad you found the problem, might pay to go buy a Powerball ticket, it +$700M now. $249 isn't bad, may have to check into it more. Here is the parts page for the relays that are in my #1 & #2 boxes. I did a quick search using the vendor number and it looks like they are available. https://www.amazon.com/Omron-12077866-Replacement-Relay-5810-0202/dp/B079ZRGS49 1 Relay.pdf 1 Link to comment Share on other sites More sharing options...
cbr046 Posted September 22, 2023 Author Share Posted September 22, 2023 14 minutes ago, jacwjames said: $249 isn't bad, may have to check into it more. Like Yogi Bera would say, "You don't need it til you need it" - b 1 Link to comment Share on other sites More sharing options...
MyronTruex Posted September 22, 2023 Share Posted September 22, 2023 (edited) N SENSE NO and N SENSE NC, Sounds like Neutral Sense, Normally Open. Neutral Sense, Normally Closed. A simple on/off relay... I carry multiple spares for a couple of relays. Seems they act up at the strangest times. And I own a service center for electronics. I think they just commit suicide. Edited September 23, 2023 by myrontruex spelling Link to comment Share on other sites More sharing options...
dandick66 Posted September 24, 2023 Share Posted September 24, 2023 Bob, Glad you found the problem and got it fixed. I had a similar issue with my Maxxforce engine, but didn’t post it here as just about everyone here has a Cummins or Cat. Here’s the link to my IRV2 post. https://www.irv2.com/forums/f122/maxxforce-10-won-t-start-600575.html Dan Link to comment Share on other sites More sharing options...
