Michel Posted October 5 Share Posted October 5 Hi, I have a Cayman 2003 and I just discovered my roof had hundreds of tiny holes in it, mostly only on one side of the RV. It started with small rust type bubble and when sanded it showed up as holes in the roof. The roof was completely replaced 6 years ago after hail storm. Any suggestion, does not want to spend a fortune on this? Replace with TPO roof? Repair like a rusted car roof, buff, putty and paint? Ethernabound over all damaged surface? They want $10,000 to completely replace the roof with an Aluminum roof. Thank you Link to comment Share on other sites More sharing options...
JDCrow Posted October 5 Share Posted October 5 (edited) If it were me, I’d putty, prime then go talk the bed liner (Rino, Arma) and get a quote to shoot the whole roof. Edited October 5 by JDCrow Spelling 2 Link to comment Share on other sites More sharing options...
hex_nut Posted October 5 Share Posted October 5 A lot depends on how long you intend to keep the motorhome. I have done motorhomes with Henry's roll on products for a short term fix (it will last a few years). For a long term fix, I would also recommend the poly-urea spray on roofing (RV Armor, FlexArmor, etc...). Roll on roofing is cheap (a few hundred bucks), but with limited warranty. The spray on poly-urea is much more expensive (about $150 per linear foot), but often has a life time warranty. I had the front of my coach sprayed with a poly-urea bra color matched to my coach to combat the rock chip problem. I have been very happy with it. Richard 1 Link to comment Share on other sites More sharing options...
Michel Posted October 5 Author Share Posted October 5 1 hour ago, JDCrow said: If it were me, I’d putty, prime then go talk the bed liner (Rino, Arma) and get a quote to shoot the whole roof. That sounds like a good idea, never though of Rino, I will check on that for sure. I guess they have white stuff. 1 Link to comment Share on other sites More sharing options...
JDCrow Posted October 5 Share Posted October 5 51 minutes ago, Michel said: That sounds like a good idea, never though of Rino, I will check on that for sure. I guess they have white stuff. Yeah there is an outfit in Yuma on South Frontage that advertises heavy. I think for our rigs it is a legit use. Outlast me anyway 1 Link to comment Share on other sites More sharing options...
Michel Posted October 5 Author Share Posted October 5 2 hours ago, hex_nut said: A lot depends on how long you intend to keep the motorhome. I have done motorhomes with Henry's roll on products for a short term fix (it will last a few years). For a long term fix, I would also recommend the poly-urea spray on roofing (RV Armor, FlexArmor, etc...). Roll on roofing is cheap (a few hundred bucks), but with limited warranty. The spray on poly-urea is much more expensive (about $150 per linear foot), but often has a life time warranty. I had the front of my coach sprayed with a poly-urea bra color matched to my coach to combat the rock chip problem. I have been very happy with it. Richard Thank you for your recommendations. I contacted RV Armor or FlexArmor not sure, they start at $195 / linear foot but maybe I could do it myself. As I understand this is only to shoot their stuff on the roof? I was quote about the same price in Canada to replace the complete roof with aluminum sheet warranty for 20 years. Link to comment Share on other sites More sharing options...
pulsarjab Posted October 6 Share Posted October 6 Have you determined what caused the holes? Link to comment Share on other sites More sharing options...
Michel Posted October 6 Author Share Posted October 6 2 hours ago, pulsarjab said: Have you determined what caused the holes? No but it is corroded just like picture of corroded aluminum. Maybe it was already corroded when they installed it, I do know. My old roof had 15 years, not even a trace anywhere but after hail, it was all dented and insurance paid for replacement. I will see if I can get the RV shop to pay for it. 1 Link to comment Share on other sites More sharing options...
lotosrggp1 Posted October 6 Share Posted October 6 Sounds like the wrong alloy of aluminum was used for the current roof. 5052 is what used to be used in marine applications for its corrosion resistance. 2 Link to comment Share on other sites More sharing options...
W7BE_Bob Posted October 7 Share Posted October 7 Aluminum does not rust. But some alloy variation could contain steel related components. Long term I'd want to know more before covering it up which might mask the problem. Link to comment Share on other sites More sharing options...
JDCrow Posted October 7 Share Posted October 7 (edited) Yeah no rust but does corrode. I have zincs on my aluminum boat for my saltwater salmon trips https://www.corrosionpedia.com/understanding-aluminum-corrosion/2/6954 Edited October 7 by JDCrow 1 Link to comment Share on other sites More sharing options...
Paul J A Posted October 7 Share Posted October 7 You need to be realistic about the value of the coach and how long you intend to keep it. Those answers will direct you to the resolution that would be appropriate. You really do have some great options to choose from. Good luck. 1 Link to comment Share on other sites More sharing options...
LaPalma 34PDD Posted October 7 Share Posted October 7 Not sure what could have caused the holes but I have had my roof covered by RV roof FlexArmor. It is a bit pricy but is guaranteed for life and the warranty is transferable. I didnt have roof issues and didnt want them later on so bit the bullet and had it done. 2006 Monaco LaPalma 34PDD. 1 Link to comment Share on other sites More sharing options...
lotosrggp1 Posted October 7 Share Posted October 7 After looking at the corrosion article I wonder if the replacement roof was properly installed. Dielectric materials need to be used between dissimilar metals, like aluminum and steel, everywhere, to prevent galvanic corrosion. You might want to use an Non Contact Voltage Tester Pen to make sure there isn't live current there which would speed the action. 1 1 Link to comment Share on other sites More sharing options...
Gary Petersen Posted October 8 Share Posted October 8 Curiously, why corrosion appears on side, and not the other? Plausible, they used incompatible alloy on one side for this application. Or, it indicates this original surface was exposed to something outside the neutral PH 4 to 6 range for Aluminum. TPO a bad choice,..difficult to fit on, and secure to the contoured surface and, also, with ANY moisture , it’s Greased Lightning! Whatever you were to put in the thin Aluminum holes, you need to be confident that it has some physics to hold it there. I would feel more confident with something that goes over, and securely covers the holes. My two cents for an economical and virtually permanent solution for this DIY project. Start by, CLEANING the painted roof surface with a quick, (but thorough), wipe down with Acetone as a cleaning agent using lots of fresh Clean rags to pick up dust. Acetone’s long term contact, can lift the paint. (also, don’t store the damp dirty, and combustable rags inside ). Now, Clean the exposed Aluminum with 50 / 50 vinegar / distilled water solution to clean and Etch the AL. Finally, lightly “damp wipe” the Aluminum with just distilled water and let it thoroughly dry. Now, spot cover Holes with reasonably sized pieces of, Eternabond Tape. Next: Mask off perimeter Non-work areas. Then, Google RC 2000 and look at Inland Coatings, as they have a two part coating system designed specifically for Metal Roofs. In this case it is important that the coatings remains slightly flexible, especially over time on a dynamic RV roof system. Check out RC 2013 as their metal roof primer, which should be "Rolled On” the entire roof surface. Then, (also rolled on), their Top coat RC 2014, this step is Required. I have been impressed with the surface adhesion of the RC 2000 products. YOU, can solve this! 1 1 Link to comment Share on other sites More sharing options...
Michel Posted November 2 Author Share Posted November 2 On 10/8/2023 at 1:16 AM, Gary Petersen said: Curiously, why corrosion appears on side, and not the other? Plausible, they used incompatible alloy on one side for this application. Or, it indicates this original surface was exposed to something outside the neutral PH 4 to 6 range for Aluminum. TPO a bad choice,..difficult to fit on, and secure to the contoured surface and, also, with ANY moisture , it’s Greased Lightning! Whatever you were to put in the thin Aluminum holes, you need to be confident that it has some physics to hold it there. I would feel more confident with something that goes over, and securely covers the holes. My two cents for an economical and virtually permanent solution for this DIY project. Start by, CLEANING the painted roof surface with a quick, (but thorough), wipe down with Acetone as a cleaning agent using lots of fresh Clean rags to pick up dust. Acetone’s long term contact, can lift the paint. (also, don’t store the damp dirty, and combustable rags inside ). Now, Clean the exposed Aluminum with 50 / 50 vinegar / distilled water solution to clean and Etch the AL. Finally, lightly “damp wipe” the Aluminum with just distilled water and let it thoroughly dry. Now, spot cover Holes with reasonably sized pieces of, Eternabond Tape. Next: Mask off perimeter Non-work areas. Then, Google RC 2000 and look at Inland Coatings, as they have a two part coating system designed specifically for Metal Roofs. In this case it is important that the coatings remains slightly flexible, especially over time on a dynamic RV roof system. Check out RC 2013 as their metal roof primer, which should be "Rolled On” the entire roof surface. Then, (also rolled on), their Top coat RC 2014, this step is Required. I have been impressed with the surface adhesion of the RC 2000 products. YOU, can solve this! This sounds like a good process, especially that RC 2000 has anticorosion in it. I will check on this, thank you. Link to comment Share on other sites More sharing options...
