Kjungles Posted October 28 Share Posted October 28 I have a 2003 executive and wondering when I store for the winter does the solar panel still charge the batteries after I kill power to the coach? Link to comment Share on other sites More sharing options...
Ivan K Posted October 28 Share Posted October 28 My factory solar system was connected directly to both battery banks and kept them alive that way. I would verify it on a sunny day but that would be my expectation. Link to comment Share on other sites More sharing options...
Just Jim Posted October 28 Share Posted October 28 by "kill power to the coach" do you mean engaging the battery disconnects? I don't know for sure, but I would think that would disconnect the solar as well. Flipping the "salesman" switch up in the front would leave the solar connected. Link to comment Share on other sites More sharing options...
Dr4Film Posted October 28 Share Posted October 28 (edited) The solar panel on my previous Windsor was on all the time. It did not go through the disconnects as I discovered when the alternator was being removed we had a small amount of voltage still present. There are two fuses, one for each system, you can remove that will disconnect the solar panel from the house and chassis systems. Edited October 28 by Dr4Film Link to comment Share on other sites More sharing options...
LakeBob Posted October 28 Share Posted October 28 On my Dynasty there is a separate, fused line, coming into the battery compartment, attached to the pos leads. This is always live on mine. I would imagine yours is set up similarly. The quick method to disconnect is to pull the fuse. Link to comment Share on other sites More sharing options...
tmw188 Posted October 28 Share Posted October 28 (edited) Bob and Richard are correct. They will unless someone wired it differently. I just installed 200w of solar with a controller using the pre wired house setup and it’s wire to charge the batteries regardless on the battery switch selection. If you have a controller it is highly advised to always disconnect the solar feed to the controller before doing anything with the batteries. The controller needs to see voltage from the batteries before turning on the solar array. I installed a breaker disconnect before the controller to help manage that. The photos below is from my Windsor as is what Bob is talking about. I got the same info from Jacwjames when I was tracing down the wires for solar. Edited October 28 by tmw188 Edit some wording Link to comment Share on other sites More sharing options...
