Ali-026 Posted March 17 Share Posted March 17 I was wondering if anyone knows the make model part number of this 2008 Camelot ride height valve? Link to comment Share on other sites More sharing options...
Chargerman Posted March 17 Share Posted March 17 What are the symptoms that are making you think it needs replacing? They are a standard part that can be purchased at a local truck shop like Frieghtliner Link to comment Share on other sites More sharing options...
bobdinsmore Posted March 17 Share Posted March 17 (edited) I just got one at NAPA in Dec, about $28, because the rubber end of the link had torn loose. Delete my response. I'm referring to the Link, not the valve. Edited March 17 by bobdinsmore Ignore my answer: Non-responsive. Link to comment Share on other sites More sharing options...
Jdw12345 Posted March 17 Share Posted March 17 The picture you posted indicates that the air line is leaking, I can only assume that is why you are asking about the air ride valve, you might be able to remove that leaking air line and reinsert it if it still leaks make a clean cut, no burs, and re-insert the air line, hopefully that there is enough extra air line to try this, I’ve noticed on some of my air lines that they cut them off just a hair short. If you’re wanting a new air ride valve you should be able to get one at any heavy duty truck parts store. Link to comment Share on other sites More sharing options...
Ivan K Posted March 17 Share Posted March 17 Yeah that is a pretty extreme angle for the line exiting PTC fitting. Might be able to tie the line to an other or a frame part that doesn't move to fix the angle and stop leaking. Link to comment Share on other sites More sharing options...
jacwjames Posted March 17 Share Posted March 17 When I went through my air system I had one PTC fitting that just wouldn't seal when I changed a fitting. Ended up getting a compression fitting and it sealed the first time. Link to comment Share on other sites More sharing options...
Solution Ali-026 Posted March 18 Author Solution Share Posted March 18 OK after some research, I think what I have is a Ridewell Lo-Flo HCV part number 6255007. I've heard a few other 2008 Camelot/Dynasty owners having the same ride height valve unit. Now I'll need to fix the air leaks thru the PTC fittings and adjust the ride height. Link to comment Share on other sites More sharing options...
