bmulvenna@hotmail.com Posted August 24, 2020 Share Posted August 24, 2020 2004 Monoco Dynasty. Headlights and tail lights work properly on both sides but right rear (passenger) brake and turn signal does not work. Front right turn signal works properly. When headlights are on the right turn arrow activates on the dash but it does not blink. Thanks in advance. Link to comment Share on other sites More sharing options...
Dr4Film Posted August 24, 2020 Share Posted August 24, 2020 First check fuses inside Monaco Box #1 and #2 located in the FRB directly under the driver's window. Then look for possibly a bad ground connection. Or is it a blown bulb? Link to comment Share on other sites More sharing options...
bmulvenna@hotmail.com Posted August 24, 2020 Author Share Posted August 24, 2020 Thanks, fuses are all good and all lights come on when I turn the headlights on. Link to comment Share on other sites More sharing options...
Ivan K Posted August 24, 2020 Share Posted August 24, 2020 If you have individual light housings for each of the lights like we do and the ground (White wire) is daisy chained from one to an other, check for a bad connection at each point. I had that happen and it was confusing the way the lights interacted at first. Link to comment Share on other sites More sharing options...
Dennis H Posted August 24, 2020 Share Posted August 24, 2020 (edited) 2 hours ago, bmulvenna@hotmail.com said: Thanks, fuses are all good and all lights come on when I turn the headlights on. You know the brake/tail lamps are double element bulbs, yes? One element is the tail light and the other is the brake light. Ergo, just because it lights with the headlights doesn't mean the brake lamp element hasn't failed. Easiest fix is to pull the bulb and check both elements. An alternative is to have someone hit the brakes and see if that bulb lights up. Make sure the key is on or the engine is running, depending on your set up.....Let us know what you find. I suspect a bad bulb.....Dennis Edited August 24, 2020 by Dennis H 1 Link to comment Share on other sites More sharing options...
bmulvenna@hotmail.com Posted August 24, 2020 Author Share Posted August 24, 2020 1 hour ago, Dennis H said: You know the brake/tail lamps are double element bulbs, yes? One element is the tail light and the other is the brake light. Ergo, just because it lights with the headlights doesn't mean the brake lamp element hasn't failed. Easiest fix is to pull the bulb and check both elements. An alternative is to have someone hit the brakes and see if that bulb lights up. Make sure the key is on or the engine is running, depending on your set up.....Let us know what you find. I suspect a bad bulb.....Dennis Thanjs. Bulbs are all LED. It was just bad sockets. Old and loose. Link to comment Share on other sites More sharing options...
Dr4Film Posted August 24, 2020 Share Posted August 24, 2020 Glad it was something simple! Link to comment Share on other sites More sharing options...
