Nosmo179 Posted September 9, 2020 Share Posted September 9, 2020 I read a long time ago where someone posted about the need to change my Flasher so I could use all LEDs in my Turn/brake lights (1156 bulbs). I ask this because I am currently making the change over. I have on problem, it's an odd one. When I put 1156 LEDs in all three lights per side. My corner light (marker/turn) and the lower side (red) clearance light (turn signal/marker) don't work at all. If I put 1 incandescent 1156 back in these side lights work fine. So, is this a problem that a alternate Flasher will cure or not? I fear changing my front turn signal bulbs to LEDs and make the problem worse. So, any info will be fun to read and hopefully fix this issue! Link to comment Share on other sites More sharing options...
Ivan K Posted September 9, 2020 Share Posted September 9, 2020 With the LED flasher lights you have 2 choices, either install parallel resistors to simulate current of the incandescent bulb or replace the flasher relay for an electronic one, not based on current and provided you find one that would fit the existing socket configuration. Resistors would be my last choice as they get hot and that could pose a problem with plastic light housings. If your red marker light alternates with the corner light, the new flasher still may not make it work but the resistors would. Something to try to know for sure. I just left the rear flashers the way they were originally. All the rest is LED. 1 1 Link to comment Share on other sites More sharing options...
waterskier_1 Posted September 9, 2020 Share Posted September 9, 2020 I suspect your 96 is wired similar to my 87 Dynasty. If the lights you are referring to are the ones that flash both with the running (parking) lights on or flash with them off, you simply can not replace those lights with LEDs. This is because Monaco did something tricky in order to have a single filament bulb flash one when needed and the running light are off, and then be able to use the same bulb flash off, if the running light are on. The way they did this is by grounding and supplying power different directions through the bulb. It is convoluted, and if you really want to know what they are doing, you can study the wiring diagram, or ask. But short of designing your own switching circuit, which will mimic the light bulb in there, and then have an output that will switch the LED, or redesigning the system, it won't work. I did design a circuit to do that, one is required at each of the four lights (front and rear) that flash this way. It worked except when the brake lights were also on. The easy way it to leave those four bulbs as is. And No, a new flasher won't help this problem. The new flashers are sometimes required because they use the resistance of standard bulbs as part of the timing circuit (that's why it flashes faster when a bulb is burnt out). The LEDs don't have anything similar to that resistance, so they will either not flash, or flash extremely fast. Adding resistance is the key, either as an external stand alone resistor, or a special flasher with that resistance already built in. -Rick 1 Link to comment Share on other sites More sharing options...
Nosmo179 Posted September 10, 2020 Author Share Posted September 10, 2020 Ivan K and Waterskier_1 thank you very much. Great info and fun to read. I'm doing the easy thing for those back side light which are just like the 87 RV. And I'll just leave the one incandescent 1156 bulb per side to get those odd ball lights to work. And Ivan K getting an electric flasher to help is nice to know. I'll keep all this for future reference. Take care, be safe and as my wife tells me, be visible (when on the road...) 1 Link to comment Share on other sites More sharing options...
dl_racing427 Posted September 10, 2020 Share Posted September 10, 2020 The way they do this is they use the turn signal filament in the bulb as the ground for the side marker lights. It's a very simple and common way to get that functionality. When the turn signal is on and the park lights are off, the side marker flashes with the signal. When the park lights are on it flashes alternately. Link to comment Share on other sites More sharing options...
pwhittle Posted September 11, 2020 Share Posted September 11, 2020 I faced this on our 1994 Signature. The solution was to install a bridge rectifier in the wiring for each LEDbulb. The two inputs can be GND or 12V, when one is GND and the other Is 12V the output -ve will be GND and the output +ve will be 12V These ones are rated at 2A, which is plenty for a single marker LED. (Pack of 20 Pieces) Chanzon 2W10 Bridge Rectifier Diode 2A 1000V WOB Single Phase, Full Wave 2 Amp 1000 Volt Electronic Silicon Diodes https://www.amazon.com/dp/B079KD43YG Paul Link to comment Share on other sites More sharing options...
