StillRunning_60 Posted October 14, 2020 Share Posted October 14, 2020 Not sure if it is a problem or what but the last 2 times I have been camping my inside RC7 GS remote controller/gen starting has been ticking like a bomb all the time. Does not do that hooked up at home. The only thing different is my power cord. Any suggestions as what the ticking means and can the power cord be the problem? Link to comment Share on other sites More sharing options...
Dr4Film Posted October 15, 2020 Share Posted October 15, 2020 What are the status of the LED lights when this happens? Plus what does the display say? Are you dry camping while away from home and hooked to shore power when at home? Link to comment Share on other sites More sharing options...
StillRunning_60 Posted October 15, 2020 Author Share Posted October 15, 2020 System status: Float Charging charge light blinking very rapidly and battery full light is on At home I have to use a must longer cord Link to comment Share on other sites More sharing options...
bobdinsmore Posted October 15, 2020 Share Posted October 15, 2020 Just a stab in the dark, but you may want to try unplugging and replugging the data cable. This is like powering off and then on your computer when it acts weird. Link to comment Share on other sites More sharing options...
veraken Posted October 15, 2020 Share Posted October 15, 2020 In case you don't have it, here is the manual Xantrex RC-7 Manual.pdf Link to comment Share on other sites More sharing options...
Guest Tim503 Posted October 16, 2020 Share Posted October 16, 2020 If you need a replacement I may have one. Link to comment Share on other sites More sharing options...
Ivan K Posted October 16, 2020 Share Posted October 16, 2020 Our RC7GS was randomly ticking like you describe when we purchased the coach second hand. No resets would make it stop until I replaced it. It also had troubles turning on the invertor at that time. It had nothing to do with an extension cord. Link to comment Share on other sites More sharing options...
StillRunning_60 Posted October 16, 2020 Author Share Posted October 16, 2020 Tim how much for the replacement panel Link to comment Share on other sites More sharing options...
Ernest Tumbleston Posted October 17, 2020 Share Posted October 17, 2020 I need one too if anyone has one for sale! Mine is doing the same thing. All of the time. I had to unplug it. Link to comment Share on other sites More sharing options...
Gary Petersen Posted October 17, 2020 Share Posted October 17, 2020 On 10/15/2020 at 5:25 AM, veraken said: In case you don't have it, here is the manual Xantrex RC-7 Manual.pdf 775.91 kB · 13 downloads As is commonly said "Thanks, I needed that!" the manual. Link to comment Share on other sites More sharing options...
