Overflow Tank Leak
There are a couple of aftermarket aluminum ones available.
Source Engineering
Veurink's RV Center.
HannaPhone 058.jpgRV Center
about $500 from Source Engineering in  Oregon     541-343-0295  Jim@sourcerv.com
3- they have the Aluminum tank   Tip: don't waste your time trying to patch the poly tank it just will crack in another place loose your fluid  overheat and have a $20,000 + engine repair
  • Thanks 1
55 minutes ago, Dr4Film said:
Talin RV, Veurinks RV, Source Engineering all have replacement tanks at a variety of prices.
I bought a replacement plastic one from Veurinks RV back in 2015.
Look on their web site to see if they are still available.
Old used ones will still crack so don't waste your time on a used poly tank
The Talin website says their tank dimensions are 14" x 14" x 14"., price $469.
Jim
Just check with Veurinks plastic no longer available.
Just saw this on YouTube
  • Thanks 1
  • 4 months later...
Finally installed new tank, but the new low coolant sensor is 2 wire.  The old tank sensor 3/4 from bottom on the left side had single wire.  I’m told that you could just combined the two wires and crimp to the single wire?
