Rob connors Posted January 19, 2021 Share Posted January 19, 2021 I need to replace my NAPA 8D Chassis Battery 110O CCA which is very Heavy. I would like to know if I should replace it with 2 each 12volt Battery wired in Parallel ? I would like to know everyones thoughts. Link to comment Share on other sites More sharing options...
John Haggard Posted January 19, 2021 Share Posted January 19, 2021 10 minutes ago, Rob connors said: I need to replace my NAPA 8D Chassis Battery 110O CCA which is very Heavy. I would like to know if I should replace it with 2 each 12volt Battery wired in Parallel ? I would like to know everyones thoughts. Your 8 D is 12 volt Thats what we use. Great batteries with long life What we use in all of our semis also. 1 Link to comment Share on other sites More sharing options...
Pepperell Posted January 19, 2021 Share Posted January 19, 2021 If you mean replacing one battery with two, the Executives have a large engine that would be happiest with two. The more CCA, the less voltage drop while cranking to start. Link to comment Share on other sites More sharing options...
John Haggard Posted January 19, 2021 Share Posted January 19, 2021 1 minute ago, Pepperell said: If you mean replacing one battery with two, the Executives have a large engine that would be happiest with two. The more CCA, the less voltage drop while cranking to start. Maybe he is thinking two 6 volt ??? 33 minutes ago, Rob connors said: I need to replace my NAPA 8D Chassis Battery 110O CCA which is very Heavy. I would like to know if I should replace it with 2 each 12volt Battery wired in Parallel ? I would like to know everyones thoughts. 12 minutes ago, Pepperell said: If you mean replacing one battery with two, the Executives have a large engine that would be happiest with two. The more CCA, the less voltage drop while cranking to start. 1 Link to comment Share on other sites More sharing options...
Guest Ray Davis Posted January 19, 2021 Share Posted January 19, 2021 He said two 12v batteries wired in parallel which is still 12v but double the amps. I think what he's asking is if 2 batteries of lesser weight would be ok. To that I say why not as long as you still have the amps. Big batteries are really heavy. I used to man handle the batteries now they man handle me. I use the bucket on my tractor to carefully lift them into place now. Link to comment Share on other sites More sharing options...
John Haggard Posted January 19, 2021 Share Posted January 19, 2021 27 minutes ago, Ray Davis said: He said two 12v batteries wired in parallel which is still 12v but double the amps. I think what he's asking is if 2 batteries of lesser weight would be ok. To that I say why not as long as you still have the amps. Big batteries are really heavy. I used to man handle the batteries now they man handle me. I use the bucket on my tractor to carefully lift them into place now. Ha Ha Yes I have 4 grandsons that play football. A $20. Gets my batteries changed out Ray. My boat has 4, 8 D house batteries. A $50. Gets them installed 1 1 Link to comment Share on other sites More sharing options...
vito.a Posted January 19, 2021 Share Posted January 19, 2021 (edited) I no longer use the large 8D batteries. I'm using two NAPA Group 31 batteries rated at 1100CCA each. They are 12V and I connect them in parallel. They crank better and last longer than the 8D batteries. Plus they are much easier to handle. Edited January 19, 2021 by vito.a 3 Link to comment Share on other sites More sharing options...
wamcneil Posted January 20, 2021 Share Posted January 20, 2021 19 hours ago, vito.a said: I no longer use the large 8D batteries. I'm using two NAPA Group 31 batteries rated at 1100CCA each. They are 12V and I connect them in parallel. They crank better and last longer than the 8D batteries. Plus they are much easier to handle. I can vouch for this configuration. My rig came stock with two group 31s in parallel. Cheers Walter 1 Link to comment Share on other sites More sharing options...
Dr4Film Posted January 21, 2021 Share Posted January 21, 2021 When I need a new 8D Chassis battery, I take the coach to my local Sam's Club and have them remove the old and install the new. Those guys are a lot buffer than I am. The last one I had done was at the Fairbanks AK Sam's Club in 2012 for $179. The old battery was the original one installed at the factory and was still going strong BUT I didn't want to have any problems with it while returning to the lower 48 so I sprang for a new one after 11 years of service. The new one still remains in there today with lots of cranking power, over 1400 CCA. 1 Link to comment Share on other sites More sharing options...
John Haggard Posted January 21, 2021 Share Posted January 21, 2021 34 minutes ago, Dr4Film said: When I need a new 8D Chassis battery, I take the coach to my local Sam's Club and have them remove the old and install the new. Those guys are a lot buffer than I am. The last one I had done was at the Fairbanks AK Sam's Club in 2012 for $179. The old battery was the original one installed at the factory and was still going strong BUT I didn't want to have any problems with it while returning to the lower 48 so I sprang for a new one after 11 years of service. The new one still remains in there today with lots of cranking power, over 1400 CCA. Thats good service Richard And why we use NAPA batteries in the semis and farm tractors also. We had lunch at Martins on Tuesday. 1 Link to comment Share on other sites More sharing options...
Dr4Film Posted January 21, 2021 Share Posted January 21, 2021 6 minutes ago, John Haggard said: We had lunch at Martins on Tuesday. They are two blocks from our house. Haven't been there since the pandemic as we seldom go out to restaurants versus enjoying my wife's wonderful Thai food that she cooks everyday. I am SO lucky to have a Thai born wife that loves to cook original Thai dishes. I ordered take out from the local Texas Roadhouse in Palm Coast on Tuesday for my wife's birthday but was disappointed by the time I got it home and dug into the food. I'd much rather enjoy a meal like that right at the restaurant versus take out but at least she didn't have to cook on her birthday. 1 Link to comment Share on other sites More sharing options...
John Haggard Posted January 21, 2021 Share Posted January 21, 2021 3 hours ago, Dr4Film said: They are two blocks from our house. Haven't been there since the pandemic as we seldom go out to restaurants versus enjoying my wife's wonderful Thai food that she cooks everyday. I am SO lucky to have a Thai born wife that loves to cook original Thai dishes. I ordered take out from the local Texas Roadhouse in Palm Coast on Tuesday for my wife's birthday but was disappointed by the time I got it home and dug into the food. I'd much rather enjoy a meal like that right at the restaurant versus take out but at least she didn't have to cook on her birthday. Well happy birthday to the misses 1 Link to comment Share on other sites More sharing options...
Hotrod - R.I.P. Posted January 21, 2021 Share Posted January 21, 2021 On 1/19/2021 at 8:09 AM, Rob connors said: I need to replace my NAPA 8D Chassis Battery 110O CCA which is very Heavy. I would like to know if I should replace it with 2 each 12volt Battery wired in Parallel ? I would like to know everyones thoughts. IF the 8D worked good, there would be little reason to want to go to anything else. Link to comment Share on other sites More sharing options...
walt2137 Posted January 22, 2021 Share Posted January 22, 2021 Last year i went from the 8D to two 900ca napa batteries, getting to old to handle the 8D. My son went from 2 8D to 4 900ca napa in his snapper fish boat and he is pleased with the change and so is his back. 1 Link to comment Share on other sites More sharing options...
Rob connors Posted January 23, 2021 Author Share Posted January 23, 2021 On 1/21/2021 at 5:17 AM, John Haggard said: Thats good service Richard And why we use NAPA batteries in the semis and farm tractors also. We had lunch at Martins on Tuesday. Love that Prime at Martins 1 Link to comment Share on other sites More sharing options...
John Haggard Posted January 23, 2021 Share Posted January 23, 2021 👍 👌 Link to comment Share on other sites More sharing options...
SigPIlot Posted June 21, 2021 Share Posted June 21, 2021 I was just about to replace 2 31 MHD Interstates. Lasted almost 6 years. I thinking based on the comments above I'll try the NAPA 31 Commercial 1000A. There about the same price and an 1 hour closer! 1 Link to comment Share on other sites More sharing options...
John Haggard Posted June 21, 2021 Share Posted June 21, 2021 3 minutes ago, SigPIlot said: I was just about to replace 2 31 MHD Interstates. Lasted almost 6 years. I thinking based on the comments above I'll try the NAPA 31 Commercial 1000A. There about the same price and an 1 hour closer! Smart move 👌 Link to comment Share on other sites More sharing options...
