powersltc Posted May 4, 2021 Share Posted May 4, 2021 Hello. Ron P. 2004 Monaco Executive Before I started looking, can someone help me out with locating the ports to charge the Dash A/C. Are the ports in the engine compartment or the generator area? Any advice or suggestions would be greatly appreciated. Ron P. 2004 Monaco Executive Link to comment Share on other sites More sharing options...
HarleyR Posted May 4, 2021 Share Posted May 4, 2021 I had my dash A/C recharged last season after my compressor seized and shredded the serpentine belt. All of the recharge fittings are below the windshield in the generator bay on my 2007 Beaver Contessa. Easily accessible. 1 Link to comment Share on other sites More sharing options...
Paul Busch Posted May 4, 2021 Share Posted May 4, 2021 I recharged mine 05 sig Detroit diesel and the port is in the rear right by the serpentine belt. paulb 1 Link to comment Share on other sites More sharing options...
timaz996 Posted May 4, 2021 Share Posted May 4, 2021 Mine are on the A/C compressor in the engine compartment. Tim Link to comment Share on other sites More sharing options...
vito.a Posted May 4, 2021 Share Posted May 4, 2021 (edited) I also have a 2004 model Monaco. We have A/C ports both up front and in the rear engine compartment. You can spot them by the red and blue plastic caps over the Schrader valves. I used the vacuum pump on the port up front for about 30 min and then moved it to the rear engine compartment ports for another 30 min. Then recharged from the rear port. Also, the dryer is up front just to the left of the generator and the system takes 4lbs of R134a. Edited May 4, 2021 by vito.a 1 Link to comment Share on other sites More sharing options...
Guest Michael V Posted May 4, 2021 Share Posted May 4, 2021 Does anyone happen to know where the expansion valve is located on a 2003 signature? Link to comment Share on other sites More sharing options...
vito.a Posted May 4, 2021 Share Posted May 4, 2021 (edited) I just replaced our expansion valve last week. It is up front above the generator. It has two black AC hoses connected with some black A/C insulation foam over the B nuts. I first removed the hoses. Then peeled back the insulation and broke the nuts loose and it came right off. I had to buy some new green orings when i reinstalled the new one. Part number: EGELHOF AC Expansion Valve 1268300384 / 0751.0003A 321300S Picture attached. Edited May 4, 2021 by vito.a 1 Link to comment Share on other sites More sharing options...
Lee Smith Posted August 25, 2022 Share Posted August 25, 2022 On 5/4/2021 at 7:06 PM, vito.a said: I just replaced our expansion valve last week. It is up front above the generator. It has two black AC hoses connected with some black A/C insulation foam over the B nuts. I first removed the hoses. Then peeled back the insulation and broke the nuts loose and it came right off. I had to buy some new green orings when i reinstalled the new one. Part number: EGELHOF AC Expansion Valve 1268300384 / 0751.0003A 321300S Picture attached. Vito, I ordered and received the part but it is different from what you installed. The part number is the same but it is missing the attached probe at the end. I assume that is some kind of a temperature probe but I wanted to check with you. Please see my pictures attached. Thank you for your help. Lee Link to comment Share on other sites More sharing options...
vito.a Posted August 25, 2022 Share Posted August 25, 2022 (edited) Hi Lee, Yes, I'm guessing that's a capillary tube for temperature. They probably deleted it for cost saving. Your choices are to try reordering, keep the original part, or install the new one. I think I'd try the new one. Good luck! Edited August 25, 2022 by vito.a 1 Link to comment Share on other sites More sharing options...
Lee Smith Posted August 25, 2022 Share Posted August 25, 2022 30 minutes ago, vito.a said: Hi Lee, Yes, I'm guessing that's a capillary tube for temperature. They probably deleted it for cost saving. Your choices are to try reordering, keep the original part, or install the new one. I think I'd try the new one. Good luck! Good advice. I ordered a new one. The original came from eBay caridautoparts and the new one, including green O-rings at .99 each, is from autohausaz. The caridautoparts eBay dealer was not even remotely interested in any kind of a timely resolution so I filed for a refund. Thanks again, Lee Link to comment Share on other sites More sharing options...
