Monte Roger Fautin Posted May 9, 2021 Share Posted May 9, 2021 I have a 2008 signature. Been a tough year. Replaced medallion, compressor for leveling, 2 air bags on driver side forward, new tires, batteries, guess it is my time. Coach has set in Las Vegas for one year because of the Covid-19 virus. Oh yes the aqua hot worked on as well, new pump. The latest was discovered when I had the oll changed. Leaking oll from turbo exhaust side was found. Approx 7.5 k to replace with a new turbo including labor. Looking for any info as to same experience, cost, remedy,etc Link to comment Share on other sites More sharing options...
Cubflyer Posted May 9, 2021 Share Posted May 9, 2021 Are you experiencing oil usage? How much? You may be victim of someone seeing some seepage thru the turbo seals (from sitting), unless it gets excessive, oil is cheap.... JMHO, YMMV.... Link to comment Share on other sites More sharing options...
96 EVO Posted May 9, 2021 Share Posted May 9, 2021 I'm really getting the feeling these new fangled VGT's don't like sitting for extended periods! Twice now, after several months idle, my engine has gone to fast idle on it's own, changed pitch, and followed shortly by smoke out the exhaust. After a shutdown / restart, it has run fine. 25mi run, no issues, 33" boost. Link to comment Share on other sites More sharing options...
Admirial RVr Posted May 9, 2021 Share Posted May 9, 2021 If you have checked your oil line connections and they are ok next step to check into is a rebuild kit to replace seals. Another option that might be available is to buy a core assembly this is the complete center section of the Turbo includes both turbine and compressor wheels. All of this is already assembeled ready to install into existing end housings. The 2 end housings I am sure are ok. Not sure if Cummins/Holset do this any longer but might be worth asking. Check into posibility of aftermarket replacements Cummins will not help you with aftermarket product but they used to sell good reman product. Cost should be less than new OE Product. Link to comment Share on other sites More sharing options...
Ivan K Posted May 9, 2021 Share Posted May 9, 2021 I would really look into what is leaking, last thing I need to see is a runaway diesel engine running on its own oil and eating itself up with no quick way to stop it. Link to comment Share on other sites More sharing options...
Tim-AZ Posted May 9, 2021 Share Posted May 9, 2021 I had my Turbo rebuilt in 2018 (complete, new impellers, seals, only housing stayed) $1050. Massy Diesel in Phoenix, AZ. And this is a large Banks Turbo. Tim Link to comment Share on other sites More sharing options...
Hypoxia Posted May 9, 2021 Share Posted May 9, 2021 18 hours ago, Monte Roger Fautin said: I have a 2008 signature. Been a tough year. Replaced medallion, compressor for leveling, 2 air bags on driver side forward, new tires, batteries, guess it is my time. Coach has set in Las Vegas for one year because of the Covid-19 virus. Oh yes the aqua hot worked on as well, new pump. The latest was discovered when I had the oll changed. Leaking oll from turbo exhaust side was found. Approx 7.5 k to replace with a new turbo including labor. Looking for any info as to same experience, cost, remedy,etc If you do need a Turbo, everything I have read for the ISX 600 is that it is a Holset VGT turbo. For the slight difference in price I would put a new one on. Is yours a CM870 or CM871? The CM870 had EGR only and the CM871 had EGR and a DPF (diesel particulate filter) Link to comment Share on other sites More sharing options...
