Scotty Hutto Posted June 28, 2021 Posted June 28, 2021 I need help sourcing steer axle brake drums for a 2006 Diplomat. I've been through 1) the Parts List, 2) the downloads section (LOTS of brake info - but nothing on drums) 3) the roadranger.com site (Bendix brakes), and multiple web searches with different search engines. The existing drums are corroded to the point where you can't see the part number. (15 years of road grime will do that.) We've also tried taking the drums to some local parts suppliers (Atlanta area). I've yet to find an exact match; the problem seems to be the three small bolt holes used to attach the drums to the hub before you put the wheels on. Otherwise they can match the drum dimensions. Any help appreciated.
Scotty Hutto Posted June 28, 2021 Author Posted June 28, 2021 5 minutes ago, Gerald H said: Did you try NAPA ?? Yes sir. No joy.
IlliniCathy Posted June 28, 2021 Posted June 28, 2021 We replaced ours and got the parts from source engineering when we replaced trailing arms. You might try them. They knew which parts we needed.
Chuck B 2004 Windsor Posted June 28, 2021 Posted June 28, 2021 Monaco purchased a complete front axle assembly back in those days. Check on the part of the axle facing the rear of the coach for the number. Chuck B 2004 Windsor
IlliniCathy Posted June 28, 2021 Posted June 28, 2021 Mechanic hubby says those 3 holes were for assembly line ease and not needed. It was used in factory only. Not needed for replacement. Be fine without. 1
Scotty Hutto Posted June 28, 2021 Author Posted June 28, 2021 1 minute ago, Chuck B said: Monaco purchased a complete front axle assembly back in those days. Check on the part of the axle facing the rear of the coach for the number. Chuck B 2004 Windsor Thanks Chuck. I have the steer axle assembly (I202BN201-1) and the Bendix brake assembly (ES-150-4L). Just not the drum. There is a "Hub & Drum Assembly", part number 975352, but I don't need the hub, and can't find the drum. 1 minute ago, IlliniCathy said: Mechanic hubby says those 3 holes were for assembly line ease and not needed. It was used in factory only. Not needed for replacement. Be fine without. Perfect!! That helps!!!
Guest Steven Posted June 28, 2021 Posted June 28, 2021 VEURINKS' RV CENTER 7144 S DIVISION AVE S GRAND RAPIDS, MI US 49548 616-281-5111 They are Monaco repair and parts center. Give them your vin number and they contact Monaco who has all the parts and manufacturers and parts number that went on your coach. They helped me with a replacement drag link assembly.
Scotty Hutto Posted June 28, 2021 Author Posted June 28, 2021 Found it! The drums are made by Webb Wheel Products, part number 65555B. https://www.webbwheel.com/online_catalog_drumdetail.php?dn=65555B Found them in Birmingham for $1k/ea. The local NAPA counter guy couldn't find it, but they do have them (pricey!!): https://www.napaonline.com/en/p/TWR65555B Now that I have the specific dimensions (and not worried about the three assembly holes) I'll find a cross available locally. Will post details once I have it. Thanks Everyone!! Looks like our July 1 trip is still on!!! (I was worried). Scotty
Jim Byrd Posted June 28, 2021 Posted June 28, 2021 (edited) Attached is a spreadsheet for the dimensions for a Webb 65555B drum and the one I installed on my Holiday Rambler Endeavor. The bolt hole diameter is a bit larger however spacers are available. Price for drum was $129 and free freight from FIND IT PARTS on line Spacer were about $40, can't remember where I purchased them, it was on line Hope this will help. Jim Brake Drum Comparison.xlsx Edited June 29, 2021 by Jim Byrd
Robert U Posted June 28, 2021 Posted June 28, 2021 Scotty Try Jacks Diesel. Talk to Gerry. They do a lot of brake work. Bob U 1
Scotty Hutto Posted June 28, 2021 Author Posted June 28, 2021 29 minutes ago, Robert U said: Scotty Try Jacks Diesel. Talk to Gerry. They do a lot of brake work. Bob U My coach is at Jack's as we speak having the front bearings replaced (I had a bad bearing) and new brake drums and shoes installed. Garrey was super helpful.
Bob Nodine Posted June 29, 2021 Posted June 29, 2021 10 hours ago, Scotty Hutto said: My coach is at Jack's as we speak having the front bearings replaced (I had a bad bearing) and new brake drums and shoes installed. Garrey was super helpful. Great Scotty. When you talked to me on the phone you did not tell me it was only the three small holes that were not on the substitute drums. I would have told you that they are not necessary. As the other poster said they only keep the drum in place when the wheel is off. No way that drum is going to come off when the wheel is on.
Frank McElroy Posted June 29, 2021 Posted June 29, 2021 Scotty, thanks for the info. I'll add it to the next parts list update.
JDStew Posted June 30, 2021 Posted June 30, 2021 I assume the drums are not turnable (machinable) to true? Just had my brakes (2003 Camelot 38PST - Roadmaster RR8S) replaced. The guys said they have never had to replace drums. I'd love to see pictures of your drums and what caused them to be unusable. 🙂
vanwill52 Posted June 30, 2021 Posted June 30, 2021 On 6/28/2021 at 2:46 PM, Scotty Hutto said: Found it! The drums are made by Webb Wheel Products, part number 65555B. https://www.webbwheel.com/online_catalog_drumdetail.php?dn=65555B Found them in Birmingham for $1k/ea. Scotty Scotty, that's where I found my drums for front of 2000 Dynasty several years ago. No, the three small holes don't matter, and neither does the size of the stud holes...the drums are hub-centered. To keep down the number of part numbers, at the time I bought them, they were available with only the largest available wheel stud hole. The drums are hub-centered, and the size of the wheel stud hole does not matter since the total clamping force of the wheel studs exceeds the braking torque available to make them "slip" on the hub.
Scotty Hutto Posted June 30, 2021 Author Posted June 30, 2021 3 hours ago, JDStew said: I assume the drums are not turnable (machinable) to true? Just had my brakes (2003 Camelot 38PST - Roadmaster RR8S) replaced. The guys said they have never had to replace drums. I'd love to see pictures of your drums and what caused them to be unusable. 🙂 Drums that large aren’t typically turned is what I’ve been told by those more knowledgeable than me. Unfortunately, I didn’t take pics, but the driver’s side front drum was cracked all the way through — you could see a big crack on the inside of the drum and the same crack - slightly less obvious - on the outside. I’m no expert, but I sure didn’t want to drive anywhere with it like that! The passenger side front looked to have gotten overheated, but no cracks.
Jim Byrd Posted June 30, 2021 Posted June 30, 2021 When I checked with Webb a couple of years ago they informed me that the 65555B was no longer in production and they didn't have an alternative drum. Mine wasn't tunable do to heat cracks and deep groove that exceeded max. ID.
Guest Steven Posted June 30, 2021 Posted June 30, 2021 Please all Veurinks 616-965-9633 give them your vin number and they will give you the replacement parts or get them for you. good luck, Steve.
