daveyjo Posted December 20, 2022 Share Posted December 20, 2022 I have a friend who has a 5th wheel, and pulls it with a pickup truck. In the truck bed she has a 3,750 watt generator with it's own starting battery, which she doesn't use often, but seems to often be discharged enough that the generator won't start. Jumper cables will get it started, put are a PITA. Is there some kind of regulated charger that she could hook up to her truck (say by plugging it into her cigarette lighter) that would charge her generator battery when the ignition is on? It just seems like asking for trouble to hard wire her generator battery in parallel with her truck battery. Dave Jones, 2005 Scepter Link to comment Share on other sites More sharing options...
JDCrow Posted December 20, 2022 Share Posted December 20, 2022 (edited) Sure, there are multiple companies that sell battery chargers for towables (RVI, I have one on my toad, Roadmaster also has be) she could splice off her cord going from truck to 5th wheel https://rvibrake.com/en-ca/pages/rvi-how-to-videos-towed-battery-charger-plus?msclkid=62911f4605c41b3cd5587ce738b521d8&utm_source=bing&utm_medium=cpc&utm_campaign=**LP DSA&utm_term=battery charger&utm_content=products (catch all) Edited December 20, 2022 by JDCrow Link to comment Share on other sites More sharing options...
Rocketman3 Posted December 20, 2022 Share Posted December 20, 2022 Yes a Victron Dc-dc charger would work - (there are others). Another way would be a small solar panel on the top of the generator (with a small solar charge controller. Link to comment Share on other sites More sharing options...
Gary 05 AMB DST Posted December 20, 2022 Share Posted December 20, 2022 She could buy a Halo battery jump (?), $125. It is easy to use and it can be used for other vehicles. Gary 05 AMB DST Link to comment Share on other sites More sharing options...
Tom Wallis Posted December 20, 2022 Share Posted December 20, 2022 You can hard wire it to the truck safely by adding a diode of the appropriate amperage to the positive wire. That does 2 things. It prevents any current flow from the generator battery to the truck and it will drop the charging voltage by 1/2 volt which helps prevent it from overcharging. 1 Link to comment Share on other sites More sharing options...
JDCrow Posted December 20, 2022 Share Posted December 20, 2022 I also bought this and carry it everywhere. Starts my diesel pickup as well as anything smaller SOLVTIN S6 Pro Max Battery Jump... https://www.amazon.com/dp/B0B2BWQW8T?ref=ppx_pop_mob_ap_share 11 minutes ago, Tom Wallis said: You can hard wire it to the truck safely by adding a diode of the appropriate amperage to the positive wire. That does 2 things. It prevents any current flow from the generator battery to the truck and it will drop the charging voltage by 1/2 volt which helps prevent it from overcharging. I believe the Roadmaster charge kit uses this Link to comment Share on other sites More sharing options...
Solution WayneC Posted December 20, 2022 Solution Share Posted December 20, 2022 I have a Yamaha emergency generator for the house ,I put fresh high grade gasoline with stabilzer in it every year ,run it on load once a year for an hour, 5 years now never a problem with the starting battery, Santa probably needs to bring her a new battery. Wayne 1999 Signature ceaser Link to comment Share on other sites More sharing options...
myrontruex Posted December 20, 2022 Share Posted December 20, 2022 Cigarette lighter charger Plug this into an outlet. Pre-wire the generator end with a matching 2 prong connector. It is not designed for jump starting of course, just charging. I built an end to end one for my wife to carry in her car many years ago. It worked quite well the couple of times it was needed. Just passed it between vehicles and plugged them in. In some cases the ignition key has to be on of course. About thirty minutes usually warms and wakes up a battery enough to spark things back to life. Link to comment Share on other sites More sharing options...
WayneC Posted December 20, 2022 Share Posted December 20, 2022 Missing the trees for the forest! Wayne 1999 Signature ceaser Link to comment Share on other sites More sharing options...
