ktloah Posted February 10, 2023 Share Posted February 10, 2023 Hello all, I know this has been discussed before, but after searching thru the files I haven't found what I'm looking for. Does anyone have the part#s for the rear brakes(drive axle) and drums? I am going to replace them this spring when we return home. It is the RR10s chassis. Thanks Link to comment Share on other sites More sharing options...
vito.a Posted February 10, 2023 Share Posted February 10, 2023 What length is your Dynasty? Our 42' Signature should be similar. It's an "S" series chassis. RR designates rear radiator and you have a side radiator. The drive axle brakes are disc. Link to comment Share on other sites More sharing options...
ktloah Posted February 10, 2023 Author Share Posted February 10, 2023 Thanks for the reply, my dynasty is 42', and it does have drum brakes on the rear. Steering axle has disc... 1 Link to comment Share on other sites More sharing options...
Idoc57 Posted February 11, 2023 Share Posted February 11, 2023 5 hours ago, vito.a said: What length is your Dynasty? Our 42' Signature should be similar. It's an "S" series chassis. RR designates rear radiator and you have a side radiator. The drive axle brakes are disc. Vito, I was under the impression that the RR stood for "Raised Rail" and the 10 in this case indicated how many air springs (bags) the chassis had. My Cayman has the RR4 chassis and only has 4 air springs, and it seems that I remember reading that there was also an R4 chassis, in which I would assume that the main structural rails that run front to back were not set as high in the construction of that chassis. I'm certainly no expert in this topic, but I would like to know if my assumption is correct. Thanks, Carey Link to comment Share on other sites More sharing options...
Michael Powell Posted February 11, 2023 Share Posted February 11, 2023 me too!!! Link to comment Share on other sites More sharing options...
96 EVO Posted February 11, 2023 Share Posted February 11, 2023 11 hours ago, Idoc57 said: Vito, I was under the impression that the RR stood for "Raised Rail" and the 10 in this case indicated how many air springs (bags) the chassis had. My Cayman has the RR4 chassis and only has 4 air springs, and it seems that I remember reading that there was also an R4 chassis, in which I would assume that the main structural rails that run front to back were not set as high in the construction of that chassis. I'm certainly no expert in this topic, but I would like to know if my assumption is correct. Thanks, Carey It does stand for raised rail. The 'r' or 's' at the end is the designation for rear or side radiator, ie... RR10(s) 2 Link to comment Share on other sites More sharing options...
vito.a Posted February 11, 2023 Share Posted February 11, 2023 Yes. You're right about RR. But the Dynasty, Executive, and Signature are built on the "S" series chassis. Attached is the Roadmaster chassis chart showing all the different versions. Roadmaster Chassis models.doc 1 Link to comment Share on other sites More sharing options...
ktloah Posted February 11, 2023 Author Share Posted February 11, 2023 So, I'm not sure how we got of the question about rear drum brakes on an 04 dynasty, but that was good info too Link to comment Share on other sites More sharing options...
ktloah Posted February 25, 2023 Author Share Posted February 25, 2023 Unfortunately my question wasn't answered. I will pull the wheels off in the spring and go from there with parts. Thank you to all those who responded. Link to comment Share on other sites More sharing options...
Happycarz Posted February 25, 2023 Share Posted February 25, 2023 Ronnie, on the bottom of the differential center section is a welded or glued on tag listing information about the rear axle. It might be covered with quite a bit of black Monaco paint. Take a look. Then you can call a truck parts store to see if that works for them. Also look at the drums for a number, most likely cast into the drum. If no one else chimes in, you might have to take the shoes and a drum to the parts store. 1 Link to comment Share on other sites More sharing options...
Guest Ray Davis Posted February 25, 2023 Share Posted February 25, 2023 (edited) Speaking of brake drums caused me to remember this post by Ed Jones that hopefully will help. " For got to add, any brake parts you need can be sourced at a Utility Trailer dealer. In my experience they have the parts and the best prices. I priced Webb drums a couple of days ago at our local Utility Trailer dealer and they were $150.00 each. " Here's the thread..... https://www.monacoers.org/topic/5025-parts-dealers/#comment-47235 Edited February 25, 2023 by Ray Davis Link to comment Share on other sites More sharing options...
ktloah Posted February 26, 2023 Author Share Posted February 26, 2023 Thank you Harry...I'll look for the tag after the snow stops... Link to comment Share on other sites More sharing options...
RIPPPA Posted September 7, 2023 Share Posted September 7, 2023 Ronnie did you get the parts you needed. If so, do you have the part numbers. I need to new rear shoes and drum per a shop here in N. Texas but I’m tired of waiting on them to do it. I have another guy that will do the work I just need to find the parts. TIA 1 Link to comment Share on other sites More sharing options...
ktloah Posted September 7, 2023 Author Share Posted September 7, 2023 I have not had the brakes replaced yet. I still have 25-30%. There should be a tag on your rear differential that will be helpful in getting parts. Good luck! Link to comment Share on other sites More sharing options...
RIPPPA Posted September 7, 2023 Share Posted September 7, 2023 ThamksRonnie did you get the parts you needed. If so, do you have the part numbers. I need to new rear shoes and drum per a shop here in N. Texas but I’m tired of waiting on them to do it. I have another guy that will do the work I just need to find the parts. TIA Link to comment Share on other sites More sharing options...
lake49068 Posted September 8, 2023 Share Posted September 8, 2023 Think this has been covered before. Check the ID tag on the axle (Rockwell/Meritor or Eaton/Dana). Both shipped "dressed axles" (complete with wheel ends/brakes/slacks/etc) to HR/Monaco. Contact customer support at the appropriate axle manufacturer's customer service line, provide the axle serial number and they should be able to call up all the components used to assemble that assembly. 2 1 Link to comment Share on other sites More sharing options...
Paul J A Posted September 8, 2023 Share Posted September 8, 2023 17 hours ago, lake49068 said: Think this has been covered before. Check the ID tag on the axle (Rockwell/Meritor or Eaton/Dana). Both shipped "dressed axles" (complete with wheel ends/brakes/slacks/etc) to HR/Monaco. Contact customer support at the appropriate axle manufacturer's customer service line, provide the axle serial number and they should be able to call up all the components used to assemble that assembly. Yep. Any good truck shop can do that, or order parts from that/those tag information . When a chassis issue, ALWAYS THINK TRUCK. 1 Link to comment Share on other sites More sharing options...
