Gazgreg Posted July 9, 2023 Share Posted July 9, 2023 (edited) So is the there a way to NOT deploy the entry steps? For instance when you are parked next to a curb. Edited July 9, 2023 by Gazgreg Link to comment Share on other sites More sharing options...
DavidL Posted July 9, 2023 Share Posted July 9, 2023 Well, on my Newmar, there is a switch...for just the reasons you speak of. Link to comment Share on other sites More sharing options...
Wrayj1 Posted July 10, 2023 Share Posted July 10, 2023 Greg, not likely. As you know you can keep them deployed when parked for a extended time, but no way to keep from deploying. When we stayed in AZ for 3-5 months we had a set of steps with handrail and small deck, I had to crawl under to unplug the coach steps. I had planned to insert a switch to turn off power to them, but we're selling so I won't be doing that. Link to comment Share on other sites More sharing options...
philcarrell Posted July 10, 2023 Share Posted July 10, 2023 Look at switches at the entry door Mine has one. Link to comment Share on other sites More sharing options...
MyronTruex Posted July 10, 2023 Share Posted July 10, 2023 I cannot defeat mine without unplugging them. It could be a real disaster to step out without them. They will just bump up against whatever is in the way and retract when you turn the ignition key. I can see some possible issues but none that outweighs the safety of stepping out into the open air. Link to comment Share on other sites More sharing options...
waterskier_1 Posted July 10, 2023 Share Posted July 10, 2023 You can not prevent the steps from opening the first time you open the door after shutting off the engine (or when the engine is running). This is a safety feature to allow passengers to exit the coach. After the first time, you can use the switch near the passenger seat to either keep the steps open all the time,. - Rick N Link to comment Share on other sites More sharing options...
Ivan K Posted July 10, 2023 Share Posted July 10, 2023 I used a magnetic tape over the door frame magnetic switch to cheat step and air bladder for troubleshooting. Like others said, you don't want to step into the air if forgotten... Link to comment Share on other sites More sharing options...
