JeffM31 Posted July 19, 2023 Share Posted July 19, 2023 Hi everyone, What sealant was this? The sealant between the 2 rubbers. The seal looks good but I can see light in one spot from the inside out. Don’t know if the windshield was ever replaced or not but the one corner sucks. As usual much appreciated for the help. Link to comment Share on other sites More sharing options...
96 EVO Posted July 19, 2023 Share Posted July 19, 2023 Some type of black Urethane. Whatever you use, don't use anything with silicone in it! Link to comment Share on other sites More sharing options...
JeffM31 Posted July 19, 2023 Author Share Posted July 19, 2023 3 minutes ago, 96 EVO said: Some type of black Urethane. Whatever you use, don't use anything with silicone in it! Thank you, I was thinking about using proflex Link to comment Share on other sites More sharing options...
Reka52 Posted July 19, 2023 Share Posted July 19, 2023 No don’t use proflex go to a glass shop and get the proper caulk or better yet take it to them it is a very minor job for a pro 1 Link to comment Share on other sites More sharing options...
Rick A Posted July 19, 2023 Share Posted July 19, 2023 I took my rig to a glass shop and they fixed it ands it’s perfect now. It took them 2 hours and it cost me $150 Cn$. 2 Link to comment Share on other sites More sharing options...
96 EVO Posted July 19, 2023 Share Posted July 19, 2023 25 minutes ago, Rick A said: I took my rig to a glass shop and they fixed it ands it’s perfect now. It took them 2 hours and it cost me $150 Cn$. That looks like Urethane 👍. 1 Link to comment Share on other sites More sharing options...
LakeBob Posted July 19, 2023 Share Posted July 19, 2023 Yep, use urathane. I used https://www.amazon.com/Windshield-Urethane-Sikaflex-Primerless-Adhesive/dp/B073WKD2C9/ref=mp_s_a_1_3_pp?crid=3OS4L49EWXZ2Y&keywords=urethane&qid=1689792130&sprefix=urathane%2Caps%2C104&sr=8-3 works well, however you need a special caulk gun and the stuff is a pain to apply for a novice. Don’t get it on you or your clothes! 3 Link to comment Share on other sites More sharing options...
DavidL Posted July 19, 2023 Share Posted July 19, 2023 wouldn't it be nice if they used some blue tape on the glass, injected the urethane, and used a finger to get rid of the bogs and then remove the tape for a finish edge... 6 Link to comment Share on other sites More sharing options...
Robert U Posted July 19, 2023 Share Posted July 19, 2023 Black urethane can be purchased at auto parts store. You can lay down blue tape and smooth out the sealer as you go. These glass guys don't care how it looks. 3 Link to comment Share on other sites More sharing options...
Johnny Mo Posted July 19, 2023 Share Posted July 19, 2023 I recently had my windshield replaced. I didn't like how the rubber gutter above the windshield looked, just like yours Jeff. So I took it off and re-applied it. I stripped off the old mounting tape from the rubber and applied 3M VHB HD mounting tape. I recommend using 3M Tape Primer on the rubber before applying the tape and on the fiberglass otherwise it will not stick very well, mainly to the rubber. When you attach the rubber leave about an 1/8" gap so you can put a bead of urethane sealant. I used what the installer used, Sikaflex P2G. Use masking tape and take your time applying urethane, you do not want to over do it as it is very messy. I used spray foam window cleaner after applying a bead and tooled it with my finger. I bought everything off Amazon 2 Link to comment Share on other sites More sharing options...
Tom Whitlow Posted July 19, 2023 Share Posted July 19, 2023 We have the same problem. Our windshield even leaks slightly. We had a glass shop look at it - twice. The glass tech said our entire windshield had shifted slightly to one side. He said he did a temporary reseal. Didn't work, still leaking. We have a small chip also that is growing slowly. When it gets big enough, I guess we'll just get a new windshield. 1 Link to comment Share on other sites More sharing options...
Martinvz Posted July 19, 2023 Share Posted July 19, 2023 In April I had a glass service delivered to some window sealing and he also looked at the windshield seal. I am not sore what he used but he did seal it and said they often do it. What he did was to lift the outside rubber and applied the caulking under it to seal it to the windshield. The jury is still out if this is the right solution. 1 Link to comment Share on other sites More sharing options...
96 EVO Posted July 19, 2023 Share Posted July 19, 2023 Believe the proper method is to seal the gasket to the body, but allow the glass to float in the gasket. 4 Link to comment Share on other sites More sharing options...
JeffM31 Posted July 19, 2023 Author Share Posted July 19, 2023 Well, upon further inspection I spotted a spot about 9 inches long on the inside above the drivers seat where the seal was not in place around the bend. Got it back in place and the light is gone. I still ordered some urethane for where the two rubbers meet though. Thank you everyone. 3 Link to comment Share on other sites More sharing options...
TW Racing Posted July 20, 2023 Share Posted July 20, 2023 1 Link to comment Share on other sites More sharing options...
JeffM31 Posted July 20, 2023 Author Share Posted July 20, 2023 7 hours ago, TW Racing said: Awesome, Thank you Link to comment Share on other sites More sharing options...
Chuck B 2004 Windsor Posted July 22, 2023 Share Posted July 22, 2023 Which ever sealant you use, be sure that it cures flexible, or it will crack the windshield. Chuck B 1 Link to comment Share on other sites More sharing options...
