terboggs Posted January 2 Share Posted January 2 Monoco Executive 2001 , is there a replacement for this Link to comment Share on other sites More sharing options...
DavidL Posted January 2 Share Posted January 2 12 minutes ago, terboggs said: Monoco Executive 2001 , is there a replacement for this Most any faucet can be a replacement. I think I see some printing on the nozzle...likely the manufacturer (Delta / Moen / Kohler etc) You can use that to track down the exact one (if still available) Link to comment Share on other sites More sharing options...
Dr4Film Posted January 2 Share Posted January 2 Nothing special about these faucets. Choose a replacement that you like that will fit the holes in your Corian Vanity Top. Link to comment Share on other sites More sharing options...
Donflem Posted January 2 Share Posted January 2 If that’s a moan you can just replace the cartridge and good as new. I’m actually on my way to Home Depot today to get one for my shower. Don Link to comment Share on other sites More sharing options...
terboggs Posted January 2 Author Share Posted January 2 its leaking water, does a bad catridge cause that, and where is one located on the faucet? Link to comment Share on other sites More sharing options...
timaz996 Posted January 2 Share Posted January 2 3 minutes ago, terboggs said: its leaking water, does a bad catridge cause that, and where is one located on the faucet? Yes Link to comment Share on other sites More sharing options...
Donflem Posted January 2 Share Posted January 2 Yes it’s a bad cartridge call Moen 800-289-6636 tell them what model you have if you don’t have the model number they will have you text a picture when you’re on the phone and send you the part you need. I just hung up with them they are sending me a new cartridge. Don Link to comment Share on other sites More sharing options...
Dr4Film Posted January 2 Share Posted January 2 There are plenty of YouTube videos showing how to change out a Moen Cartridge. I had to change a cartridge in both the kitchen and one of the vanity faucets this winter in our Dynasty. Link to comment Share on other sites More sharing options...
terboggs Posted January 2 Author Share Posted January 2 Do the Gerber Faucets have the cartrige Link to comment Share on other sites More sharing options...
Dr4Film Posted January 2 Share Posted January 2 Never heard of that brand of faucet. I stick to either Moen or Delta faucets. Link to comment Share on other sites More sharing options...
StephenW Posted January 2 Share Posted January 2 All single handle faucets have a cartridge. As stated by Donflem if it is a Moen they have a lifetime warranty. I’m not sure about Gerber faucets and any warranty. If you could find the faucet brand and model, you should be able to find a replacement part. A new cartridge should stop any leaking. While changing the cartridge be sure to use a good O-ring food grade silicone lubrication. Link to comment Share on other sites More sharing options...
NormMel Posted January 3 Share Posted January 3 We switched to this faucet from Amazon. The drain plug that comes with doesn't work with this sink, so we opted for a screen, we don't use the plug feature so it didn't matter to us. Prefer the cascade water flow.🙂 Link to comment Share on other sites More sharing options...
VinceB Posted January 3 Share Posted January 3 Just recently replaced the cartridge in my kitchen faucet. Took the old cartridge to Ace Hardware and the rep knew just what I needed. Love Ace... The kit will have everything you need - change out everything while you have it apart. The O-rings for the spout would not work so I had to use 2" slip joint washers for the spout because it is an off-brand/Delta knock off faucet. YMMV. Link to comment Share on other sites More sharing options...
