Tillman111 Posted January 24 Share Posted January 24 Hi everyone... my coach is a 2002 Holiday Navigator 40PBDD on a roadmaster chassis. Per the tire placard tires size is 295/80/22.5. After further researched I opted to change the steer tires to 315/80/22.5. I am happy to report the ride is alot nicer as is my peice of mind with a bigger 20 ply steer tire. The down side of this is now my abs light is on which I am certain has to do with wheel speed sensors since the front tires are larger than the rear. I pulled some blink codes so far 4 6 17 are the main codes I am getting. My question to the group - I have heard of many others doing this change to steer tires. Is there programming I should have done to account for the difference in tire size? Thanks for the help! Link to comment Share on other sites More sharing options...
vito.a Posted January 24 Share Posted January 24 (edited) Interesting. I've changed three Monaco coaches over from 295 to 315 front tires and not had an issue with the ABS. I'm not sure the ABS system cares about the tire circumference, only that it's rolling and not locked up. An active handling system does care about tire circumference but we do not have that system. Have you tried depressing the ABS reset switch? Edited January 24 by vito.a 1 Link to comment Share on other sites More sharing options...
Frank Bergamo Posted January 24 Share Posted January 24 Also, make sure the sensors are seated on the tone rings. All it takes is a light tap to seat them. Hope this helps. 1 Link to comment Share on other sites More sharing options...
Tillman111 Posted January 25 Author Share Posted January 25 Thanks guys. Inspected the sensors and harness nothing obvious stands out. The sensor seems to be seating correctly. I have not tried to clear the light using the button yet. On that note do you have an idea where I can find that procedure? 1 Link to comment Share on other sites More sharing options...
Ivan K Posted January 25 Share Posted January 25 Do you know what ABS system you have? My codes come in pairs, for instance 4-6 would be left rear sensor. I had 17-1 and it was a broken retarder relay wire, so it depends... Link to comment Share on other sites More sharing options...
MHRookie Posted January 25 Share Posted January 25 7 hours ago, Ivan K said: Do you know what ABS system you have? My codes come in pairs, for instance 4-6 would be left rear sensor. I had 17-1 and it was a broken retarder relay wire, so it depends... What device are you using to retrieve codes? 1 Link to comment Share on other sites More sharing options...
Ivylog Posted January 25 Share Posted January 25 Have put 315s on the front of 2 rigs without any ABS issues, the larger diameter isn’t your problem. I’m a little surprised they fit on a 40’ coach as it was a tight fit on our 42’ Dynasty and plenty of room on our 45’. Link to comment Share on other sites More sharing options...
Tillman111 Posted January 25 Author Share Posted January 25 I have to try and find the brand of my abs system although I think I am getting blink codes in pairs as well. MHrookie I am retrieving codes using the abs push button that lets the system send blink codes. Ivylog they fit but it was close! I just can not believe the coincidence. Just after tire install light came on. The investigation continues! Link to comment Share on other sites More sharing options...
Ivan K Posted January 25 Share Posted January 25 1 hour ago, MHRookie said: What device are you using to retrieve codes? Diagnostic push button under the dash in my case, blink codes. Others have it in FRB so it depends on the system. 1 Link to comment Share on other sites More sharing options...
Paul J A Posted January 25 Share Posted January 25 (edited) The guys at https://sourcerv.com/ may know what system you have. Worth a call. Edited January 25 by Paul J A Link to comment Share on other sites More sharing options...
dl_racing427 Posted January 26 Share Posted January 26 Are 315-75/R22.5 not available? I'd think that would be a better match as far as diameter goes. Link to comment Share on other sites More sharing options...
