powersltc Posted March 15, 2024 Posted March 15, 2024 Ron P., 2004 Monaco Executive I have no taillights and clearance lights. I have brake lights and turn signals. Can someone help me locate the fuse that controls the taillights and clearance lights. Ron P. 2004 Monaco Executive
cbr046 Posted March 15, 2024 Posted March 15, 2024 If the fuse checks out ok consider this jumper I just found today inside the steering housing. The burnt part is the headlight jumper. The other jumper is for parking and marker lights. Just something to consider. - bob
timaz996 Posted March 15, 2024 Posted March 15, 2024 You also might want to check the back of your light switch to make sure nothings melted or burnt wires.
powersltc Posted March 15, 2024 Author Posted March 15, 2024 Ron P. 2004 Monaco Executive. I'm looking for the fuse.
ktloah Posted March 15, 2024 Posted March 15, 2024 Try the compartment under the drivers seat...left front box in front of the tire.. 1
powersltc Posted March 15, 2024 Author Posted March 15, 2024 Hello. I appreciate the information. I have checked each fuse in the run box and all are working. Stumped.
MyronTruex Posted March 15, 2024 Posted March 15, 2024 14 hours ago, cbr046 said: If the fuse checks out ok consider this jumper I just found today inside the steering housing. The burnt part is the headlight jumper. The other jumper is for parking and marker lights. Just something to consider. - bob Time to consider a headlight relay kit to get rid of the heavy load on light wires and old connections. 1 1
Oldgoat Posted March 15, 2024 Posted March 15, 2024 If the front checks out there is another panel in the engine compartment.
