Jeff sams Posted March 24 Share Posted March 24 Looking to replace interior lights in 2004 Monaco dynasty . Has small recessed lights throughout coach and they get very hot looking to replace with LED any suggestions? Link to comment Share on other sites More sharing options...
Tom Wallis Posted March 24 Share Posted March 24 I replaced mine with these LEDs from Amazon and I really like them. https://www.amazon.com/gp/product/B00ODVEWPG/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1 Link to comment Share on other sites More sharing options...
Ivylog Posted March 24 Share Posted March 24 (edited) Having gone LED in a 04 Dynasty 18 years ago… reducing the amps from 32 to 4 (all 32 ceiling lights on) you want G4 12SMD 5050 bulbs in warm white (3000 temp) or daylight (5000 temp). Daylight wasn’t available even 10 years ago and it’s my preference today for inside. I sometimes use bright white (7000 temp) outside, but it’s too bluish for many situations. Over the years I’ve experimented with various LEDs and the 5050 chips run the coolest. Cut half the length of the pins off and bend in slightly. Use a flashlight to help get the pins in the small holes. The only LEDs I’ve had poor service out of are the strips so I use panels with 48 SMD 5050 chips. 12 bulbs for $17 on Amazon… $14 ones are 7000 temp and too blue. https://www.amazon.com/EverBrightt-12-Pack-Camper-Reading-Marine/dp/B00NNJF1FO/ref=mp_s_a_1_1_sspa?dib=eyJ2IjoiMSJ9.MZEFGUGP2wJxHt1ZfjFdnZKiGMpoeekRXOd_dZd5iZQKdSAhoH8wPMtl85JfTUi-Nv4TIjsJ-8tw-9YcludpGys3ledjkVSzFtUlILlGwSubPJa6xGJMT3qPNCl6urVd--D_ylJxyvJ5ajNszsYL7GwyBxQ6TRY4Bh0iyr6wooONer9ABWGBJAZ2tQmJ7eV_azsIB_eZqzs5LnW7rTeVTw._QkBguEsjZb4Agxj72wRMeF7OgHwka5L0y2Ls1Y6SWk&dib_tag=se&keywords=g4+super+bright+flat+lights+12+5050+smd+car+led+light+bulb+lamp+dc12v+2w&qid=1711296104&sr=8-1-spons&sp_csd=d2lkZ2V0TmFtZT1zcF9waG9uZV9zZWFyY2hfYXRm&psc=1 Edited March 24 by Ivylog Link to comment Share on other sites More sharing options...
jacwjames Posted March 24 Share Posted March 24 Here is an older post Link to comment Share on other sites More sharing options...
joefromperry Posted March 24 Share Posted March 24 (edited) Almost done changing all the puck lights from halogen to LED in my 2003 Signature. These are what I got from Amazon, 2700K, dimmable. Only adjustment I made was trimming just a smidge off the length of the bi-pins: https://www.amazon.com/OLÉ-Lighting-Flicker-Non-dimmable-Energy/dp/B0BFCM51B6/ref=sr_1_1?crid=2LYEB9MNR6QQ9&dib=eyJ2IjoiMSJ9.JYq8vnhGRpbe21XNgtjo5Jobk9-I3Z9oC3sA8Q9jAbQXHGuHKL5Tlbj9NWaJEL5h43GisBVWHudteTEswnjNMYsOlDs-4LsRLV0tu7YNfDL2zEBrZVMXQzB9S150CTE1JZMoyBx3ueHUK7A7pGrGbglSgI-GtPvUGdvMNn0wn_Nril0_YIAHqNpr-isw_yIq7JJZD3DaBRd8T4e5lJgHu9gvPxakOiOey5LXbInUiyTz0cX8izsm9du2HprJGbzG9F3-9VaxKTfKrm3fT5PTWJm_ljqH7zvzjqnlHCmoc3k.kP6xGA9ymWLlNrJCzpncycS6vCzDbAkgpy714CLZvvs&dib_tag=se&keywords=G4%2BLED%2BBulbs%2B2W%2BWarm%2BWhite%2BLED%2BBulb%2B2700K%2C%2B200LM%2BG4%2BLED%2BBulb%2B12V%2BAC%2FDC%2B180°%2BBeam%2BNo%2BFlicker%2BDimmable%2BEnergy%2BSaving%2BLamp%2BG4%2BBulb%2B(8%2BPacks)&qid=1711310183&sprefix=g4%2Bled%2Bbulbs%2B2w%2Bwarm%2Bwhite%2Bled%2Bbulb%2B2700k%2C%2B200lm%2Bg4%2Bled%2Bbulb%2B12v%2Bac%2Fdc%2B180%2Bbeam%2Bno%2Bflicker%2Bdimmable%2Benergy%2Bsaving%2Blamp%2Bg4%2Bbulb%2B8%2Bpacks%2B%2Caps%2C87&sr=8-1&th=1 What a big difference in brightness; these are 200 lumen, and going from 20 watts/bulb to 2 not only saves battery, but a whole lot less heat per puck. I did all the puck lights in the coach, living room and bedroom. Edited March 24 by joefromperry added info Link to comment Share on other sites More sharing options...
Jeff sams Posted March 24 Author Share Posted March 24 Thanks guys! This forum is awesome! Link to comment Share on other sites More sharing options...
ktloah Posted March 24 Share Posted March 24 Got mine replaced thru M4 Products....great people Link to comment Share on other sites More sharing options...
Mocephus Posted March 25 Share Posted March 25 I installed these. Bright white. They have worked well so far: https://a.co/d/gmmEVLf 1 Link to comment Share on other sites More sharing options...
amphi_sc Posted March 25 Share Posted March 25 (edited) If your existing Halogen bulbs are dimmable make sure you get dimmable LED that won't flicker. I went with 20w equivalent pucks that were a little whiter than the yellowish Halogen but be careful about going too blueish. Probably 10w equivalent is fine for the BR as I end up dimming those down, but like the full 20W brightness in the LR. (My source from 8 years ago doesn't seem to be around anymore or changed their domain name.) Edited March 25 by amphi_sc Link to comment Share on other sites More sharing options...
rustykramermetalfab Posted March 25 Share Posted March 25 https://www.amazon.com/dp/B0B861854J?psc=1&ref=product_details I use these in all my puck lights now. I really like the 4000K they are white or clear? My wife does not like the warm 3000K lights anywhere. It just depends on the interior colors of your rig and what you like. These run nice and cool also. Link to comment Share on other sites More sharing options...
Joint Venture Posted March 25 Share Posted March 25 (edited) I changed all our ceiling 3" puck lights with these from Amazon. https://www.amazon.com/Facon-3Inch-Aluminum-Recessed-210Lumens/dp/B06XR85Y7B?pd_rd_w=hMj49&content-id=amzn1.sym.f2d28eb3-77c3-4c91-a745-724ad4914c8c&pf_rd_p=f2d28eb3-77c3-4c91-a745-724ad4914c8c&pf_rd_r=P3D6ZJDVKFPDN635526S&pd_rd_wg=4xGS7&pd_rd_r=a8f4db35-00f7-45dc-a141-67ed2fdad2af&psc=1&ref_=pd_bap_d_csi_rtpb_bap_sim_0_t They were pretty easy to install and a direct replacement for OEM. Edited March 25 by Joint Venture Link to comment Share on other sites More sharing options...
terboggs Posted April 7 Share Posted April 7 will these options work on a 2001 Monico execitive Link to comment Share on other sites More sharing options...
Joint Venture Posted April 7 Share Posted April 7 On 3/25/2024 at 1:25 PM, Joint Venture said: I changed all our ceiling 3" puck lights with these from Amazon. https://www.amazon.com/Facon-3Inch-Aluminum-Recessed-210Lumens/dp/B06XR85Y7B?pd_rd_w=hMj49&content-id=amzn1.sym.f2d28eb3-77c3-4c91-a745-724ad4914c8c&pf_rd_p=f2d28eb3-77c3-4c91-a745-724ad4914c8c&pf_rd_r=P3D6ZJDVKFPDN635526S&pd_rd_wg=4xGS7&pd_rd_r=a8f4db35-00f7-45dc-a141-67ed2fdad2af&psc=1&ref_=pd_bap_d_csi_rtpb_bap_sim_0_t They were pretty easy to install and a direct replacement for OEM. Depends, if yours are 3" puck lights then mine will work just fine. Link to comment Share on other sites More sharing options...
