rambler07 0 Posted November 14, 2020 Share Posted November 14, 2020 What type of should be used on a fiberglass or metal roof ? 1 minute ago, rambler07 said: What type of paint or coating should be used on a fiberglass or metal roof ? Link to post Share on other sites
Scotty Hutto 140 Posted November 14, 2020 Share Posted November 14, 2020 @throgmartin is certainly the resident expert on this... His recommendation for Fiberglass roofs at the Gathering in Feb 2020 is: Prep with Dicor RP-FCP-1 Clean and Prep Coat with Dicor RP-FRC-1 Fiberglass RV roof Coating. I believe he said a gallon of each should handle the roof of a 40’ coat. But I’m sure he’ll correct me if I’m wrong. 😂 I can’t speak to metal roofs. 1 1 Link to post Share on other sites
96 EVO 21 Posted November 15, 2020 Share Posted November 15, 2020 Rust-oleum Marine Topside paint get's good reviews as well. Link to post Share on other sites
Monte Roger Fautin 0 Posted January 3 Share Posted January 3 Is the painting sprayed or brushed? Link to post Share on other sites
Chargerman 34 Posted January 4 Share Posted January 4 I did Rustoleum Deck Over Paint. Two coats. It’s a great product and 4 years later it looks like I just put it on. Prep is key. It is applied with a roller and brush. Thorough cleaning, assuring all chalking/ sealing is in good condition and masking the paint line. I overlapped the old paint line by 1/4” or so to assure the edge was sealed. I now wash my roof once or twice a year with a mild soap and a soft brush. Link to post Share on other sites
Dr4Film 127 Posted January 4 Share Posted January 4 (edited) I hired a painter who was familiar with using elastomeric paint. He put multiple coats of Tuff-Coat White Rubberized (UT-100SR (Smooth Rubber Fine Textured Coating) on a well prepped roof back in 2014. Still looks the same as the day it was completed after numerous power pressure washings. https://tuffcoatmarine.com/ Edited January 5 by Dr4Film 1 Link to post Share on other sites
Rikadoo 1 Posted January 10 Share Posted January 10 I just completed painting my metal roof with Henrys TropiCool, from Home Depot first I cut in all the sides, air conditioners, sky light, vents then used a roller, I put two coats total. I watched several you tube videos to convince myself "I can do it!!!" The reason for doing it myself was due to the amount of $$$ company wanted to do it. it was a lot easier than I thought it would be... If I was to say one thing to make it go easier, have a good ground crew to help. 1 Link to post Share on other sites
dl_racing427 36 Posted January 10 Share Posted January 10 4 hours ago, Rikadoo said: I just completed painting my metal roof with Henrys TropiCool, from Home Depot first I cut in all the sides, air conditioners, sky light, vents then used a roller, I put two coats total. I watched several you tube videos to convince myself "I can do it!!!" The reason for doing it myself was due to the amount of $$$ company wanted to do it. it was a lot easier than I thought it would be... If I was to say one thing to make it go easier, have a good ground crew to help. So true on the ground crew. It seems that whenever I go to do something that's up high or otherwise difficult to access, I end up going back 14 times to grab just one more tool that I forgot to get the first time. LOL 1 Link to post Share on other sites
Jim Bob 3 Posted January 11 Share Posted January 11 I used the Dicor products on my roof this summer and it turned out great. The application of the paint is the easy part... you just roll it on and let it dry for about 3 hours then apply another coat. timing is key as its not supposed to get wet, even with dew. The hard part is the prep. I cleaned the roof, removed old sealants, etc. then sanded with two different grits of sandpaper, then washed with the special Dicor product. Taping up the entire coach and enclosing with plastic is important as the Dicor wash will mess with your paint and other surfaces. I would not say its an easy job at all. If not for being couped up in the house due to Covid I most likely would have hired it done. I'm getting a bit to old to be climbing a ladder and working on a slippery roof. Again, the finished product looks good, but its not a quick or easy job. 1 Link to post Share on other sites
