bmulvenna@hotmail.com Posted April 2, 2021 Share Posted April 2, 2021 2004 Dynasty. Docking lights fuse blows as soon as switch is turned on. Remove 2 rear docking light bulbs. Replace fuse, turn on switch and 2 front dock lights work fine. Place bulbs back in rear and the fuse blows again. Any thoughts are appreciated. Link to comment Share on other sites More sharing options...
John Haggard Posted April 2, 2021 Share Posted April 2, 2021 You got it narrowed down. Maybe a ground issue ??? Remove the left rear bulb 💡 and try. Then the right rear bulb 💡 and try 1 Link to comment Share on other sites More sharing options...
bmulvenna@hotmail.com Posted April 2, 2021 Author Share Posted April 2, 2021 2004 Dynasty. Docking lights fuse blows as soon as switch is turned on. Remove 2 rear docking light bulbs. Replace fuse, turn on switch and 2 front dock lights work fine. Place bulbs back in rear and the fuse blows again. Any thoughts are appreciated. Link to comment Share on other sites More sharing options...
klcdenver Posted April 2, 2021 Share Posted April 2, 2021 I would take all the bulbs out and mark them. Start putting one front bulb in the rear sockets one at a time and check. If you fave multi meter you can check the rear bulbs for a short. Probably have shorted element in a rear bulb. Good luck Link to comment Share on other sites More sharing options...
HarleyR Posted April 2, 2021 Share Posted April 2, 2021 It sounds like a short in one of the rear lamp sockets may me the culprit. Test one, then the other. Possibly a bad socket or a bare wire short circuit behind the socket. Link to comment Share on other sites More sharing options...
Pepperell Posted April 2, 2021 Share Posted April 2, 2021 Anyone have an led substitute for the oval ones? I’m thinking of trying a 6” oval truck led via the McGyver method. Link to comment Share on other sites More sharing options...
Dennis H Posted April 2, 2021 Share Posted April 2, 2021 (edited) The lights are easy enough to check. Look underneath first and look for a frayed wire. You could swap one of the front bulbs with a rear one and test them that way. You are talking about the side lights, right? Not the two on the rear of the coach.....Dennis Edited April 2, 2021 by Dennis H Link to comment Share on other sites More sharing options...
bmulvenna@hotmail.com Posted April 2, 2021 Author Share Posted April 2, 2021 40 minutes ago, Dennis H said: The lights are easy enough to check. Look underneath first and look for a frayed wire. You could swap one of the front bulbs with a rear one and test them that way. You are talking about the side lights, right? Not the two on the rear of the coach.....Dennis Thanks. Yes. The sides, bad fixture was shorted out when bulb was inserted. Link to comment Share on other sites More sharing options...
Harvey Babb Posted April 3, 2021 Share Posted April 3, 2021 Could be a shorted bulb. Rare, but it happens. Link to comment Share on other sites More sharing options...
bmulvenna@hotmail.com Posted April 3, 2021 Author Share Posted April 3, 2021 (edited) Found a bad housing. It was shorting out when a bulb was inserted. Ordered a new one from NW rv supply. Thanks for the help. Mike Edited April 3, 2021 by bmulvenna@hotmail.com Spelling Link to comment Share on other sites More sharing options...
