RekaAnn$ Posted October 10, 2021 Share Posted October 10, 2021 We took our coach to a chassis repair due to a constant alarm we could not stop‼️It took all day but they got the alarm stopped‼️In reading the repair order they only removed the alarm buzzer‼️We drove 200 miles without incident ‼️Should we be concerned about this alarm? Really perplexed as what to do‼️ Rekaann ‘04 Holiday Rambler Endeavor 36 Link to comment Share on other sites More sharing options...
DavidL Posted October 10, 2021 Share Posted October 10, 2021 (edited) what alarm was it for? reverse? Slides moving? Engine? Alarm clock? Need more info. I would be concerned if they just disconnected the "alarm" to silence it. they need to find out WHY the alarm was signaling. Edited October 10, 2021 by DavidL 1 Link to comment Share on other sites More sharing options...
waterskier_1 Posted October 10, 2021 Share Posted October 10, 2021 I'd be very concerned. You don't know what was making the alarm, so don't know if you still have a problem. It's the same idea as pulling out all the warning bulbs in the dash so you won't be bothered by them. -Rick N. 1 Link to comment Share on other sites More sharing options...
Chuck B 2004 Windsor Posted October 10, 2021 Share Posted October 10, 2021 So you drove 200 miles without an incident with the alarms disconnected. What if you had a alarm generating incident and did not get a warning? Hummmmmmmmmmm! Your coach, your money. Chuck B 2004 Windsor Link to comment Share on other sites More sharing options...
ncsteve Posted October 10, 2021 Share Posted October 10, 2021 If it was the low air alarm, I would be alarmed. 2 Link to comment Share on other sites More sharing options...
RekaAnn$ Posted October 10, 2021 Author Share Posted October 10, 2021 It was‼️Any suggestions ? TIA Link to comment Share on other sites More sharing options...
Chuck B 2004 Windsor Posted October 10, 2021 Share Posted October 10, 2021 How did you know? Your alarm was disconnected. Chuck B 2004 Windsor Link to comment Share on other sites More sharing options...
RekaAnn$ Posted October 10, 2021 Author Share Posted October 10, 2021 We don’t know what the alarm was for! All our gauges were fine no low air light on We’ve taken it to three different shops to find cause for alarm! We thought they had fixed it! Now what to do? Link to comment Share on other sites More sharing options...
Flyinhy Posted October 10, 2021 Share Posted October 10, 2021 If it was the low air alarm.....hook it back up. See if while applying the brakes you have a steady loss of air. Link to comment Share on other sites More sharing options...
redstickbill Posted October 10, 2021 Share Posted October 10, 2021 Have the shop reconnect the alarm, then find a shop that knows how to work on a motorhome. As Chuck wrote, your coach, your money. Bill B 07 Dynasty Link to comment Share on other sites More sharing options...
Skipjack Posted October 11, 2021 Share Posted October 11, 2021 (edited) Did the alarm only come on after driving a little way, and getting up to temp? I had this happen to me, and found out that the temp sending unit was just a little too sensitive. While my engine temp is perfect, I tend to get the alarm when going up hill. I tried replacing the alarm module. (See picture). This module has five inputs, and one of them is the engine temp. the module is just behind the dash. not sure if that’s your problem, but this it what I had Edited October 11, 2021 by Skipjack Alarm module Link to comment Share on other sites More sharing options...
RekaAnn$ Posted October 11, 2021 Author Share Posted October 11, 2021 (edited) Thank you for the pictures & advice! It’s hard finding component shops to work on our Big Girl! Betty A 04 HR Endeavor 36 06 Jeep Wrangler Edited October 11, 2021 by RekaAnn$ Link to comment Share on other sites More sharing options...
RekaAnn$ Posted October 11, 2021 Author Share Posted October 11, 2021 The alarm comes on after the air brake is released & never stops beeping until air brake is in park! No low air light on the dash‼️ Any suggestions on work shops in Oklahoma? ‘04 HR Endeavor 36 06 Jeep Wrangler Link to comment Share on other sites More sharing options...
Scotty Hutto Posted October 11, 2021 Share Posted October 11, 2021 Betty, Based on the above comment, it sounds like one possibility is that you might be getting an alarm from the “jacks down” signal from your jacks. That is one scenario that would cause the behavior you mention. (Alarm starts when parking brake is released, stops when it is applied) When you release the parking brake, do you get any flashing lights on the jack control panel? You may also have a bad Nason switch on your parking brake air valve. That switch can go bad, and create an issue similar to the one you describe. See the following link for more about that: The good news is that this is not an expensive part, and any decent truck or RV mechanic should be able to replace it. Hope this helps! Link to comment Share on other sites More sharing options...
cbr046 Posted October 11, 2021 Share Posted October 11, 2021 1 hour ago, RekaAnn$ said: The alarm comes on after the air brake is released & never stops beeping until air brake is in park! No low air light on the dash‼️ Any suggestions on work shops in Oklahoma? ‘04 HR Endeavor 36 On our 03 Endeavor the air alarm was totally silent for 7 months, even with no air pressure. Then one day it was constant until aired up and driven a bit (air pressure would build up and maintain). The last 2 months the air alarm seems to work as it should (while building air) and comes on if I set the parking brake with transmission still in drive / reverse. It's my habit to set the brake first, then tran to neutral. I can live with that . . . . not sure about the wife. 😄 But as others have said, you need to know what alarm was disconnected, and especially need to know if you fall below minimum air pressure *BEFORE* you start descending a downhill grade, or heavy traffic, or . . . . - bob Link to comment Share on other sites More sharing options...
redstickbill Posted October 11, 2021 Share Posted October 11, 2021 (edited) Betty, The Nason switch is a fairly easy do it yourself job. Bill B 07 Dynasty Edited October 11, 2021 by redstickbill Link to comment Share on other sites More sharing options...
RekaAnn$ Posted October 11, 2021 Author Share Posted October 11, 2021 Thank y’all for all the input. We did find the part they removed under the drivers seat. Now to find a shop to work on her. 04 Endeavor 36’ PST Link to comment Share on other sites More sharing options...
RekaAnn$ Posted November 29, 2021 Author Share Posted November 29, 2021 Update on Nason Switch it was the Nason switch went bad‼️Thanks for all the help from this forum‼️ Link to comment Share on other sites More sharing options...
Bjohnsonmn Posted March 4, 2022 Share Posted March 4, 2022 On 10/10/2021 at 1:27 PM, waterskier_1 said: I'd be very concerned. You don't know what was making the alarm, so don't know if you still have a problem. It's the same idea as pulling out all the warning bulbs in the dash so you won't be bothered by them. -Rick N. This only works and is acceptable on Jeeps. 🙂 (I am a Jeep fan) 1 Link to comment Share on other sites More sharing options...
