LarryB Posted November 20, 2021 Share Posted November 20, 2021 Howdy friends, I need help w locating the inverted pwr ckt. to add the outlet on the southern side of our bed for my wife’s CPAP machine. We have an 07 Dip PDQ. Link to comment Share on other sites More sharing options...
FHWilliams57 Posted November 20, 2021 Share Posted November 20, 2021 I did some research on this and found that while some wiring diagrams may suggest that the receptacles at the nightstands are on inverter power, I have confirmed that mine are not. The TV and dresser receptacles are so may need a extension cord. 2008 Monaco Diplomat SKQ Link to comment Share on other sites More sharing options...
Dr4Film Posted November 20, 2021 Share Posted November 20, 2021 Unplug from ANY shore power. Turn your Inverter on, take a three pronged Circuit Tester like the one below and plug it into all of the sockets in the bedroom and nearby area to see which ones work and which ones don't. https://community.fmca.com/topic/3171-retired-allison-transmission-fluids-engineer/ Link to comment Share on other sites More sharing options...
FHWilliams57 Posted November 20, 2021 Share Posted November 20, 2021 I would also check this post before plugging in cpap machine on inverter power. I have no experience on this and maybe someone else can conform? Link to comment Share on other sites More sharing options...
waterskier_1 Posted November 20, 2021 Share Posted November 20, 2021 40 minutes ago, FHWilliams57 said: I would also check this post before plugging in cpap machine on inverter power. I have no experience on this and maybe someone else can conform? Yes, electric blankets & Keurig coffee makers are very suspects to damage by MSW inverters. I use CPAP also. I have a 12-volt DC cable for I bought for mine. I started using it before I had a coach wired with an inverter. When I upgraded CPAP machines, I made sure to get one that I could use with a 12-volt cable. I currently have PSW and leave the inverter on all the time so I can use either method. I keep the 12-volt cable handy for power outages at my sick-and-brick house. I haven't tried using it on MSW, but if the CPAP is older analog type, it should work. But if it's the newer digital type, it may not. I recommend getting a 12-volt cord and then you know you are safe. 1 Link to comment Share on other sites More sharing options...
Gary 05 AMB DST Posted November 20, 2021 Share Posted November 20, 2021 (edited) WOW! I have used my ResMed 10 on the inverter outlet with no problem so far. If I need the CPAP on inverter power, I will relocate to the other end of the bed and turn off the humidifier and not use an extension cord. Will not do it again though. Thanks for the info. Second thought, does the CPAP transformer make a difference? Gary 05 AMB DST Edited November 20, 2021 by Gary 05 AMB DST second thought Link to comment Share on other sites More sharing options...
Joelsheriff Posted November 20, 2021 Share Posted November 20, 2021 I have been using my Bipap on an extension from the bathroom Gfi run around the wall and under the bed. Doing this 13 years now on 3 different machines. No issues. When hooked to shore up sometimes plug directly into duplex near bed. Still no issues. 07 Dip PAQ Link to comment Share on other sites More sharing options...
hex_nut Posted November 21, 2021 Share Posted November 21, 2021 I have gone both ways in this situation. Fifteen years ago the CPAP machine I had did not have 12 volt DC power supply capabilities and there was no 120 volt AC inverter power in my RV bedroom. So I installed a power plug from the inverter into my bedroom. I was surprised at how much power drain there was leaving the 3000 watt inverter on all night. The CPAP uses very little power, but the inverter is a significant drain on the batteries just in idle mode. I boondock for weeks at a time and this was not acceptable. So, at the first opportunity, I purchased a CPAP machine that could be powered from a 12 volt power source. I installed a 12 volt DC power port on the nightstand by my bed. This works very well. I do not use a humidifier while boondocking as I expect it would have a significant impact on power usage. Good luck whichever way you decide to go. Richard Link to comment Share on other sites More sharing options...
dl_racing427 Posted November 21, 2021 Share Posted November 21, 2021 I have my Resmed Airsense 10 plugged into a UPS at home, with a 50ah AGM battery wired in and the alarm beeper removed. This keeps my CPAP running seamlessly through any power outages. I'm sure the UPS is MSW, and I've been using it like this for several years. It has run under UPS power for hours on several occasions, and I haven't noticed the power supply running hotter than normal, or any other issues. Of course, this may differ from one machine to another. I also have a Resmed Airsense Mini I use for travel, but haven't had an opportunity to try it on an inverter yet. Link to comment Share on other sites More sharing options...
96 EVO Posted December 1, 2021 Share Posted December 1, 2021 On 11/20/2021 at 10:15 AM, Gary 05 AMB DST said: WOW! I have used my ResMed 10 on the inverter outlet with no problem so far. If I need the CPAP on inverter power, I will relocate to the other end of the bed and turn off the humidifier and not use an extension cord. Will not do it again though. Thanks for the info. Second thought, does the CPAP transformer make a difference? Gary 05 AMB DST I've run mine on MSW inverter a dozen or so nights as well. Doesn't seem to affect it. 1 Link to comment Share on other sites More sharing options...
