woodylmiller Posted April 26, 2022 Share Posted April 26, 2022 Not sure if this is the right forum, but; my wipers started behaving badly. As it stands right now the only thing the wipers will do is activate for one sweep of the windshield every 2 or 3 minutes. That's it. They will not shut off nor operate in any other fashion. Wiper/washer function, no. Constant on, no. Able to adjust the interval timing, no. Turn off, no. Not sure where to start trouble shooting. A smart wheel problem? Roadside chassis multiplex, the dreaded Kongsberg system? There is no response from pushing any buttons on the smart wheel. The wiper does make a sweep once every so often so I know it's getting power. Other functions on the smart wheel are working. Thanks, Woody Miller 09 Dynasty Link to comment Share on other sites More sharing options...
Trinidaddave Posted April 26, 2022 Share Posted April 26, 2022 Woody, my 2005 Safari Gazelle also moves once when I turn the key on. All other wiper functions seem to work okay. It hasn't worsened so I haven't investigated further. Please post your resolution to your problem. Link to comment Share on other sites More sharing options...
Frank McElroy Posted April 26, 2022 Share Posted April 26, 2022 25 minutes ago, woodylmiller said: Not sure if this is the right forum, but; my wipers started behaving badly. As it stands right now the only thing the wipers will do is activate for one sweep of the windshield every 2 or 3 minutes. That's it. They will not shut off nor operate in any other fashion. Wiper/washer function, no. Constant on, no. Able to adjust the interval timing, no. Turn off, no. Not sure where to start trouble shooting. A smart wheel problem? Roadside chassis multiplex, the dreaded Kongsberg system? There is no response from pushing any buttons on the smart wheel. The wiper does make a sweep once every so often so I know it's getting power. Other functions on the smart wheel are working. Thanks, Woody Miller 09 Dynasty When you say everything else on the smart wheel works, have you verified that flashing the headlights and rear marker lights work? If they don't work then likely you have a failing 5 VDC supply from the CCM. This fix has been detailed in another discussion. Link to comment Share on other sites More sharing options...
Trinidaddave Posted April 26, 2022 Share Posted April 26, 2022 Thanks for the information, I will check these items. I know my rear marker lights work since I used the power for my new rear camera. I will look for the previous post. We have only owned the coach a little over a year, but learn something new every day. Link to comment Share on other sites More sharing options...
Dr4Film Posted April 26, 2022 Share Posted April 26, 2022 David, Frank's point was to check the two buttons on your VIP Smart Wheel that are for Flashing the headlights or Flashing the Marker Lights. That has nothing to do with whether your headlights and marker lights work correctly when simply turned on. Link to comment Share on other sites More sharing options...
lake49068 Posted April 26, 2022 Share Posted April 26, 2022 Think wiper motors have a thermal overload function. If yes, it will reset itself after cooling down. So possible bad motor and/or binding linkage causing motor to overload and stop. If wiper arm stops "mid swipe" that's another clue. Link to comment Share on other sites More sharing options...
Ivylog Posted April 26, 2022 Share Posted April 26, 2022 Not a motor overload. The multiplex system keep doing what’s it told (intermittent wipers) until it’s told to do something else like stop… the wipers are not getting that command. Link to comment Share on other sites More sharing options...
willbo777 Posted April 26, 2022 Share Posted April 26, 2022 I'm not sure it is the exact same problem, but my wipers would act up, sometimes they would turn on and then be unable to turn off or visa versa. Sometimes there would be no way to turn them on, always in the rain:-), then if I got them on finally, I couldn't turn them off. Turned out it was the clock spring. Link to comment Share on other sites More sharing options...
woodylmiller Posted April 26, 2022 Author Share Posted April 26, 2022 I thought an auto resetting thermal circuit breaker might be the problem. But the wipers will not turn off, so it's a command issue I think. Cold, windy and nasty out today so the next time the sun comes out I may try disconnecting the batteries to see if I can reboot the system. Maybe the electrons are a little disorganized or confused about what I want them to do. Frank, I know the headlight flashing worked. I'll double check those and the marker lights and take it from there. Woody MIller Link to comment Share on other sites More sharing options...
