pcallison Posted August 30, 2022 Share Posted August 30, 2022 To all who can help with this?? Anyone know how to reset code for the safe that is in my coach. When I bought it they didn't know the code. I have contacted Monaco for information and was told they couldn't help. There has to be a way to reset them, just finding out how to program them is the key I suppose. Doc Gem and there was a number on the bottom corner... Thanks Phil Link to comment Share on other sites More sharing options...
Wrayj1 Posted August 30, 2022 Share Posted August 30, 2022 Hopefully someone knows, may need a locksmith or a safe cracker. Link to comment Share on other sites More sharing options...
Dr4Film Posted August 30, 2022 Share Posted August 30, 2022 A safe cracker may be your only solution. I would think that it would have to be in the open position to reset the code. 1 Link to comment Share on other sites More sharing options...
Gary Cole Posted August 30, 2022 Share Posted August 30, 2022 Try 50 50 50. That is the code most safes ship with. Lot of people don't change the code. Afraid they might make a mistake. Link to comment Share on other sites More sharing options...
pcallison Posted August 30, 2022 Author Share Posted August 30, 2022 Was just watching some youtube on how to get it open and they aren't really that safe?? lol I think I will give it a shot... I will try the 50 ship code first though... Evidently there is a clinoid pin that can be jarred loose?? Link to comment Share on other sites More sharing options...
Wrayj1 Posted August 30, 2022 Share Posted August 30, 2022 Yes, safe is a very relative term as is secure. We have a female friend who is quite paranoid regarding security of her home. She asked me about various locks, security cameras, etc. My reply was that locks work reasonably well for slowing down entry into your house, security cameras will get you a picture of the invader, who has long been gone before you can react to it and with all that said and done your best bet is to remove your windows because if they are determined to get in breaking a window or patio door is the easiest way in. I recommended she have good locks, close and latch the windows, have security cameras, but nothing guarantees that someone can't get in. My thought is that motion sensor lights on all sides of your house is as good a deterent as anything. When the light comes on a potential intruder doesn't know if your home and turned on the light because you knew they were there. Sorry for the dissertation, but security issues amuse me. 1 Link to comment Share on other sites More sharing options...
Tom Cherry Posted August 30, 2022 Share Posted August 30, 2022 Are you sure it was a Monaco installed option. Can’t find the 2003 brochure, but the 2002 & 2004 don’t list it. YES….they did custom builds, but only the upper ends had safe options. have you tried the manufacturer of the safe? This looks like an older style hotel safe where you programmed in your own number before they went to the key style. My understanding was that there is a “master” programming code to reset them. I have installed a lot of combo locks at our church and you program them with a code. For these, if it is a “hotel” style OEM or added by an owner….it has “the code” stamped or printed somewhere. It is battery powered. Does it go beep or give you any kind of feedback? Lots of questions. As Richard pointed out, a good locksmith will be “bonded and licensed” and have the access code or a way of getting in. I watched a maintenance man at our time share when they had these kind, He popped in a master or a programming code….reset the code to the “universal one”, then it worked. Might pursue the manufacturer or maybe shoot a picture and visit a good local bonded locksmith….they will give you info….as well as an estimate. Assume it is bolted down. Can you get to the bolts? Grind off the heads of there are any or the nuts….take it out. Might be cheaper to buy a new one, The combo dial (three digits) ones are sold by Amazon and Lowes. I have one in the MH and it is secure….and has NO BATTERY….a good feature. I don’t bother to bolt it down….it is a heavy dude…. Good Luck Link to comment Share on other sites More sharing options...
Capt Mike Posted August 30, 2022 Share Posted August 30, 2022 I actually removed my safe and took into a local locksmith who “cracked” the safe and gave me instructions to reset the combo. It was pretty easy to do. Link to comment Share on other sites More sharing options...
Ivan K Posted August 30, 2022 Share Posted August 30, 2022 36 minutes ago, Capt Mike said: I actually removed my safe and took into a local locksmith who “cracked” the safe and gave me instructions to reset the combo. It was pretty easy to do. How have you removed the safe? Ours is bolted from the inside of it through the floor. Ours works so I did not check if there is a way to undo it from underneath, it would not be that easy or fast, it might even go through the rail. Just curious how safe it is from just stealing the whole thing ... Link to comment Share on other sites More sharing options...
96 EVO Posted August 31, 2022 Share Posted August 31, 2022 2 hours ago, Ivan K said: How have you removed the safe? Ours is bolted from the inside of it through the floor. Ours works so I did not check if there is a way to undo it from underneath, it would not be that easy or fast, it might even go through the rail. Just curious how safe it is from just stealing the whole thing ... Usual way! Chain around it, attached to the toad, and just a little tug 😂! 1 1 Link to comment Share on other sites More sharing options...
GypsyJo Posted August 31, 2022 Share Posted August 31, 2022 Depending on the brand, I’d you can see an ID number you can call manufacturer and they can send you the combo. Link to comment Share on other sites More sharing options...
coastal_front Posted August 31, 2022 Share Posted August 31, 2022 (edited) It looks a lot like the one I installed in our coach. Strictly from memory since the coach is in storage, there is a small key hole behind the logo on the front of the safe. You open it with the key, change the batteries (couple of AAA's) and reset the code by following the directions inside. The key is a small one that looks like it would be for a padlock. If it is like mine, it came from Harbor Freight. Edited August 31, 2022 by coastal_front Link to comment Share on other sites More sharing options...
Beemermcr Posted August 31, 2022 Share Posted August 31, 2022 Ours opens/looks like a hotel safe: opens wth 1111, worth a try. Link to comment Share on other sites More sharing options...
Capt Mike Posted August 31, 2022 Share Posted August 31, 2022 Replying to Ivan K… my safe was bolted to a piece of one inch board and that board was held in place by four wood screws. (If memory serves) I did remove the door that hides the safe also. Link to comment Share on other sites More sharing options...
Ivan K Posted August 31, 2022 Share Posted August 31, 2022 13 minutes ago, Capt Mike said: Replying to Ivan K… my safe was bolted to a piece of one inch board and that board was held in place by four wood screws. (If memory serves) I did remove the door that hides the safe also. Thanks for the reply , Mike. Sounds like a different installation. Link to comment Share on other sites More sharing options...
dl_racing427 Posted August 31, 2022 Share Posted August 31, 2022 17 hours ago, pcallison said: Was just watching some youtube on how to get it open and they aren't really that safe?? lol I think I will give it a shot... I will try the 50 ship code first though... Evidently there is a clinoid pin that can be jarred loose?? Many of these type safes can be opened with a paper clip. It's possible to slip the clip behind the bezel and short across the relay that trips the bolt. Once it's open, there may be a reset button inside to allow reprogramming the combination. Check Youtube for instructions, and remember it's only a deterrent. I wouldn't keep my gold bars in there. LOL 2 Link to comment Share on other sites More sharing options...
