Gary Petersen Posted February 25, 2023 Share Posted February 25, 2023 OK, my three new "vented" ICON Shrouds arrived today, along with my foam gasket material which, I hope to install on my 2002 Sig.. Today was my first opportunity to kinda see down into the exposed units. I don't think any of the original AC units ever had their shrouds off. They look pretty dirty from my ladder perch. How, and what Maintenance should I perform to Clean, or Lube the units, before I install the new shrouds? Is there anything to be done under the sheetmetal cover. Thanks, Gary Link to comment Share on other sites More sharing options...
Steven P Posted February 25, 2023 Share Posted February 25, 2023 Other than tightening the bolts from the inside, I don't think there is much maintenance on these. Periodically use an AC coil cleaner and water hose to clean dirt and debris from the fins. Use low pressure to avoid damaging the fins and there may be some water that drips inside so a protective tarp under it would be good. 1 Link to comment Share on other sites More sharing options...
SteveC Posted February 25, 2023 Share Posted February 25, 2023 Annually I remove the covers and check the fins for dirt and wasp nests. The air is drawn into the coils so keeping them clean helps efficiency. I agree with Steven P. Be careful not to bend or damage the fins. I typically will use low pressure air and blow the dust out and blow the fins from inside to outside. I also keep an AC fin straightener on hand in case any need adjusting. Link to comment Share on other sites More sharing options...
jacwjames Posted February 25, 2023 Share Posted February 25, 2023 15 minutes ago, SteveC said: Annually I remove the covers and check the fins for dirt and wasp nests. The air is drawn into the coils so keeping them clean helps efficiency. I agree with Steven P. Be careful not to bend or damage the fins. I typically will use low pressure air and blow the dust out and blow the fins from inside to outside. I also keep an AC fin straightener on hand in case any need adjusting. This is what I do. The other thing to periodically check is whether the motor is spinning freely, my front one started to seize up in 2015 and I had to replace it. When I did that I also found that the rubber support bushings were worn out letting the motor squat. It squatted enough for the fan blade to hit the metal shroud occasionally. In 2021 my rear AC started to make a noise, when I checked it I found the rubber bushings were again worn out. I decided that after ~20 years the AC's were probably on there last leg so I decided to replace both. At the time a new AC cost ~$1200, they have almost doubled in price since then. 1 Link to comment Share on other sites More sharing options...
MyronTruex Posted February 25, 2023 Share Posted February 25, 2023 Remove the metal shroud showing and clean the inside condenser. It can be tricky keeping water from getting into the rv but take your time. Link to comment Share on other sites More sharing options...
Solution 96 EVO Posted February 25, 2023 Solution Share Posted February 25, 2023 That's the 'Evaporator' coil under that metal shroud, and if you want to get the best performance out of the unit, it needs to be clean. Also, if you do a search on this forum, there are some pic's posted of where exactly the foam strips need to go. 3 Link to comment Share on other sites More sharing options...
brokenarrow1244 Posted February 26, 2023 Share Posted February 26, 2023 it is a good opportunity to be sure the condensation drains are clean and open. you have easy access to the collection area while doing the cleaning. Link to comment Share on other sites More sharing options...
throgmartin Posted February 27, 2023 Share Posted February 27, 2023 The inside evaporator coil is a mus to clean. It gets packed with dust and dirt over the years because of the flimsy filters used for these units. The best way to clean these coils is to remove the metal shroud, lay a tarp or whatever on the floor inside under the unit, soak the coils down with a coil cleaning solution you can get from Lowe's. Then with someone standing on a step stool, have them hold a large trash bag over the opening while you blow the coils out from the roof. This is how we do it at my service center. You will be surprised at the amount of crud that comes out, especially if you have pets. This process will increase the efficiency of your AC units. 3 2 Link to comment Share on other sites More sharing options...
jacwjames Posted February 27, 2023 Share Posted February 27, 2023 57 minutes ago, throgmartin said: The inside evaporator coil is a mus to clean. It gets packed with dust and dirt over the years because of the flimsy filters used for these units. The best way to clean these coils is to remove the metal shroud, lay a tarp or whatever on the floor inside under the unit, soak the coils down with a coil cleaning solution you can get from Lowe's. Then with someone standing on a step stool, have them hold a large trash bag over the opening while you blow the coils out from the roof. This is how we do it at my service center. You will be surprised at the amount of crud that comes out, especially if you have pets. This process will increase the efficiency of your AC units. On my older unit peeling the sheetmetal back was a PITA, which is why the cleaning doesn't happen that often or if at all from the top. I had some success using a vacuum and long attachment with a brush head going form below but you can only get ~50% of the face. The newer units have a removable plastic shroud that is easy take off and put back on. Link to comment Share on other sites More sharing options...
MyronTruex Posted February 27, 2023 Share Posted February 27, 2023 I use one of those thin plastic cutting boards to re-direct the water spray when cleaning those coils. I have had some success with taping the hole but some sort of plug would sure help. This group has enough talent to invent something. Maybe a small blow up inner tube or beach ball? The filter provided for the Wacko silencers is excellent but still must be cleaned often. We full time so that is quite regular. To make that chore a bit quicker I fashioned some thumb screws to replace the phillip head screws. 1 Link to comment Share on other sites More sharing options...
96 EVO Posted February 27, 2023 Share Posted February 27, 2023 Myron, I just used a trigger pump spray bottle full of water to rinse the evap cleaner and debris out of mine. I did have a towel over the hole, but practically didn't need one. Link to comment Share on other sites More sharing options...
MyronTruex Posted February 27, 2023 Share Posted February 27, 2023 We full time and lived at the end of a dirt road. Mine got plenty dirty. We have moved to a bit less dusty enviornment now. Link to comment Share on other sites More sharing options...
Gary Petersen Posted March 3, 2023 Author Share Posted March 3, 2023 My appreciation to all, for your advice and support regarding my AC issue. As suggested, I first gently sprayed compress air and then sprayed the Evaporator and Coil with a spray foam cleaner which did a fine job of sloughing off the dirt and grime before a final cleanup. I found your noted photographic description of exactly where the new AC foam tape was to be located on my early AC models, especially helpful. I am truly impressed with the recommendation of the new ICON brand shrouds from Amazon. After a minor straightening of the AC's sheet metal, my new Stainless Steel screws aligned perfectly with holes in all three of the AC's and shrouds. These shrouds are awesome. Now, all I have to do is look for some warmer weather, South of Seattle, to be able to use them. Thank You's 2 Link to comment Share on other sites More sharing options...
