snoracer Posted June 8, 2023 Share Posted June 8, 2023 I'm about to install a new stereo to replace the old magnadyne. What are you guys doing to adapt a new single din stereo into the old double din hole. Are there new dash panels available to do this? Amazon has adaptors, but they are year make and model specific, so obviously nothing is available for RV's. Thanks Tim Link to comment Share on other sites More sharing options...
Scotty Hutto Posted June 8, 2023 Share Posted June 8, 2023 Tim, I can’t speak with authority about the 2007 Endeavor, but the 2006 Diplomat (twin coach) had a 1.5 DIN Magnadyne. I was able to enlarge the hole on the top and bottom to get a double din unit installed. Here’s a link to my install: 1 Link to comment Share on other sites More sharing options...
Martinvz Posted June 8, 2023 Share Posted June 8, 2023 Same issue on my LaPalma as I have a 1.5 Din Magnadyne as well. Still to be replaced …. Link to comment Share on other sites More sharing options...
snoracer Posted June 8, 2023 Author Share Posted June 8, 2023 Thanks Scotty - I must admit, I am definitely not up to speed on stereo stuff. This whole DIN thing is new to me. I haven't replaced a stereo in about 20 years. I should probably get educated from my kids. My problem with this installation is that the new radio is a single DIN, so I need to find some way to mount this smaller radio into a much larger hole. I've been searching on this forum and IRV2. I did see a post where someone made a completely new dash panel out a piece of oak and stained it to match the rest of his woodwork. I just might give that try. Two of the corners are broken on my dash panel from the screws being tightened too tight, so now would be a good time to replace it. I'm open to any idea's. Link to comment Share on other sites More sharing options...
miacasa_2000 Posted June 9, 2023 Share Posted June 9, 2023 Tim if your skills with wood working are ok to do it with wood then you also could do it with sign material. That's what I did you use all the same wood working tools on it (saws,drills,router,Etc..) the material is 2 pcs of aluminum with rubber in-between so much stronger and will never crack and can hold the weight of radios and more. It's 1/4" thick but bevels nicely to create a nice edge. I picked up a scrap pc at a local sign shop and made my radio dash plate and my wall panel. Roy 2003 Dynasty Link to comment Share on other sites More sharing options...
Rikadoo Posted June 9, 2023 Share Posted June 9, 2023 Hey Tim, im the same when it comes to similar things, however have you tried Crutchfields? They have people you can talk to that “speak” that kind of stuff… Link to comment Share on other sites More sharing options...
Bruce S Posted June 9, 2023 Share Posted June 9, 2023 I have previously fabricated new black panels from 1/4" plexiglass when I had similar problems in my coaches. The first one I attempted was the driver's side panel where the transmission shifter sat in our old 98 Sig. I later fabricated other dash pieces in a similar fashion using the old pieces as a template. The only issue you might have is where something was stuck to the backside of the panel. This might require a little ingenuity. Thinner plexiglass doesn't stand up over time especially for screw holes. Unfortunately I don't have any before/after pics to add just one pic of a panel that needed some tlc. The panel shown had one too many large holes as well as broken screw holes. You can also see bolt heads glued to the backside of the panel. Link to comment Share on other sites More sharing options...
snoracer Posted June 9, 2023 Author Share Posted June 9, 2023 Thank you everyone for all the suggestions. I think for now I'll fabricate a filler plate to fill the entire opening where the old radio was. I have a sheet of 1/8th inch aluminum that should work pretty well. I'll glue it to the backside of the woodgrain dash panel using panel bond. We use panel bond in the body shop to glue body panels on. Should easily support the weight of the new radio. I will try to remember to follow up with photo's and results. Link to comment Share on other sites More sharing options...
lake49068 Posted June 11, 2023 Share Posted June 11, 2023 I contacted Magnadyne a few years back to see if they had a newer 1.5 DIn replacement radio..no. But they did have a 1.5 to single DIN adaptor plate plus they could provide a wiring harness to connect any brand of single DIN radio to the coach's original Magnadyne connectors. Perhaps an easier approach? My Magnadyne radio had a problem with the Sirius/XM function so decided to buy a stand alone XM receiver connected to the radio's audio input. Even simpler! Link to comment Share on other sites More sharing options...
Solution snoracer Posted June 11, 2023 Author Solution Share Posted June 11, 2023 Thanks for that info Adam. I just checked the magnedyne website and I found the adapter plate, but not sure of the wiring harness yet. I'll have to call tech support later on for more info. Thanks again. Link to comment Share on other sites More sharing options...
lake49068 Posted June 11, 2023 Share Posted June 11, 2023 Magnadyne tech support volunteered the info about the "custom" harness so not surprised they're not on the website. Hope that my comments are still good... Link to comment Share on other sites More sharing options...
