MHRookie Posted August 3, 2023 Share Posted August 3, 2023 All, little direction needed on where to purchase the copper bar/plate material used in RRB and to hook up the ACR UNIT? Thanks in advance, Kurt Link to comment Share on other sites More sharing options...
Jdw12345 Posted August 3, 2023 Share Posted August 3, 2023 I believe that others have been using McMaster-Carr. Link to comment Share on other sites More sharing options...
jacwjames Posted August 3, 2023 Share Posted August 3, 2023 You might check Ebay to see if there is something that will work https://www.ebay.com/itm/304712537845?var=603742074291&hash=item46f24856f5:g:4mwAAOSw~WZjfSSu&amdata=enc%3AAQAIAAAA0MKHcRaWpjKGPR%2BeNjdqcLJcjlAl69nECVJRUGO2OAz8ZZpda%2FXaUZNOvC0GU4b2n5UB4kVyEAI%2FCKgUky0FBea2X8uRFopcv6uBygzZ4WJY0bwq68oce3gSHg8oEYuV8j86Jo4pAqxK6RlVaAN9agKE9FlAhyO2ssY7bR3yQtRevrvPyDjiQLYnD%2BJ6hF1vmCEyS9gayGYc%2FZH%2B%2BiaIKn6pMoDEWtNm78a5SmBaLd0gTczY3YDjPkVn%2B2bqATObMmEfPATbxozRLU9Dy6S2Se8%3D|tkp%3ABk9SR4amsrC3Yg Link to comment Share on other sites More sharing options...
willbo777 Posted August 3, 2023 Share Posted August 3, 2023 I used Online Metals Link to comment Share on other sites More sharing options...
Yoaks5 Posted August 3, 2023 Share Posted August 3, 2023 I got mine from Amazon. Ququyi Pure Copper Flat Bar 1/8"... https://www.amazon.com/dp/B0B1PRCKRX?ref=ppx_pop_mob_ap_share Link to comment Share on other sites More sharing options...
Dr4Film Posted August 3, 2023 Share Posted August 3, 2023 I also purchased mine from Amazon but mine is thinner than the one above. If you get one too thick it will be harder to bend into the shape you need. https://tinyurl.com/yu6n3fuh Link to comment Share on other sites More sharing options...
Cubflyer Posted August 4, 2023 Share Posted August 4, 2023 soft copper tubing (3/8") hammered flat will work pretty good, use a step drill/unibit to drill the holes. 1 Link to comment Share on other sites More sharing options...
MHRookie Posted August 4, 2023 Author Share Posted August 4, 2023 31 minutes ago, Cubflyer said: soft copper tubing (3/8") hammered flat will work pretty good, use a step drill/unibit to drill the holes. I wondered if this would work. Didn’t know if hammering flat would be considered “loose” and possibly arc…..but then stranded wire is all loose. second, wasn’t sure if there was a thickness element since the 2/0 wires are what’s hooked to it. thanks!! Link to comment Share on other sites More sharing options...
Solution Cubflyer Posted August 4, 2023 Solution Share Posted August 4, 2023 Dr4Film's link to amazon is about perfect IMO... 1/12 of an inch is thinner than 1/8 inch... 1/8th=.125 1/12th =.078... flattened 3/8"copper tubing is about .063 1 Link to comment Share on other sites More sharing options...
georgecederholm Posted August 4, 2023 Share Posted August 4, 2023 I also used 1/8” copper bar stock from Amazon in the 1” width for buss bars and numerous battery terminal extensions/adapters. 1 Link to comment Share on other sites More sharing options...
